October 13, 2026, 07:37:26 am
Oberg or Fram HP1
Topic: Oberg or Fram HP1 (Read 54160 times)
John Maher
Re: Oberg or Fram HP1
Reply #30 on:
December 08, 2008, 21:47:40 pm »
Canton filters down to 8 microns and flows so well there's no need for a bypass valve
That's what I call a PROPER filter
Filter element isn't re-usable but replacements are reasonably priced
Gets my vote
John Maher
Reply #31 on:
December 08, 2008, 21:55:02 pm »
I'm surprised how unknown the Canton is in the VW drag scene.
Among the circle track guys, they're like a pre-requisite.
Reply #32 on:
December 08, 2008, 22:48:51 pm »
Some good info on this thread. Thanks to all involved
http://www.cmfilters.com/
Cheesepanzer
Reply #33 on:
December 09, 2008, 04:19:56 am »
Thanks for the tips on the Canton filter.
What's the preferred filter set-up - the remote mount like the #1281 or the spin-on filter like the #1284?
I found this with some pricing and replacement filter info:
http://s2.pegasusautoracing.com/2008/069.pdf
63 Type 2 Single Cab
Cornpanzers
John Maher
Reply #34 on:
December 09, 2008, 10:25:28 am »
Quote from: WardVWRacer on December 09, 2008, 04:19:56 am
If you've already plumbed a conventional style filter, #1284 is a straight swap - screws straight in (3/4 x 16)
Starting from scratch you have the option...
#1281 saves having to buy a regular oil filter mount but you'll need to add in a couple of hose adapters eg #12 to #8
It's a little more work to access the filter element - easiest to remove the unit from the car
John Maher
pupjoint
Reply #35 on:
December 09, 2008, 12:42:28 pm »
http://www.cantonracingproducts.com/cgi-bin/commerce.cgi?preadd=action&key=25-262
25-262 - CM -15 BILLET SPIN-ON FILTER 3/4-16 (25-262)
The 4-1/4" tall BILLET spin-on filter has 3/4"-16 thread and a standard o-ring. It accepts CM’s -15 2-5/8" high synthetic fiber depth filter element which flows 15 GPM of hot engine oil with no loss of pressure. It has a 3" dia. heavy duty light weight billet aluminum housing and a blue anodized finish.
Our Price: $99.60
seems to be the same as John described, p/n 1284, but this has a diff part number.
Prowagen
Reply #36 on:
December 09, 2008, 15:28:27 pm »
Quote from: tikimadness on December 08, 2008, 20:20:57 pm
I allways use MAN filters oil stays clear very long.
Michael
Good filters I think VW even recomment MANN filters.
John I understand what your saying about the pitfalls of the oberg and other cleanable filters that bypass under high pressure, but disposable canister filters do this too!
Not sure what F1 teams use but I am sure its not a HP1 or similar! My main point here is for people to stay clear of HP1's they are not good!
Now the Canton that looks like a nice bit of kit.
Rob.
John Maher
Reply #37 on:
December 09, 2008, 17:27:48 pm »
Quote from: Prowagen on December 09, 2008, 15:28:27 pm
Agree on the HP1 - they
used
to be a good quality filter but like so many things nowadays, you can't rely on a part to have the same quality several years on just because it carries the same name.
Suppliers and manufacturers get swallowed up by large companies. Corners are cut to lower costs. They rely on 'branding' to push profits up, while quality goes down.
Only way they'll learn the error of their ways is if the consumer hits them where it hurts i.e. stop buying their piss poor products and spend your money with the good guys
I doubt F1 has used a paper element filter (let alone a washable strainer!) for years
http://www.magnom.com/index.php/tech/howitworks/
Removes particles smaller than 1 micron!
John Maher
Reply #38 on:
December 13, 2008, 20:10:39 pm »
Quote from: Jim Ratto on December 08, 2008, 21:55:02 pm
What more can i say ! I'm using the Canton spin-on (with removable bottom plate) for years. No more
System One or Fram for me. Although i use the System One as a pre-filter for break-ins.
PS. Canton uses the same filtering medium for their fuel filters as well....
Last Edit: December 13, 2008, 20:12:36 pm by FDK/Hurry
Reply #39 on:
December 15, 2008, 21:09:53 pm »
Quote from: John Maher on December 09, 2008, 17:27:48 pm
Thanks for the Link !
Reply #40 on:
December 15, 2008, 21:23:48 pm »
Quote from: John Maher on December 09, 2008, 10:25:28 am
If you just would like to swap from HP1 ( 3/4 - 16) there's the Canton # 25-462.
Unfortunately they do not make the removable 4 bolt bottom - filter anymore.
Reply #41 on:
November 20, 2011, 18:38:13 pm »
The Canton oil-filter with four bolts at the bottom is back again.
Last Edit: November 30, 2011, 12:49:04 pm by Harry/FDK
Reply #42 on:
November 21, 2011, 09:59:11 am »
Where did you order yours Harry?
directly from the US?
Reply #43 on:
November 21, 2011, 10:00:15 am »
Yep, no problems with shipping either.
pupjoint
Reply #44 on:
November 21, 2011, 15:03:58 pm »
Harry, which vendor did you use? i have the System 1 now, just remove and bolt on?
Martin
Cash Converter....
Reply #45 on:
November 21, 2011, 16:33:30 pm »
I have used HP1 and System 1
I have now changed to Canton, I have had to turn down the Preshure on the pump as the prshure drop accross the media is much less. Its also a lot smaller than the system1 set up.
You have to bare in mind im using a Peterson V8 style of pump on my car
as for looking at the filter, once its been in the oil for a few weeks you can pull the filter apart and roll out the media, its amazing what it catches!
Canton all the way for me now, can't recomend them enough (and there cheeper than system 1's)
Martin
www.taylormachine.co.uk
OFF/500
bilboa2
Reply #46 on:
November 21, 2011, 21:03:52 pm »
canton mecca on street car.. Cause jim rattto said so....A little painting done to matching color of inset brm spoke area. Hangs a little low but not dangerous. My Baja has k and n spin on. Have dealt with many oberg motors and like to be able open it and see what's going on, rod brng, shop rag lint, rtv.. messy deal though, depends where you mount it, sometimes can unbolt then let it hang into a drain pan . bill
kingsburgphil
Reply #47 on:
November 22, 2011, 07:11:44 am »
As usual nicely done. Any chance on getting Clyde to weld up a couple of sumps like yours?
karl h
Reply #48 on:
November 22, 2011, 07:14:45 am »
i use system one for break in (the same one on every engine i build), after checking i use a paper filter afterwards - with the berg relief cover i cant blow it
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
bilboa2
Reply #49 on:
November 22, 2011, 16:04:49 pm »
Phil, that would be dougs work not clyde. Doug is so meticulous in his work. I am so fortunate to have him close by. Sump holds alot of oil, it gets VERY warm here in nevada , no over heating issues. I believe it's design helps, along with deck lid propped, thermostat controlled fan, 9.2 comp. etc . Maybe if enough people requested ?
Reply #50 on:
November 22, 2011, 16:29:38 pm »
Quote from: pupjoint on November 21, 2011, 15:03:58 pm
Directly from Canton / Mecca.
Just remove and bolt on.
-Alex-
Reply #51 on:
November 23, 2011, 22:12:38 pm »
How about CSP oilfilter? Is it bad as rest of billet washable filters? I have one, but i havent used it.
http://www.machine7.com/section.php?xSec=102
While Cal-Look stands still, looking backwards for inspiration, German Look keeps pushing boundaries further forward
Reply #52 on:
November 24, 2011, 14:16:07 pm »
You just can't beat 8 Micron filtration (without by-pass). My 2 cts.
Hotrodvw
Reply #53 on:
November 25, 2011, 18:32:12 pm »
I've been using the WIX 51515R filter. This website led me to it, along with the recommendation of others as well. When the filter is cut apart, you can see how many paper pleats are used......more pleats = more surface area = better filtration. Also, some filters, such as the HP! from Fram, use a plastic bypass valve. Plastic gets hard and brittle with heat. The last thing you want is a chunk of plastic in your motor. The Wix filter's bypass is made of rubber, which will hold up to heat better.
Here's some good reading for you guys.
http://minimopar.knizefamily.net/oilfilters/reference.html#wix
Hose & Fittings
'67 Sunroof
www.ultimateaircooled.com
Reply #54 on:
November 30, 2011, 12:36:19 pm »
Quote from: Harry/FDK on November 20, 2011, 18:38:13 pm
The Canton oil-filter with four bolts at the bottom is back again (thus making life easy): 25-414 - CM 6.25" BILLET SPIN-ON FILTER 1" -12 THREAD 2 5/8 O-RING (25-414)
Update for my stupid mistake: The correct part# must be 25-464, it has 3/4 x 16 thread and the endcap is removable with 4 bolts.
My apologies for the error. (Thanks PUPJOINT).
25-464 - CM 6.25" BILLET SPIN-ON FILTER 3/4" -16 THREAD 2 5/8 O-RING (25-464)
NEW!
This 6.25" tall billet spin-on filter has 3/4"-16 threads and a standard size o-ring. Like all CM filters it features a billet aluminum body built for strength and durability for a lifetime of use. Heat sink ribs add to filter's functionality and aggressive aesthetic. The filters bottom cap is easily removed with four bolts for filter element inspection and replacement. A CM 4-5/8" tall synthetic fiber filter element which flows 45 GPM of hot engine oil with no loss of pressure and filters down to 8 microns comes preinstalled
Last Edit: November 30, 2011, 21:12:50 pm by Harry/FDK
glenn
Reply #55 on:
November 30, 2011, 14:25:58 pm »
Quote from: Harry/FDK on November 24, 2011, 14:16:07 pm
Been using one for 8 years now and it saved my engine when a valve spring broke and the pushrod chewed up the aluminum Pauter rocker and dumped shavings in the oil. Nothing got past the filter and after a few kerosene flushes the engine was fine.
Glenn
74 Beetle Specs
74 Beetle Restoration
2180cc Engine
www.DasVolks.com
Long Island's Aircooled Club
Reply #56 on:
November 30, 2011, 16:13:51 pm »
Like i wrote earlier: Canton uses the same filter-medium for their fuel filters. You might change the o-ring for Viton...
-Alex-
Reply #57 on:
December 01, 2011, 21:21:19 pm »
Ok, time to change filter
Information is correct about what CM filter fits to vw filter mounts?
Last Edit: December 01, 2011, 21:28:15 pm by -Alex-
Reply #58 on:
December 02, 2011, 18:08:18 pm »
I like the CSP,Jay Cee and Geers filter. Easy to clean and works nice-
www.Udobeckertuning.de
Reply #59 on:
December 02, 2011, 18:09:26 pm »
Quote from: bilboa2 on November 21, 2011, 21:03:52 pm
This is much too long if you want to go racing .
