October 05, 2026, 13:00:27 pm
Latest Member: Chakalives
| | |-+  New MeXXspeed mill V3
Pages: [1] 2 3 ... 7 Print
Author Topic: New MeXXspeed mill V3  (Read 153209 times)
MeXX
« on: February 18, 2021, 09:34:57 am »
Dear Folks....
After much too long time I'm trying to post as much as possible of my R&D of the last years....
I know that much time has past till I posted a threat of my old engine....
http://cal-look.no/lounge/index.php/topic,20436.msg284272.html#msg284272
put step by step I will post all the details and spec and the evolution of my engine....
<a href="http://www.youtube.com/v/zbtBX-Nt9UU" target="_blank">http://www.youtube.com/v/zbtBX-Nt9UU</a>
MeXX
« Last Edit: February 26, 2021, 08:55:57 am by MeXX » Logged
Drag or Die
karl h
« Reply #1 on: February 18, 2021, 09:46:02 am »
seen it in person, its awesome!
samotorsport
« Reply #2 on: February 18, 2021, 10:11:12 am »
Can t wait to see the magic Smiley
MeXX
« Reply #3 on: February 18, 2021, 10:16:49 am »
I always have been really in love with " unlimited NA engines" and seeing how far the V8 guys pushed the small block engines in NASCAR and Australian Pro Stock and the big blocks in NHRA and PDRA..
has been inspiring me to push our tiny Volkswagen engine as far as possible... or at least as I can...
to get the....
Unlimited NA Type 1 engine.....
So what does T1 mean?   of course not a modified stock Beetle engine.... but an engine that is based on that.... with the same bore spacing of 112mm and the same cam location, although a cam trop would make sense it is not necessary...
Unlimited does definitely ask for the maximum displacement, so what is the maximum that makes sense?? in my case 4.040" (102.6mm) bore by 90mm stroke.... for sure the bore can be enlarged even further... as we did... and yes the displacement will get bigger, so it will by more stroke... but the rigidness of the whole strukture will suffer... and but can you really make more horsepower??
That this combo has been the right decision... has come true for me after the last dyno sessions and rack tests....
« Last Edit: February 18, 2021, 11:25:28 am by MeXX » Logged
Drag or Die
MeXX
« Reply #4 on: February 18, 2021, 10:23:54 am »
upside down I will start with the dyno results and the track tests....
as I was asked several times.... still with out Nitrous...... but I can guarantee the day will come....
439,4hp @ 9150 RPM
« Last Edit: February 18, 2021, 14:17:40 pm by MeXX » Logged
Drag or Die
MeXX
« Reply #5 on: February 18, 2021, 10:31:47 am »
the track tests @ TnT in Zerbst in September 2020....
unprepped track...
no full run... launch @ 7800RPM shifts @ 8200 8400 8600 8600
I had to pedal the car in first and slightly in second gear.... but still quite a promising result:
8.903 @ 237.333km/h (148,3mp/h)
« Last Edit: February 18, 2021, 14:38:27 pm by MeXX » Logged
Drag or Die
Basti
« Reply #6 on: February 18, 2021, 13:03:30 pm »
been there  Cool
- black 62 cal look beetle
- Pro Mod Race car
MeXX
« Reply #7 on: February 18, 2021, 13:09:23 pm »
MeXXspeed V3 spec:
displacement 2977ccm
bore 4.040" 102.62mm
stroke 90mm
CR 14.6:1
fuel injected on methanol
Case is Autocraft modified and reinforced (thx to Mike Seymour)
Crank is custom Scat billet flanged 90mm chevy rod and main bearings (thx to Tom Lieb)
Flywheel is billet aluminum with bronze wear plates, billet pressure plate centrifugal enhanced
Pistons are CP X forging 4.040"
Cylinder are billet housings with ductile iron liners
Pins are .866-15-DLC titanium hyprid
Rods are billet titanium 6" length 2" rod bearing and 22mm pin
Heads are Billet MeXXspeed V3.4 canted valves with valve rotation
Valves are Xceldyne titanium 7mm hollow shaft Intake 2.150" (54.6mm), 7mm shaft Exhaust 1.600" (40.6mm)
Rockers are Jesel custom 1.800 pivot arm 1.8 to 2.0 ratio
Pushrods are Manton 9/16" barrel shaped
Lifter are Jesel DLC dogbone roller lifter .904 with .820 roller
Cam is a custom tool steel S7 from Com Cam with Intake 281° .920lift Exhaust 294° .860 lift 112°LCA (thx to Dean Harvey)
Cam geer is Magnum
Retainer CHE coated titanium
Valve springs PSI
Oil pump is Dailey 5 stage dry sump oil vacuum pump
Bearings are King XP
Exhaust is over the top 2 to 2 1/8 stepped inconel with titanium reverse cone stinger
« Last Edit: February 18, 2021, 15:45:42 pm by MeXX » Logged
Drag or Die
Trond Dahl
« Reply #8 on: February 18, 2021, 16:08:42 pm »
Thanks for sharing,
always said your work is not only proven in performance but is also work of art!
Race car 9.49/236kmt@SCC 2017
Eddie DVK
« Reply #9 on: February 19, 2021, 07:19:26 am »
Whoooo,
I love the injectors above the throttle body s
Regards Edgar
MeXX
« Reply #10 on: February 19, 2021, 08:34:15 am »
Whoooo,
Hi Eddi....
we moved the injectors as far up as possible.... and gained close to 20hp on the dyno....
<a href="http://www.youtube.com/v/XkDv919AW_Q" target="_blank">http://www.youtube.com/v/XkDv919AW_Q</a>
« Last Edit: February 19, 2021, 09:20:59 am by MeXX » Logged
Drag or Die
Erlend / bug66
Global Moderator
SCC Event
« Reply #11 on: February 19, 2021, 09:57:39 am »
Whoooo,
Hi Eddi....
Did the raised injectors make the previous tune too fat, end you could lean it out?
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
Eddie DVK
« Reply #12 on: February 19, 2021, 09:59:28 am »
Whoooo,
Hi Eddi....
This is a a cool picture.
20 HP is a serious.
Looking at using throttle bodies and placing the injectors above them with a bracket in the oval filter houses like on IDF/dellorto carbs.
This is good mind food then.
Regards Edgar
MeXX
« Reply #13 on: February 19, 2021, 11:50:39 am »
« Last Edit: February 19, 2021, 12:20:00 pm by MeXX » Logged
Drag or Die
MeXX
« Reply #14 on: February 19, 2021, 12:19:30 pm »
Whoooo,
Yep....
we had to remove fuel from the mapping and got more power on the other hand.... WOT a wonderful world....
Seriously.... it is just about the fuel that enters the combustion chamber as a liquid and even if it is tiny droplets.... it is just lost for the combustion...
So if you get the same amount of fuel evaporated in the combustion chamber it is just on the rich side....
Additionally we could see the egt going up....
MeXX
Drag or Die
Erlend / bug66
Global Moderator
SCC Event
« Reply #15 on: February 19, 2021, 13:16:45 pm »
Whoooo,
Yep....
MeXX
I guessed that was the only way it would make more power. Better atomization of fuel given the slightly longer time to disburst into a mist.
The '67:
The '59:
Not yet..
MeXX
« Reply #16 on: February 19, 2021, 13:24:10 pm »
Whoooo,
Yep....
MeXX
Yep.... especially on methanol....
Drag or Die
mikko k
« Reply #17 on: February 20, 2021, 08:57:19 am »
Hi,
Have you tested this engine on dyno with race gas or E85?
MeXX
« Reply #18 on: February 20, 2021, 09:25:16 am »
Hi,
Hi....
It is running on methanol only.... we tested different kinds like M1 and M5...
MeXX
Drag or Die
PPRMicke
« Reply #19 on: February 20, 2021, 10:07:12 am »
Hi,
Hi....
MeXX
What pressure on the fuel Martin
  Here in Sweden, they run high pressures type 8 bar on methanol with EFI
to atomize the fuel
/// Micke
MeXX
« Reply #20 on: February 20, 2021, 10:32:59 am »
to atomize the fuel
/// Micke
Hi....
Yep the higher the better... at least I think so....
By doing some testing with the spray pattern of the injectors.... I checked out that at certain pressure the injector starts to atomize better...
@ 30 psi really bad just spitting droplets....
@ 40 psi much better
@ 45 psi nearly all fuel is atomize
@ 50 psi all fuel is atomized
@ 55 psi no further change...
That's why I kept the fuel pressure @ 50 psi
« Last Edit: February 20, 2021, 14:27:09 pm by MeXX » Logged
Drag or Die
MeXX
« Reply #21 on: February 20, 2021, 15:13:38 pm »
To built the ultimate unlimited NA T1 engine the key facts are
as much displacement as possible or better still makes more power...
as high RPM peak power as possible....
Heads that can deliver the CFM the engine is demanding according the first two facts...
A rigid backbone.... a case with crank and rod combo... that can bear that....
Maybe one of the most overlooked part is the valve train that has to be really stable and as straight as possible....
Maybe one of the best examples is Dan Jesel's Equal Eight Engine....
https://www.enginelabs.com/engine-tech/the-equal-8-inside-dan-jesels-new-clean-sheet-12000-rpm-v8/
<a href="http://www.youtube.com/v/NdOH6flt6E8" target="_blank">http://www.youtube.com/v/NdOH6flt6E8</a>
Without a doubt Jesel products are the best available, and there is a reason why, it is not only the quality and the design...
More being in industry for over 40 years.... in a leading position....
I really like what they call "The Straight Column Valvetrain (SCVT)"
The idea behind that is keeping the pushrod angle as straight (less than 1°) as possible, not only because it kills power, more because it just makes it just impossible to run high valve lift and aggressive cam raps....
These pix will show how straight I was able to end up...
« Last Edit: March 13, 2021, 13:37:44 pm by MeXX » Logged
Drag or Die
MeXX
« Reply #22 on: February 21, 2021, 09:12:45 am »
So let's start with the backbone... the bottom end...
The case is an autocraft and thx to Mike Seymour it was reinforced by modifying the mold before casting and not welding...
The idea behind that was to have enough material supporting the, bigger in diameter, .904 Jesel roller lifters...
The main studs were upgraded from 7/16 8740 CrMo to M12 tool steel, this was done to get a much higher clamping force to hold the case together on high horsepower and high RPM.
The upgrade was necessary because of the switch to 0W20 oil to keep the much tighter bearing clearance in spec....
Like the main bolts, so are the shuffle pins and the washers manufactured out of tool steel... check out the little collars to keep the aluminum from collapsing into the bore under the high load. The main bolts do have a yield strength of 1890N/mm2 and are finally torqued to 100Nm...
Autocraft case ready for assembly
Lifter bores .904 ready for the lifters check out the bolt for the dog bone
Main studs.. black is autocraft silver are tool steel....
Main and heads studs
« Last Edit: March 02, 2024, 20:07:58 pm by MeXX » Logged
Drag or Die
MeXX
« Reply #23 on: February 21, 2021, 16:09:52 pm »
The roller lifter are Jesel DLC coated dog bone style with a diameter of. 904".... as they are coated and the case is aluminum the clearance is kept to .02mm.
The dog bone is manufactured out of high strength beryllium bronce and is full floating ....
Jesel .904 DLC roller lifter with dog bone and hardware
lifter installer doing their job
side few, check out the additional aluminum to support the lifters
« Last Edit: February 21, 2021, 16:14:47 pm by MeXX » Logged
Drag or Die
Steve67
« Reply #24 on: February 22, 2021, 07:40:12 am »
thanks, this is really interesting to read. Great engineering!
MeXX
« Reply #25 on: February 22, 2021, 17:00:41 pm »
As mentioned before keeping the pushrod as straight as possible was one of the design requirements....
Giving the case a personal touch...
Check out the straight pushrod design...
« Last Edit: February 22, 2021, 17:09:23 pm by MeXX » Logged
Drag or Die
MeXX
« Reply #26 on: February 23, 2021, 20:03:52 pm »
The heart of the bottom end is the custom scat crank shaft...
Compared to the of the shelf part it has thicker webs, bigger radii smaller oil holes and 65mm main bearing diameter....
Custom crank compared to the "of the shelf " on the right
Bigger radii and smaller oil holes....
« Last Edit: February 24, 2021, 19:06:31 pm by MeXX » Logged
Drag or Die
MeXX
« Reply #27 on: February 23, 2021, 20:10:22 pm »
Thicker webs...
« Last Edit: February 23, 2021, 20:14:25 pm by MeXX » Logged
Drag or Die
dannyboy
« Reply #28 on: February 23, 2021, 22:11:21 pm »
epic on all levels  Cool
8.77@156.8mph
O/FF 60
MeXX
« Reply #29 on: February 24, 2021, 10:49:01 am »
As mentioned before the plan has been to run this engine on 0W20 Valvoline Pro V oil...
to keep the bearing clearance in spec it is necessary to have a very precise line bore and bearings that give you the chance to set the clearance to the required value.
A deep groove was machined into the case saddles to keep the bearings supported 360° with oil.... in addition they have to bring enough oil to the oils squirters located in the top side of the saddle pointing to the piston.
The  bearing shells have multiple slots to support the inner groove to lubricate the main bearing and support 360° oil supply for the rod bearings. In the #4 bearing location a roller style bearing is used. As these do not need pressurized oil supply a restriction of 0,5mm has been installed in the oil hole.
« Last Edit: February 24, 2021, 14:13:07 pm by MeXX » Logged
Drag or Die
