June 10, 2026, 18:28:22 pm
352173 Posts in 28911 Topics by 6920 Members
Latest Member: chris41
| | |-+  front mounted oil coolers?
Pages: 1 ... 3 4 [5] 6 Print
Author Topic: front mounted oil coolers?  (Read 117427 times)
Rasser
« Reply #120 on: May 04, 2009, 16:37:32 pm »
Just to confirm with you Rasser, you found this oil cooler at your local Mercedes dealer or did you take it from a old car?
I like the small and neat size of it. I noticed Setrab is also selling some small ones.
Best rgs
BB
I bought it new from a "Cooler-shop" that sells replacement coolers for all manufactures.  If I remember right then it has 22x1,5 male fittings. If I were to do it again, then I would have these fittings cut off, and welded some alu. AN fittings on instead.
1955 type1
1966 type2 13w deluxe
« Reply #121 on: May 04, 2009, 17:14:29 pm »
That's a BEHR oil cooler off a W123 or W116 turbo diesel. Part # is 1161801765
Used on 300D and CD turbo W123 cars and 300SD W116 (and I think W126 too)
« Reply #122 on: May 04, 2009, 17:31:16 pm »
can you see the retail price as well, jim?
and rasser, how about those mounts?
Rasser
« Reply #123 on: May 04, 2009, 17:34:43 pm »
W123 rings a bell....  think that´s the one!
I made two brackets that attaches to the top of my gearbox mount and the cooler - Nothing fancy, but a nice and solid construction. It´s bolted in for easy removal.
You can actually see it if you look closer at the pictures  Wink
« Last Edit: May 04, 2009, 17:36:29 pm by Rasser » Logged
1955 type1
« Reply #124 on: May 04, 2009, 17:40:54 pm »
List price from MBZ is $570.00 USD
Rasser
« Reply #125 on: May 04, 2009, 17:43:01 pm »
Monkiboy: Forgot one thing - the cooler is mounted a bit higher than the front sparewheel housing (don´t know the correct word, but you know the front part of the body that carries the spare wheel. My guess is that the cooler is maybe 5cm higher than this location. Add to this that the spare wheel housing is IN FRONT of the front wheels, and the oilcooler is BETWEEN the rear wheels. No problems on an "ass up" cal-looker  Grin
1955 type1
Rasser
« Reply #126 on: May 04, 2009, 17:44:48 pm »
WOOOW, that´s insane.
This weekend I saw them at VW show, new in the box for 175euros - which is roughly what I payed a few years ago!
1955 type1
« Reply #127 on: May 04, 2009, 19:25:56 pm »
I pay something like 150€ for mine in a auto parts shop. That's not a genuine Mercedez Benz.
« Reply #128 on: May 04, 2009, 21:28:14 pm »
Hmmm interesting you mention that because I was just thinking about this again  Roll Eyes and the "Front valance" spare wheel area probably comes into this on VERY low cars  - I read somewhere in an hotrod magazine that NOTHING should ever be mounted below the "Scrub line" which is the imaginary rectangle/line drawn between the lowest point of the 4 road wheels,
Hmmmm another reason NOT to go too low at the front guys  Wink Smiley
Arnoud
« Reply #129 on: May 05, 2009, 06:29:04 am »
Rasser-were you at the Maikäfertreffen in Hannover last weekend?
« Reply #130 on: May 05, 2009, 07:18:42 am »
live report from the mercedes dealer here.
that cooler costs 221 EUR excluding VAT. more expensive than my cagero cooler, so i don't feel too bad after all  Wink
Rasser
« Reply #131 on: May 05, 2009, 08:14:12 am »
Yes. We had fun!
This was my first time at hannover, and we will be back next year. Mels diner were so cool;)
1955 type1
181
« Reply #132 on: May 05, 2009, 08:40:28 am »
this is mine alu oil cooler from CSP. Racimex brand.
I´m gonna put it near the gearbox behind the left swingaxle.
« Reply #133 on: May 05, 2009, 09:03:39 am »
nice! is that thermostat from csp as well? i still need one...
181
« Reply #134 on: May 05, 2009, 15:08:36 pm »
Yes the thermostat is from CSP too. it should be preset at 80°C and they have two versions - this one with push on 1/2" hose rigid fittings and a more expensive version with threaded holes for whatewer fittings you like..
Rasser
« Reply #135 on: May 05, 2009, 15:57:27 pm »
I´m running the thermostat with threaded holes from CSP. Works really well, and opens up at 80-85 degrees. But you have to make your own brackets for the threaded version - the other one has a bracket allready attached.
I have also used the one with push on ½" hose fittings on another engine, and it also worked good - actually I think they are both RACIMEX.
« Last Edit: May 05, 2009, 16:02:46 pm by Rasser » Logged
1955 type1
« Reply #136 on: May 05, 2009, 16:22:16 pm »
Banjos are a REAL bad idea for oil systems. Those look like awfully small fittings. Like 10mm?
tikimadness
« Reply #137 on: May 05, 2009, 17:38:12 pm »
You should use the largest 90 degree fittings you can fit because they are relatively small in diameter on the inside.
Michael
NIDGAFWYT
181
« Reply #138 on: May 05, 2009, 21:48:54 pm »
That´s what I specifically asked for before ordering and was told that no restriction. I inspected the banjo bolt inside out and they seem to be free flowing..anyway its diameter is not smaller then a diameter of oil passage in the case.
dirk zeyen
« Reply #139 on: May 06, 2009, 21:31:27 pm »
hello rasser
your oilcooler works good for sure, but what about a traffic holdup? i think if the car stand still and the engine is runing the exhaust will heat your oilcooler. i have the same oilcooler and did it the same way like you years ago (1998 or 1999), like every year i made my trip to budel and like every year we started to late it was a sunny and hot day. so like every year there was a big traffic holdup 1.5 ours for around 1 km and the engine was so hot....
my new setup:
hidden oilcooler and airboxes, now the oilcooler is away from the exhaust.
dirk
back again!!!
Rasser
« Reply #140 on: May 07, 2009, 22:20:31 pm »
hello rasser
my new setup:
dirk
Was yours also a type4 ?    - because the type4 engine cools so much better.
I have just been to 1. mai  Kaefer treffen in Hannover, and we ended up in a "traffic holdup"  just before the Elb tunnel in Hamburg for about ½-1 hour  - no problems (80-85 degree oil temp).
1955 type1
dirk zeyen
« Reply #141 on: May 08, 2009, 21:08:14 pm »
hello rasser,
my engine is a typ 1 without dog house cooler, don't know much about typ 4 engines but they work Grin Grin Grin.
really nice car!!!
dirk
back again!!!
« Reply #142 on: May 08, 2009, 21:16:40 pm »
Hey guys - just so you know its me, I just showed this thread to my dad and he agrees with me and to quote him "Why on earth would you put an OIL COOLER down there???"
 Wink Smiley
Rasser
« Reply #143 on: May 08, 2009, 22:53:54 pm »
because it needs to be fed by air, and it would look dumb in front of the car, imho. It's extremely effective!!!
« Last Edit: May 08, 2009, 22:58:03 pm by Rasser » Logged
1955 type1
« Reply #144 on: May 08, 2009, 23:37:18 pm »
just playing dude - anyway if it needs air then put it on the roof  Cheesy Smiley
I know "Why" you and others have done it buddy and yes I do agree you get maximum airflow BUT it just scares the hell out of me  Smiley
« Reply #145 on: May 09, 2009, 00:46:46 am »
yeah, that's what Sarge is gonna do.
 Shocked
 Grin
« Reply #146 on: April 05, 2010, 17:31:18 pm »
my location of a Racimex alu oil cooler
« Reply #147 on: April 09, 2010, 05:50:31 am »
Havent been on this post for a while. How about useing two cooler's with there own fan, But one is on all the time for cooling and the other, Turned on when needed in winter to blow warm air ducted, for inside car ?
« Last Edit: April 09, 2010, 05:52:47 am by danny gabbard » Logged
« Reply #148 on: April 09, 2010, 07:11:10 am »
I just got through installing a single fan Setrab oil cooler above the tranny on the driver side of my 69' I wish I could have monted it on/near the torsion tube, but it's IRS, no room. I was running well over 220*, but adding the cooler and set my timing @28*, was 32*, helped alot. So far runs @ 187*.
Ted
der60er
« Reply #149 on: January 25, 2011, 17:52:39 pm »
does andyone know whith fitting to use for the EMPI Oil Cooler ? (LONG)
Its not metric, or ?
thank you
