September 23, 2026, 02:16:14 am
| |-+  For sale!
| | |-+  2442/Turbo Marty Staggs Motor
Author Topic: 2442/Turbo Marty Staggs Motor  (Read 5640 times)
71CALRIPPER
« on: April 09, 2008, 10:43:47 am »
I am selling because its to wild for what I need at the moment, the labor and parts are all paid for so you basically get a new engine built by the best at a reduced cost.
$14500
£ 7,361
Euro 9,220
Nok 73,337
Based on current Exchange rates
Which is a bargain you cant buy the parts for that money let alone the skill of such a builder.
2442 Turbo EFI Motor
CB Case
Comp E Heads 44x40
Crank 88mm Bugpack Flanged Crank + Matching Flywheel
Rods (Pauter 5.7 Chevy journal)
Cam (Staggs Racing custom grind)
Straight Cut cam gears (Competition Engineering)
Pushrods (Manton double taper)
Rockers (Pauter 1.3)
P&C's (94 wiseco w/Cima barrels)
Jaycee pushrod tubes
SLR Lifters
Custom dual disk clutch setup
Custom Revmaster oil pump
Cooling – Charging
DTM Fan setup
Fan (welded balanced)
Alternator kit
Turbo System Ceramic coated – Will get the full specs
Custom Ball Bearing Turbo
Custom header system (stainless steel)
Turbosmart wastegate
Turbosmart BOV
Turbosmart two stage boost controller
Intake manifolds with injector bungs
Fuel rails
Intake system
Custom oil lines with fittings
Modified Berg oil sump
65mm Billet Throttle Body
Misc bungs and fittings
There will obviously be a lot of little parts I haven’t listed but, you get the skill and knowledge of Marty Staggs to build you the Turbo motor above, its in the short block stage, so details could be changed to suit your needs, may be you don’t want to use Fuel injection.
Any other questions please contact myself or Marty
71CALRIPPER
« Reply #1 on: April 09, 2008, 21:53:17 pm »
Right if shipping is a problem i will help shipping to country of purchase Smiley
Rob
71CALRIPPER
« Reply #2 on: April 10, 2008, 12:54:19 pm »
Big motor + One of the best engine builders + ship to the country of choice
No takers Smiley
71CALRIPPER
« Reply #3 on: April 11, 2008, 17:55:32 pm »
Pending sale
67worshipper
« Reply #4 on: April 11, 2008, 18:00:57 pm »
who,s the lucky buyer Shocked
vw hot rod heaven
