September 22, 2026, 09:51:38 am
| | |-+  67 axle length and Ercos
Author Topic: 67 axle length and Ercos  (Read 16743 times)
« on: January 16, 2008, 16:57:41 pm »
Hi guys,
Would 6" Ercos (3,5" + 2,5") and 205 MH Dots fit on a 67 with stock length axles?
Thanks,
Best rgs
deano
« Reply #1 on: January 16, 2008, 17:04:38 pm »
I don't think so. I am affraid that the edge of the rim would be outside the edge of the fender... Sarge?
Anglia Obsolete Guru
'67 Heaven
« Reply #2 on: January 16, 2008, 21:21:40 pm »
Thanks, let`s see what Sarge says   Smiley
deano
« Reply #3 on: January 17, 2008, 01:13:51 am »
You "might" get away with it using stock '67 drums, but I seriously don't think so with disc brakes or Type 3 drums.
'67 Heaven
« Reply #4 on: January 17, 2008, 05:14:15 am »
I concur.
« Reply #5 on: January 17, 2008, 09:02:01 am »
Thanks guys,
Original drum brakes will be used.
Best rgs
BB
Bewitched666
Bewitched
« Reply #6 on: January 17, 2008, 09:59:26 am »
Like deano said i think they will stick out,3.5 inch is alot Cool
Fast vw beetle's rule
« Reply #7 on: January 17, 2008, 10:08:43 am »
It is 3.5 inch inset and 2 1/2 inch out.... Look at this picture, this is a short axle car with the same rims but with a little narrower tire - don`t you think there is room (and will look even better) with the wheel 1" further out?
Bewitched666
Bewitched
« Reply #8 on: January 17, 2008, 10:11:40 am »
The 205 tire may rub then Cool
« Reply #9 on: January 17, 2008, 17:54:30 pm »
I think that red car looks just about right. Long axles will move the tire out about 1 1/8" on each side I believe.
« Reply #10 on: January 17, 2008, 18:02:50 pm »
Zach, that red car used to belong to Trond. Personally I think it is to much air between fender and tire but it could be that the angle is fooling me.
« Reply #11 on: January 17, 2008, 23:42:04 pm »
THIS is the look I`m after. 67 with original axles, 6" Ercos and 205`s;
Trond Dahl
« Reply #12 on: January 17, 2008, 23:58:20 pm »
Looks much better in the last picture... I agree
Race car 9.49/236kmt@SCC 2017
« Reply #13 on: January 18, 2008, 00:01:49 am »
I think that's because it is lower...
The Burnout King
« Reply #14 on: January 19, 2008, 02:33:29 am »
Just sold a 67 with the same wheels and yes they stick out, I can email you pics if you want......
Or just ask Peter, he owns it now....
go BIG or go HOME
www.theburnoutking.com
The Burnout King
« Reply #15 on: January 19, 2008, 02:37:39 am »
Found a Pic.....Kinda Hard to see but you get the point....
go BIG or go HOME
« Reply #16 on: January 19, 2008, 09:23:40 am »
Excellent info Dom - If you do have a pic of it showing how far out they are it would be highly appreciated.
Thanks,
Best rgs
BB
« Reply #17 on: January 19, 2008, 21:22:16 pm »
Its not hard to switch to short axles! Just do it! Wink
« Reply #18 on: January 19, 2008, 21:24:17 pm »
How does it work?
Do you have to tear apart the gearbox or not?
« Reply #19 on: January 19, 2008, 22:11:18 pm »
How does it work?
It could be done in the car, but I wouldnt recommend it unless you're a glutton for punishment Wink You need short axles and tubes with short end castings. Dont forget the proper bearing cap. When you take it apart you will see how its not all that difficult, its pretty much "out with the old, and in with the new". If the axles are used, make sure they go back on the same side they were previously used on- Ive heard that they take a "set". When you bolt the retainers back up to the trans, you have to make sure that the axle moves around with just a slight drag, not loosey goosey, not too tight. You adjust it by adding/removing gaskets. Its pretty simple really!
beetletom
« Reply #20 on: January 20, 2008, 00:08:34 am »
arn't 67 axles inbetween short and long axle lengh?
or do they run long rear axles?
deano
« Reply #21 on: January 20, 2008, 00:53:21 am »
There are short-short, long-short, and long-long axles. '67 are long-short. The second portion of that description is the length of the splines...
'67 Heaven
