October 12, 2026, 16:46:59 pm
| | |-+  JPM 00806 camshaft
Author Topic: JPM 00806 camshaft  (Read 12802 times)
meule
« on: July 07, 2021, 21:36:23 pm »
Hello there,
I am looking for a replacement camshaft on my 2180cc motor that had a failed cam( FK8 )and lifters (Udo becker).
Does anyone can provide me with some more information on the JPM raptor cam 008(06) or is anyone using it on his engine?
I really can't find much more information about it other than the lift 9.64mm at the cam and advertised duration of 301°
Does anyone have a timing card for this cam?
I was told that this would be a split duration cam but can anyone tell me what would have the bigger duration lobes (in or outlet)?
Another question I have about this cam is if it is not to agressive on the lifterbores compared to the FK4x series cams?
thanks,
Glauco
« Reply #1 on: July 08, 2021, 06:35:03 am »
info@jpmotorsport.se
send him an e-mail, he will be happy to help you, very nice guy.
Dougy Dee
« Reply #2 on: July 08, 2021, 14:14:40 pm »
My info shows 263@.050.
106 LC
IC calculates at 67. Need cam card for actual.
For 1.4/1.5 rockers
meule
« Reply #3 on: July 08, 2021, 19:00:09 pm »
Wel, actually I've allready tried to contact him about 2 weeks ago thru an info request form on his website with no result so far.
I guess he must be verry bussy or maybe Swedish hollidays are a bit sooner than Belgian hollidays ;-)
baz
« Reply #4 on: July 08, 2021, 22:46:23 pm »
I will prevail.
cel
« Reply #5 on: July 09, 2021, 21:26:26 pm »
Hi
I have a jpm008/017 08 , split duration, 108 lc
Here is the sheet from jpm:
nice greetings
meule
« Reply #6 on: July 13, 2021, 06:54:09 am »
Hi
nice greetings
thanks  for sharing the details about your camshaft.
I can see your cam type is the 008/017 and this is indeed a split duration cam as the timing card confirms.
It makes me believe the 008 that I have in mind for my application won't be a split duration cam wich answers my question for the biggest part.
baz
« Reply #7 on: July 13, 2021, 13:26:15 pm »
Hi
nice greetings
I've the 00808 it's not split duration. Don't have the card as the guy who built the motor originally kept it
I will prevail.
meule
« Reply #8 on: July 13, 2021, 21:16:05 pm »
May I ask what kind of heads or motor size and C/R are you guys running with the 008 or  008/017?
And what about the powerband? I expect it to build some decent torque starting at 2500-3000rpm.
baz
« Reply #9 on: July 13, 2021, 21:50:46 pm »
2276 10.2 cr 041 heads by Jeff Denham makes 170 nm @2800 but isn't at optimum due to leaking rings. Getting fixed now hope to see 200 @3000 rising to 230
I will prevail.
