September 23, 2026, 09:20:59 am
| | |-+  Berg sump
Author Topic: Berg sump  (Read 8414 times)
baz
« on: July 26, 2020, 08:48:20 am »
Are folk loctiting these in place?
« Last Edit: July 26, 2020, 08:51:13 am by baz » Logged
I will prevail.
« Reply #1 on: July 26, 2020, 16:09:06 pm »
Not me and never had one come loose Smiley
baz
« Reply #2 on: July 26, 2020, 16:45:50 pm »
Hmmm, you using gasket? I have gasket with smear of black sticky stuff. Perhaps the gasket is the problem ya think?
I will prevail.
« Reply #3 on: July 26, 2020, 18:52:55 pm »
Do you have an Ali case? If so I had to clearance a little bit underneath my case as it slightly fouled on my empi 3.5 deep sump. This prevented the sump sitting perfectly flush with the case. May be worth a look
Lee
baz
« Reply #4 on: July 26, 2020, 19:12:26 pm »
Lee
I had that problem too Lee but clearanced the sump to allow it to fit. My guess is its the gasket compressing that's causing it.
That's an uneducated guess though  Tongue
I will prevail.
« Reply #5 on: July 26, 2020, 19:39:04 pm »
It’s been so long, I can not remember if there is a gasket or not. I use Wellseal on the mating surfaces. Matt Keene recommended it to me and it’s very good.
Lee
baz
« Reply #6 on: July 26, 2020, 19:49:47 pm »
Lee
I was using wellseal on case until I ran out and used loctite, prefer the loctite now. Forget the number. I'm gonna put sump on with just sealant this time and see how it goes.
I will prevail.
