September 22, 2026, 04:40:10 am
| | |-+  rear shock absorbers strap limitation
Author Topic: rear shock absorbers strap limitation  (Read 9894 times)
wolfswest
« on: February 14, 2008, 15:18:30 pm »
Somebody advised me to install some sort of straps on the rear-shock absorbers to prevent negative camber on the rear wheels when braking or when you stop pushing the right pedal…  Cheesy
Does somebody has experience with these tools on a street car, positive or negative remarks?
If you don’t know what I’m talking about, here is a picture a “stole” from a dutch forum.  Thx to MartijnC!
Dem
« Last Edit: February 14, 2008, 15:39:05 pm by wolfswest » Logged
Jason Foster
7.69 87mph 12.35 106 mph
« Reply #1 on: February 15, 2008, 06:45:28 am »
  Hello,
 Firstly the straps limit positive camber when you lift on the big end the rear end wants to unload causing the contact patch between tire and road to become smaller this can cause loss of control and often times flips. Most run 12" or 13" straps. Hope this helps.
lawrence
« Reply #2 on: February 15, 2008, 07:06:56 am »
I have been thinking about purchasing a camber compensator or limit straps for my beetle. How do these straps react in turns and normal driving? Who has experience with a camber compensator?? Thanks
"Happiness is a Hot VW!"
wolfswest
« Reply #3 on: February 15, 2008, 08:48:21 am »
  Hello,
That is what I mean, but difficult to explain in an other language...  But what happens when you brake very hard?
Frank LUX
Back...Soon...hopefully!!!
« Reply #4 on: February 15, 2008, 17:47:58 pm »
  Hello,
On the Strip, with Slicks, braking hard, you will most surely end up on the Roof... Wink
Frank
jr59
« Reply #5 on: February 15, 2008, 17:53:10 pm »
  Hello,
Even if I think that 13" will be OK,Well you first have to check with a jack when your car begin to get a positiv camber then you can determine your lenght!
Using flop stop is also a good and simple solution
wolfswest
« Reply #6 on: February 19, 2008, 11:40:13 am »
  Hello,
Can somebody give me more info on the "flop stops"  or other solutions?  I want to make my car more safe when I loose my foot of the trottle @ high speeds...
« Reply #7 on: February 19, 2008, 11:46:30 am »
I used the Bugpack "flop stops" on my race car - just a simple bracket that bolts to the bottom oedge of the springplate. Purpose is, as said above, to stop the wheels tucking under when coming off the throttle. I made som enquiries about using them on the street and was told it wasn't a good idea as for street driving you are effectively limiting the suspension in one direction and over bumps, potholes etc the car ends up dropping into holes rather than the suspension doing its job. The person said that it was the most scared they had been in their car! Shocked
wolfswest
« Reply #8 on: February 19, 2008, 16:08:10 pm »
OK, not a good idea to use these things on a streetcar...  Undecided  mmm
« Reply #9 on: February 19, 2008, 16:47:24 pm »
If you use them on the strip they're a really good idea, just take them off before you drive home! If you've got the rear wheels off for changing slicks back to street tyres, you could undo them then!  Wink
Jason Foster
« Reply #10 on: February 20, 2008, 07:14:02 am »
  I run 13" straps on my car at all times on the street or strip. It doesn't completely take away down travel just lilmits it hence the name limiting straps. A little positive camber is ok just not the excessive amounts you get with stock suspension. My oppinion. If I jack my car off the ground the spring plate is a little over 1/4" from the perch.
        Jason Foster
wolfswest
« Reply #11 on: February 20, 2008, 08:59:36 am »
        Jason Foster
jason, if I understand you correctly you made your straps a little bit longer then the shocks when they are under the car...  I'm a correct?
Jason Foster
« Reply #12 on: February 21, 2008, 01:16:33 am »
that is correct I have a small amount of uptravel if the car is lifted with a jack.
