September 01, 2026, 10:36:17 am
Latest Member: Lotus67
| | |-+  Lube-a-lobe
Author Topic: Lube-a-lobe  (Read 14006 times)
« on: September 14, 2006, 13:19:22 pm »
Are these still good shit, or are they the same as the rest?
SilverPig
Alles klar?
« Reply #1 on: September 14, 2006, 13:58:55 pm »
Well...they lube the lobe...which is a good thing. Wink
Say hello to my little friend!
« Reply #2 on: September 14, 2006, 16:05:50 pm »
I personally didnt have any problems with the lube a lobe lifters,but the new 75g lube a lobes seem even better,cheers richie,uk
« Reply #3 on: February 18, 2007, 20:32:48 pm »
I did 2 engine tear offs with them and they looked good after inspection. No "star-like "scratches to the outside. Like a Fúp lifter looks...
Jordy/DVK
« Reply #4 on: February 21, 2007, 13:05:20 pm »
 Does anyone have a list of which lifters to choose/avoid? (and the weights, if known...)
  "The Full-Throttle Cruisers"
« Reply #5 on: February 21, 2007, 18:36:38 pm »
there are not that many bad lifters around, but there is a certain lot of people that reckon SCAT lifters suck, though others have run them without any issues.
mahle and febi lifters are fine, lube-a-lobe SCATs are better than normal SCAT.
just pay attention that web cams are more picky on lifters than engle cams.
jordy, hit me up on your ideas!  Wink
« Reply #6 on: February 22, 2007, 00:35:48 am »
There are even those who dont blaim the lifters at all, and they use whatever... and never has a problem.
If you are going to install whatever springs at whatever springpressure combined with a real streetable cam, you need the best lifters money can buy. I would then go ceramic.
« Reply #7 on: February 22, 2007, 06:58:18 am »
But this lubing does not change the material of the lifter !!!!
« Reply #8 on: February 22, 2007, 07:03:01 am »
All cams have nearly the same material and hardening. We never had problems with any cam , web, pauter and engle. Only the lifters have been the problem , exept our german steel !
« Reply #9 on: February 22, 2007, 09:55:44 am »
Udo, lifters are suposed to be harder than the cam right?
« Reply #10 on: February 22, 2007, 12:46:12 pm »
I never tested a cams hardness . A lifter must have the right material and hardness. I never had a cam problem with my lifters , but with all others you can see first pitting on the lifter and after that the cam goes flat . EVERY engine i get with aftermaket lifters have pittings on the lifter or both , flat cam and, up to broken lifters . It depends on how long the engine was running.
