September 22, 2026, 22:17:30 pm
| | |-+  1776 Weapon...Go Go Go!
Pages: 1 [2] Print
Author Topic: 1776 Weapon...Go Go Go!  (Read 29725 times)
« Reply #30 on: December 12, 2007, 17:32:45 pm »
we need a new thread for your street killer, Derek....
headsheadsheadsheadsheadsheadsheadsheadsheadsheadsheadsheadsheadsheadsheadsheadsheadsheadsheads.... Grin
The Ideaman
« Reply #31 on: December 13, 2007, 01:59:41 am »
You guys are sissies! Tongue
94x64 with custom (2 ring?) pistons
A set of Heads Up! welded heads and intakes, narrow stems and possibly LS1 springs.
Titanium valves and rods.
Crank would be a Bryant or Moldex with wing shaped counterweights.
roller cam with net lift over .800 @ the valve.
Vacuum pump
engine would have to be able to spin 10k.
4.86r/p and close gears (and a couple extra in the trailer for when they let go)in a 67 sedan for ss/fs
It is the soldier,
Who salutes the flag,
Who serves beneath the flag,
« Reply #32 on: December 13, 2007, 02:00:50 am »
they had all that stuff in the 80's?
The Ideaman
« Reply #33 on: December 13, 2007, 03:10:49 am »
Okay, everything but the vacuum pump.  Instead, it will have an oil accumulator and Vasco triples.
Should be pretty streetable with the low gears.
« Last Edit: December 13, 2007, 03:48:44 am by The Ideaman » Logged
It is the soldier,
ugly duckling
« Reply #34 on: December 15, 2007, 06:11:23 am »
here lets put these tolit holes on your littel toy that will bring your rpm up to buzzzzz! saw range!.i had them on a 1805 65X94 the thing started to make steam at 7 and sounde real happy up at 10.000 but needed more carb. UD
« Last Edit: December 15, 2007, 06:22:18 am by ugly duckling » Logged
Bewitched666
Bewitched
« Reply #35 on: December 15, 2007, 12:05:10 pm »
Damn,what kinda heads are those,self made or some oldhead unknown to me? Grin
Fast vw beetle's rule
redbluebug
« Reply #36 on: December 15, 2007, 21:19:45 pm »
Forget the egg fitting thru the port, you could suck the whole chicken thru those ports Shocked  Nice work Wink
The Ideaman
« Reply #37 on: December 16, 2007, 03:26:58 am »
I bet that thing idled at 2k, at least.  Heard stories of Comp Eliminator motors with 4" bores and 2.7" strokes that won't take a load on a dyno under 5-6k.
It is the soldier,
stealth67vw
« Reply #38 on: December 16, 2007, 06:11:07 am »
Probably ran like a pre hippy/earth first super flusher toilet huh Jeff?
John Bates
JB Machining Services
12.34 @ 108 mph 1/4
7.76 @ 89mph 1/8
« Reply #39 on: December 16, 2007, 07:08:42 am »
somehow i have clear memorypictures of that description...  Roll Eyes
« Reply #40 on: December 25, 2007, 04:26:28 am »
Here's what my 1776cc looked like in the early 80s.
Cima 90.5 with total seal rings
Heads by ported The Head Shop. Cant's remember valve sizes. Berg Shafts and valve adjusters.
Berg Counteweighted Crank.
Carillo Rods (Stock Length)
14 lb flywheel
VZ35 cam
H Case with all the typical mods done by rimco
48IDAs on Skat-Trak talls
1 3/8" merged 4 Tuned header
Offset cooler
Bosch 010
Red Coil
Worm
Whose stupid idea was that?
« Reply #41 on: January 23, 2008, 22:26:45 pm »
Hmmmm, I went a bit different way trying to fool the "weber" crowd.
90.5 Cimas
Berg 69mm crank
Polished rods
balanced toe to toe.
heads by DOUG Berg
massive non welded ports
38X42
matched manifolds with..... Tah Dah... Kadrons!
Yes, kadrons.
Doug tore them apart and jetted and gutted them just so.
This motor in my 63' vert blazed!
I however did not build this motor myself I bought it.  I bought it from a local tranny builder that was low on funds named Dave Foltz.  Is he still around?
This was the fastest Kadron motor... OMG it was fun to have the guys lift my decklid and immediately snap to say "I'll race yah yeah!"  Then weber boy would be sad.  granted I was not running against 48's.  But the 1776's with 42's and 44's, I was in.  Now Dyno Don and I had some days discussing whose Kadron motor was faster....  My vert or his Notch.
Worm
 "Pretending to know everything closes the door on whats really there"
Pages: 1 [2] Print
