September 22, 2026, 10:41:55 am
| | |-+  discussion of high perf engine posts here...
Pages: 1 [2] Print
Author Topic: discussion of high perf engine posts here...  (Read 46864 times)
« Reply #30 on: April 08, 2008, 02:37:16 am »
Its called Dykem (sp?)
stealth67vw
« Reply #31 on: April 08, 2008, 04:09:21 am »
To sliiiide our rambling back to topic, where do you buy the blue stuff that you use to make an imprint on where you´re going to take away material?
www.mcmaster.com
I order from them everyday for work. They have everything.
John Bates
JB Machining Services
12.34 @ 108 mph 1/4
7.76 @ 89mph 1/8
Bewitched666
Bewitched
« Reply #32 on: May 03, 2008, 13:47:33 pm »
Jim any news?? Grin
Fast vw beetle's rule
airstuff
« Reply #33 on: May 06, 2008, 11:50:11 am »
Hej guys,
Can anybody tell me,what is the advantage of running 5.5 VW rods in a 2276 in comparison to 5.4 rods Huh
airstuff
« Reply #34 on: May 07, 2008, 15:33:46 pm »
Maybe I would exchange the I-beams for the H beams
SlingShot
« Reply #35 on: May 08, 2008, 06:36:06 am »
Correct ! I use Dykem regularly. Don't take too many deep breaths when using it though, you will forget what your doing in a hurry  Wink
Will Race For Beer !!!
« Reply #36 on: May 13, 2008, 18:25:06 pm »
Jim any news?? Grin
Only news I really have is that time is very hard to find right now. Sheep's 88 x 74 motor is my main focus right now, he's been waiting for over a year. I did spend much of the weekend smoothing the inside of his case. Sorry no time for pictures and stories right now. I'll be back.........
« Last Edit: May 13, 2008, 18:30:38 pm by Jim Ratto » Logged
« Reply #37 on: May 14, 2008, 20:51:25 pm »
Hi guys,
Sheep's heads are nearly done, though they are going to be 40 x 35.5 now, not 35 x 32
My garage is still a mess, and in no shape for putting a nice new motor together. Next step will be getting the heads sent off for bigger seats and cut for dual springs and 88mm bore. While they're out, I will take some pics of other parts and tools and share on the other thread. Sorry for lagging.
« Reply #38 on: May 14, 2008, 21:27:50 pm »
Hi guys,
Slacker... it's not like you're working a full-time job, your wife's near the end of her pregnancy and you have to get things ready for the baby's room!  Grin Grin Grin
Bewitched666
Bewitched
« Reply #39 on: May 15, 2008, 07:19:41 am »
 Grin Grin Grin
« Reply #40 on: May 15, 2008, 08:10:27 am »
here is a question i have to ask:
what trans works for a 1776? i want to drive it, but it needs to be stronger. it is a 4.12 type3 case from a 66. so i was thinking of a late model swingaxle with shorter gears, but with super diff and sideplates...
just something that will keep it together and will drive me around.
Bewitched666
Bewitched
« Reply #41 on: May 15, 2008, 13:44:58 pm »
That will keep you going Nicolas.You can use those urethane mounts for more riggedty and a tractionbar also. Cool
Jesse/DVK
'64 2176cc
« Reply #42 on: July 28, 2008, 11:13:21 am »
Any news yet? Love to see some posts on engine building.
« Reply #43 on: July 28, 2008, 22:41:45 pm »
sorry.... too much to do and no time right now.... maybe if you have specific questions? I can try to help.  Smiley
Jesse/DVK
'64 2176cc
« Reply #44 on: July 28, 2008, 23:10:23 pm »
Not really questions yet, but maybe you can tell me a little more on cam choice, if you compare camshafts with each other where to look for, what gives more bottom end torque, more rpm etc. So look at duration, valve lift, heads, carbs etc.
And one other question, when to use chromoly head studs instead of OEM VW?
« Reply #45 on: July 28, 2008, 23:27:54 pm »
this thread was supposed to be an assembly technique guide more than a "what parts to use" guide. Sorry.
Camshafts can be tricky and really, deserve their own thread.... let's start one....  Wink
Mike Lawless
« Reply #46 on: July 29, 2008, 05:23:37 am »
Here's some stuff one might find helpful. It was my first experience with CBs raised roof case when it first came out.
http://home.comcast.net/~mlawless29/NewMotor.htm
2006 PRA Super Gas Champion
2002-2003 DRKC Champion
http://www.lawlessdesigns.com
« Reply #47 on: July 29, 2008, 05:27:32 am »
got word that sheep's squared 40 x 35.5's are almost done.... then we can get back on topic with his 88 x 74
no fair taking up this post with my 2165 revamp
sorry for lagging
stealth67vw
« Reply #48 on: July 29, 2008, 05:35:04 am »
sorry for lagging
Friggin slackers  Roll Eyes Grin
John Bates
12.34 @ 108 mph 1/4
7.76 @ 89mph 1/8
John Rayburn
« Reply #49 on: July 29, 2008, 21:17:59 pm »
We interupt these commercials with...... The topic.
I also park at Nick's.
Jesse/DVK
'64 2176cc
« Reply #50 on: August 03, 2008, 18:14:44 pm »
Well Jiim do you have a list with all the tools you need to build an engine, to measure up parts etc. So I can start buying them to check out the parts when they arrive.
« Reply #51 on: August 04, 2008, 18:15:23 pm »
off the top of my head....  to complete the "build sheet" i will post later....
(depending on rod bolt type too)
full set 1/4" drive metric sockets/ratchet/extension
same but 3/8" deep and std metric
good dependable and calibrated 3/8" torque wrench (click) or beam indicator
small jeweler or hobby file set
1" travel dial indicator (in .001") and magnetic or snake base
set of feeler gauges
strong magnet
depth gauge measured in .001 or .0015"
vernier caliper/dial measured in .001"
bench mount valve spring tool
more to come....
Bewitched666
Bewitched
« Reply #52 on: August 06, 2008, 07:18:01 am »
Between all this Jim,how's the kiddo doing? Grin
airstuff
« Reply #53 on: August 06, 2008, 10:56:34 am »
Talkin about the torque wrench,
Do I need one whick has 10-150 foot pounds range,or do I need one with 120-960 inch per pounds
here is where I have some I might get:
http://www.mamotorworks.com/acvw?frame=1.3105
http://www.mamotorworks.com/acvw?frame=1.3101
Jesse/DVK
'64 2176cc
« Reply #54 on: February 20, 2009, 13:05:39 pm »
Hi Jim any news?
About the torquewrench. How NM should it have max? I don't need one for the flywheel cause i can borrow one from 200-500 nm from a friend.
Pages: 1 [2] Print
