June 25, 2026, 18:27:55 pm
352204 Posts in 28920 Topics by 6920 Members
Latest Member: chris41
| | |-+  Post Pics from racing engines
Pages: 1 ... 9 10 [11] 12 13 14 Print
Author Topic: Post Pics from racing engines  (Read 428622 times)
Mirco Jufer
« Reply #300 on: September 28, 2011, 17:37:16 pm »
This is my Racing Enginge...
Half Mouse... :-)
2180ccm and made a 11.40 at DDD this Year,with homeselfported Heads...
« Reply #301 on: October 01, 2011, 05:58:57 am »
Well -- the 2919 is running -- having trouble with the EFI box or I'm having trouble with me LOL -- -- Click the picture
« Last Edit: October 01, 2011, 06:01:16 am by Fiatdude » Logged
« Reply #302 on: October 01, 2011, 07:56:25 am »
Half Mouse... :-)
love the pic,
Could you give me more details on car and motor please?
Mirco Jufer
« Reply #303 on: October 02, 2011, 17:34:07 pm »
Thanks for the nice words!
The Engine is a 2180ccm with G.M.E Heads with 42mm inlet and 38mm Outletvalves.I ported the Heads bymy self,also the Big Beef Manifolds.
The Cam is a Fk87.Scat Flangecrank and EMPI H-Connecting Rods.
The Lifters are from Udo Becker 58g.
In ther Car i put a lot of work and Money since i buy them in Texas in 2006.Then it looks like a Roadworks.
The Flipfront and the Rear Fenders are Fiberglass,the rest is still Metal but lightened to the maximum.
Now it is the fastest Bug in Switzerland Wink In the 80is the Car was a Baja Bug i hear from the last Owner Grin
For next Season i will change the Pistons to a lightened One and hope i can go closer to the 10" with this small Engine. I rev it only to 7400!
« Reply #304 on: October 02, 2011, 19:59:16 pm »
Thanks for the info,
I'm assuming the engine is 82x92mm?
I'm building a 2110 and am at the point of trying to select heads. What are G.M.E heads?
Mirco Jufer
« Reply #305 on: October 03, 2011, 11:47:47 am »
Hi Lee
I guess they are Japanese Heads from the 80. or 90i.
Steve Becher run they also in hes sleeper..
Yes thats right it is 82mm Stroke and 92mm Bore,i orient me at the Engines in the 70is,then 2180 was big  Smiley
But Yesterday it was a Mouse...
Next Year i will come to you on the Ile to run at Shakespere,then you can watch the Engine at work  Cheesy
Try to go faster in the "NoSuperflowheadsclass"
Regards
Mirco Jufer
« Reply #306 on: October 03, 2011, 11:51:52 am »
Front End
brezel
« Reply #307 on: October 06, 2011, 09:52:53 am »
1835 cc
60 ft     1.906        1.797         1.843          1.881
1/8      8.674          8.550        8.552          8.575
1/4     13.758      13.575        13.532          13.554
13.331 June 2012 Bitburg / 13 B Rotary N/A
12.188 Sept 2012 Bitburg / 13 B Rotary N/A
11.599 Sept 2013 Bitburg / 13 B Bridge Port N/A
« Reply #308 on: October 06, 2011, 10:12:07 am »
1835 cc
Nice,
Get that 60ft down and you will see big improvements on your ET.
BB
brezel
« Reply #309 on: October 06, 2011, 17:53:18 pm »
i  would like to do  Huh
in winter i make 1:1.25 rocker arms or better a FK 87 with 1:1.4 rockers ?
more compression now 10.5:1 better 11.5:1
and a rev limiter for better starts with a kpl. MSD Ignition AL 6 Digital ?
I hope for more rpm
now max 7000 and i shift by 7000  Shocked   all four gears max rpm on the 1/4 mile  Huh
its only an 1835 cc  Cheesy
« Last Edit: January 09, 2012, 09:27:26 am by brezel » Logged
Type1/DVK
« Reply #310 on: October 06, 2011, 20:23:48 pm »
clubmate had some problems with that type of ignition (the 123 model) above 6500-7000.
Nice times!! i had a 14.7 with 1776, do you have more specs?
brezel
« Reply #311 on: October 06, 2011, 20:34:50 pm »
http://cal-look.no/lounge/index.php/topic,9877.30.html    Cheesy Cheesy Cheesy Cheesy Cheesy
Mirco Jufer
« Reply #312 on: October 08, 2011, 07:32:11 am »
I rev it also only to 7200!
And your Engine looks bigger then it is Wink Wink
« Reply #313 on: October 08, 2011, 08:11:43 am »
Yes and that's exactly why you should focus on improving your 60ft. You do not have the power to make up for a poor start.
lowfastbus
WUNDERWAFFE
« Reply #314 on: October 08, 2011, 09:50:15 am »
It's the same problem that I have, done 13.07s at bitburg last weeks with an 1.94 64ft time.
Thats actually the best time the car ever did on a 60ft.
Engine is a 2054cc, light car, normal tires and stock gearbox.
What would you guys suggest to get lower 60ft times...
http://dragvws.skynetblogs.be
WUNDERWAFFE
The Knuckle Buster
« Reply #315 on: October 08, 2011, 11:01:36 am »
You have a low 12 sec car if you can improve your 60ft. Find out why you have such a poor start and fix it  Smiley DOT tires is a good start if you have problems with wheelspin. More launch rpm, rear suspension set up etc etc. The best 60ft I have seen with ordinary, radial street tires 205/70-15 is 1.61. This was on a very sticky track and after a good burnout. He basically gave it everything it got and if I remember correctly he launched with  7500 rpms. He used original torsion springs, bus snubbers an adjustable Konis to prevent the car from bouncing up.
A very aggressive clutch will also hurt your 60ft.
Mind you that a good 60ft goes for all racers. A poor start and you can just as well abort the rest of the run.
« Reply #316 on: October 08, 2011, 11:51:57 am »
DOT tires , but you need a stronger gearbox with those tires
« Reply #317 on: October 08, 2011, 12:50:17 pm »
If you preload your car really well I do believe you can make a original gearbox last at least a couple of good starts. Preload is important.
vintagewagenwerks
« Reply #318 on: October 14, 2011, 20:58:24 pm »
My ready modified engine for race season 2012 . Cool
Itīs better to burn out than to fade away.
dangerous
« Reply #319 on: October 16, 2011, 23:19:55 pm »
Gotta separate those HT wires! Cry
vintagewagenwerks
« Reply #320 on: October 17, 2011, 05:16:54 am »
Should i take the Coilcable away from the fuel line or what do youe mean.Or all Ignition cables without straping? Huh ??
vintagewagenwerks
« Reply #321 on: October 17, 2011, 16:19:39 pm »
ok ,hopefully i undestood your advice right.I seperated all single cables without crossing and one diameter of the cable in space. Tongue
dangerous
« Reply #322 on: October 17, 2011, 23:01:19 pm »
very good!
« Reply #323 on: October 18, 2011, 01:20:07 am »
Functionally better, esthetically better.  Good advice Dangerous and well executed Vintageworks
vintagewagenwerks
« Reply #324 on: October 18, 2011, 05:03:21 am »
I admit the the car drives better with seperated cables ,the acceleration is smoother than before and the idle is not so rough instead of befor by an cold engine.Thanks for your advise.
Shag55
Shag Leone, SL-1racing
« Reply #325 on: October 18, 2011, 21:15:39 pm »
Here is my 2165cc turbo street motor for my 55 rag. So far I made 288whp and 282tq @15# on pump gas. More to come with better tune.
Shag55.sl1racing@gmail.com
Facebook at SL 1 racing
Shag55
« Reply #326 on: October 18, 2011, 21:18:11 pm »
Here is in the car.
« Reply #327 on: October 18, 2011, 21:25:08 pm »
nice car but turbo is resto cal Huh.................... Roll Eyes Roll Eyes Roll Eyes
Martin Greaves
10.88@128.58
« Reply #328 on: October 18, 2011, 22:00:25 pm »
Oh wash your mouth out now Cheesy
« Reply #329 on: October 19, 2011, 11:49:53 am »
A turbo is too easy to get the power  Smiley
