October 14, 2026, 01:05:55 am
| | |-+  Carrillo rods
Author Topic: Carrillo rods  (Read 6205 times)
fish
« on: February 19, 2008, 05:14:24 am »
Hey guys and gals, just registered on this forum and this is my first post. I am trying to build an engine using Carrillo 5.7" rods without having to cut tin off this very clean 66 deluxe, any ideas?
It will be a street and strip maschine.
« Reply #1 on: February 19, 2008, 18:09:32 pm »
Use a 50mm stroke  Cheesy
Roman
« Reply #2 on: February 19, 2008, 21:04:35 pm »
Buy pistons from JPM. I ran his pistons in my 2387 with 86 mm stroke and 5.7" Carrillos and it was narrower than stock.
« Reply #3 on: February 19, 2008, 21:09:46 pm »
That is the only way , you can get JE's down to 24 mm compression height . But only as a special order .
fish
« Reply #4 on: February 19, 2008, 23:12:41 pm »
Thanks for the info guys, i need to check if they are VW or Chev journal. A mate of mine used them with 78mm crank to run in the 2L class.
I also found Super Squish pistons from ACNet that might work.
