July 25, 2026, 19:01:26 pm
| |-+  For sale!
| | |-+  '53 full steel 8-sec cal-look
Author Topic: '53 full steel 8-sec cal-look  (Read 27689 times)
Jyrki
8.88 & 251
« on: July 23, 2025, 12:12:59 pm »
FOR SALE: Purpose built street car
I have had this car for 36 years and it has seen quite a few evolution versions. I built the latest version almost 15 years ago, and ran 8.88sec at over 250km/h in 1/4 mile, 5.68sec at over 200km/h in 1/8 mile 10 years ago. Since then my interest has been lame and lately it has not been out much, so maybe someone else could have fun with it?
Since the build thread ('A purpose built street car') I have upgraded to a new Mendeola -2D to replace the old MD-4, upgraded the turbo from a very old GT4294R to a new GTX4508R with Tial V-band housing, upgraded the IC to a custom W2A with Garrett 1000hp core, built a new custom plenum, upgraded steering to a rack&pinion etc.
Currently it makes over 660hp / 6600rpm & over 800Nm / 5400rpm with only 1.30bar boost! Before the upgrades I ran 1.7bar boost to make the same power.  This is enough to run a high 8 at over 250km/h in 1/4 mile. Injectors are at 60% DC, and the turbo is capable of a lot more, so I would say low 8s are at sight, but a 7 is a stretch unless clutchless shifting is implemented. Please note that the engine does not have modular cylinders, so it most likely would not handle 3+bar boost & 1000++ hp.
Asking 70.000€ turnkey with Finnish VIN, papers and plates (street legal with turbo, ladder bars, roll cage etc) / make a fair offer, no low-balls thanks.
Today it would cost over 100.000€ to duplicate, even if you’d do all the work yourself.
May separate; roller no engine, roller no engine no transmission, or just the engine and transmission package.
Along with the ‘53, I can also sell my black 2018 aluminum 3S trailer with lots of options and some custom touches to make it real nice for the '53. 5000mm x 2000mm, 800kg/2500kg, can be raised to 2700kg. Hydraulic lift for very low cars, electric winch with remote etc. Always stored in warm&dry, ‘as good as new’ (which would cost 258.000SEK). Asking 15.000€, but only if the ’53 sells.
Specs of the ‘53:
RLR SFI 7.50sec CrMo chassis, funny-car cage, 34" ladder bars
“Eternal 7.50sec certification”
RLR CrMo wheeliebars
Narrowed steel front beam
Steering rack VW Polo
Dropped spindles
Geers disc brakes front and rear, upgraded rear calipers and big spline hubs, 5/8” MW studs and titanium nuts rear, ½” front
Strange coil-overs 2-way adjustable (RLR spec), 3 sets of springs
Strange front shocks 2-way adjustable, custom valved
Vertigate shifter
Custom fuel & water cell
Aeromotive huge fuel pump, regulator, billet pre- and post-filters, -8AN S/S hoses
Meziere water pump for Water-IC
Tilton pedals
12V to 15V trick system
Working headlights, rear lights and horn
Kirkey 15" seat, co-driver's seat is fake
Stroud chute (fresh)
Fire suppression system, SFI approved, it has ran out of cert
Custom 3-piece 'fuchs' wheels, billet centers, new (zero passes) 9x29x15 slicks, front runners
Fresh 275-60-15 tires on steel wheels for dyno runs, 125-90-15 front tires on BMW steel wheels for storage
3/1953 oval window body - very early oval, one of the very first, some one-year only stuff. Very rare
Ribbed doors
Original front fenders (1960s?), repro rears
Deck lid with convertible style openings
H-pattern apron
Front stretched 35mm; very nice and tricky, nobody will notice
Rear fenders raised 65mm
Sahara beige paintjob
Repro chrome, rebuilt headlights, repro window rubbers & chrome, repro door handles etc
Lexan windows, front window is glass
Car looks good from 2-3 meters, but a closer look reveals flaws with the paint and uneven door gaps
Even though it has some lights and a horn, it will not pass annual street car inspection.
Mendeola / Weddle MD4-2D, bought in 2018, not many passes, stronger case, G50 input shaft, Rancho CV-spool and super-race-duty axles 5” narrowed, spare Liberty-rings
Pauter 94x108, never damaged, bullet-proof and very low maintenance for 18 years, only replaced bearrings once during 2007-2025 😊, and replaced the rockers in 2013 from the old-style to the new style.
-   94mm crank, 351W main, std/std
-   Pauter steel rods, BBC big ends
-   4.25” (108mm) pistons
-   Pauter heads 57x43, titanium intake, inconel exhaust
-   Triple springs - same set since 2007, still good to go 😊
-   1.3:1 new style rockers - low lift, less power, but zero issues
-   Pauter roller cam
-   4-stage gerotor dry sump upgraded at Pauter
-   Moroso tank, S/S AN hoses, dual 300W Defa 230V heaters, custom breather tower etc
-   Motec M800 ECU w/all options, incl. drive-by-wire, antilag, traction ctrl, launch ctrl, boost ctrl etc
-   Motec dash with logging
-   Motec professionally built wiring harness
-   Sensors: gearshift force, ride height front (infrared), ride height rear, clutch position, clutch speed, drive speed, GPS speed, lambda, air temp before and after turbo, oil temp, cylinder head temp, transmission temp etc
-   Garrett GTX4508R, Tial stainless steel exhaust v-band housing
-   K&N huge air filter
-   Custom W2A intercooler, built with Garrett 1000hp core
-   2 x Tial 38 wastegates
-   2 x Tial 50mm BOV
-   MSD coils
-   Custom plenum
-   997TT electric throttle body
-   Siemens 2200+cc injectors
-   36-2 custom pulley + mini-alternator
-   Kennedy dual-disc clutch + clutch management system
Fastest full-steel Beetle in the world?
Jyrki
jyrki dot laune at voland dot fi
« Last Edit: October 22, 2025, 14:57:17 pm by Jyrki » Logged
Jyrki
8.88 & 251
« Reply #1 on: July 23, 2025, 12:18:07 pm »
Jyrki
8.88 & 251
« Reply #2 on: July 23, 2025, 12:19:10 pm »
Jyrki
8.88 & 251
« Reply #3 on: July 23, 2025, 12:20:21 pm »
« Last Edit: July 23, 2025, 17:39:36 pm by Jyrki » Logged
Jyrki
8.88 & 251
« Reply #4 on: July 23, 2025, 12:21:43 pm »
« Last Edit: July 25, 2025, 09:35:08 am by Jyrki » Logged
Jyrki
8.88 & 251
« Reply #5 on: July 23, 2025, 12:23:01 pm »
Jyrki
8.88 & 251
« Reply #6 on: July 23, 2025, 12:23:32 pm »
« Last Edit: July 25, 2025, 09:38:20 am by Jyrki » Logged
Jyrki
8.88 & 251
« Reply #7 on: July 25, 2025, 13:36:53 pm »
Jyrki
8.88 & 251
« Reply #8 on: July 25, 2025, 13:39:02 pm »
Jyrki
8.88 & 251
« Reply #9 on: July 25, 2025, 13:46:18 pm »
Jyrki
8.88 & 251
« Reply #10 on: July 25, 2025, 13:47:29 pm »
Jyrki
8.88 & 251
« Reply #11 on: July 25, 2025, 13:48:45 pm »
Jyrki
8.88 & 251
« Reply #12 on: August 05, 2025, 15:29:45 pm »
Some details: working headlights, plastic ultra-lightweight lenses, removable tow-hook, plugs for defa oil-heater and Ctek-charger:
Jyrki
8.88 & 251
« Reply #13 on: October 22, 2025, 15:00:03 pm »
Some details edited in the ad above.
Price drop 67.500€
Jyrki
8.88 & 251
« Reply #14 on: March 04, 2026, 09:38:35 am »
Race season 2026 is soon here. My turnkey 8-sec full-steel cal-looker is still for sale. Willing to take offers. no low-balls.
