April 30, 2026, 09:33:20 am
Latest Member: Nallepuff
| | |-+  Angle flow heads available again
Pages: 1 ... 3 4 [5] 6 7 ... 12 Print
Author Topic: Angle flow heads available again  (Read 248790 times)
Marty
« Reply #120 on: July 23, 2008, 05:27:49 am »
Those are some REAL good flow numbers now!
NoBars
« Reply #121 on: July 23, 2008, 06:02:38 am »
Now digitize them and go into production...
Why bother buying intake manifolds? 2 flanges, create the runners with weld...
In all seriousness, Really nice work.
ugly duckling
« Reply #122 on: July 23, 2008, 08:06:20 am »
thanks guys. youl see some better #s ive got a few more trickes up my sleeve. UD.
kev d
« Reply #123 on: July 23, 2008, 19:05:52 pm »
Nice work Cool
Would these work for a street motor though or just for the drags?
Cheers,
Kev
Liou
« Reply #124 on: July 23, 2008, 20:07:30 pm »
wow I love see UD word this heads lol big nice valve !!
great job
liou
My 62 ragtop cal look
« Reply #125 on: July 23, 2008, 21:26:41 pm »
Nice work Cool
Cheers,
Kev
Kev
I think they have been proven on the street Smiley
Jeffs own car was driven all over with those heads on his 3litre in his blue bug,then on the real street cruise from LA to Las Vegas only on pump gas and they travelled about 75/80 alot of the way where traffic conditions would allow,then raced them,then drove back home again Cheesy
Austin Larsen
« Reply #126 on: July 23, 2008, 22:19:24 pm »
anyone know what the heads flowed stock?
« Reply #127 on: July 24, 2008, 21:25:14 pm »
WOW! jeff nice work. the only complaint I've heard is that those dog's need a ride with those new heads. Keep up the good work and I hope everythings going good.
Austin Larsen
« Reply #128 on: July 25, 2008, 02:41:44 am »
At your .700" number...
54mm Valve =  3.55" Sq.  at   288 CFM  / 3.55 = 81.12 CFM of flow per Sq in. of valve area
56mm Valve =  3.81" Sq.  at  306 CFM  / 3.81 = 80.31 CFM of flow per Sq in. of valve area
For comparison a decent 42mm T1 head Flowing 200 CFM at .650 lift
42mm Valve = 2.14 " Sq.  at  200CFM   / 2.14 =  93.45 CFM of flow per Sq. inch of valve area
K-Roc,
I was thinking about this today
and instead of comparing flow to surface area of the valve
SA(V)= D(pie)
compare flow to the surface area taht air is cactually flowing through
wich would be teh circumfrence of teh valve times liift
SA(F) = (Rsquared)(pie)(lift)
So the 54  gives 2.48" SA or 115CFM/"
the 56 gives 2.67" SA or  114CFM/"
lastly the 42 gives 1.39" SA or 143 CFM
but for my valve surface area im getting
54=6.67"s not 3.55
56=6.92"s not 3.81
and 42=5.19 not 2.14
maybe my converzion is wron im using
1 millimeter = 0.0393700787 inches
taking the MM(0.0393700787)(pie)=SA
« Last Edit: July 25, 2008, 02:59:20 am by Austin Larsen » Logged
dangerous
« Reply #129 on: July 25, 2008, 11:07:27 am »
Have you been drinking energy drinks Austin?
Not sure what you are getting at completely, but I have an idea.
It may be more clear if you use different terms to describe what you men.
Valve AREA is (pi)x (radiusxradius), and really the valve throat area is relevant if that is the minimum cross section in the port.
(not always at the valve seat throat Wink)
Also relevant is the CURTAIN AREA, which is the VALVE CIRCUMFERENCE multiplyed by lift.
Circumference is = (pi) x diameter
Both these calculations, and the actual flow numbers are handy when comparing various valves and their flow numbers at different lifts.
Guys like Jeff, Darren K, Pat D and the hell-guys from Heads-Up! know what numbers are representative from their vast experience,
so they can compare apples with apples.
Interestingly a 4 valve chamber has massive curtain area, and large low lift flow numbers without the large cross section.
But this may not be an advantage as you may first think.
Although the japanese designers seem to have made the most of both low and high lift flow numbers in some production engines.
Normally they use smaller duration to avoid too muc low lift flow, too early....typical of 4-valve, or any large-curtain-area/excessive low lift flow combos.
dangerous
« Reply #130 on: July 25, 2008, 11:11:43 am »
Sorry about the verbal diarrhea.
Austin Larsen
« Reply #131 on: July 25, 2008, 16:06:55 pm »
thats what i meant
wouldnt it be better to compare flow to curtain area instead of valve area?
drgouk
« Reply #132 on: July 26, 2008, 22:57:10 pm »
Dave, I have been following your progress on the aussieveedubbers with your new head combo, very nice, always good to start with a clean sheet of paper. I am doing the same thing with a pair of comp "e" heads.
It will be very interesting to see what happens at the dyno. Wink
ugly duckling
« Reply #133 on: August 04, 2008, 05:18:23 am »
some more head candy.
ugly duckling
« Reply #134 on: August 04, 2008, 05:56:05 am »
this will be the round int/ex street/race port. valve size is 50x42 the ex seat will except a 40 but wanted to see what it would flow with the bigger 42 will see this week. you turbo guys may like this set up. again there is no weld what so ever on the head casting and the manifold this time as well. the rnd int is smige bigger than the original port just slitely warmed over  Tongue.  UD
« Last Edit: August 04, 2008, 06:16:55 am by ugly duckling » Logged
ugly duckling
« Reply #135 on: August 04, 2008, 06:10:50 am »
more to come. when we head over to the over size vacume cleaner. enjoy. UD.
71CALRIPPER
« Reply #136 on: August 04, 2008, 10:00:25 am »
what about rocker shaft support for those high lift motors ? will there be extra support ?
58vw
« Reply #137 on: August 04, 2008, 22:57:04 pm »
hey wont the engine run funny with the different ports like that? Wink Grin
www.4inbore.com
Angleflows...order them now
ugly duckling
« Reply #138 on: August 05, 2008, 01:23:54 am »
hey rob. when i do the crower conversion rocker set up there will be plenty of support. as far as your standard rocker set up the rocker blocks on these heads are alot bigger than the early 80s style angle flows and in my opinuon shoudent be a problem. UD.
Austin Larsen
« Reply #139 on: August 05, 2008, 03:12:05 am »
is that a CNC mill?
redbluebug
« Reply #140 on: August 05, 2008, 03:31:12 am »
Nice!
ugly duckling
« Reply #141 on: August 05, 2008, 07:04:39 am »
naw austin. are you gonna get one for me for christmas. come on be a pal.  Smiley.  UD.
Austin Larsen
« Reply #142 on: August 05, 2008, 07:09:24 am »
u might be able to buy mine if u can come up with the right amount of $$$
need a  5 Axis
71CALRIPPER
« Reply #143 on: August 05, 2008, 08:18:25 am »
 Grin
Martin
Cash Converter....
« Reply #144 on: August 05, 2008, 12:07:56 pm »
Hello Jeff, man there looking good, been following this thread witha lot of interest.
I've done the Crower rocker Conversion on my motor and i must say its great! even running the 700lb springs they just seam so stable.
Keep up the good work!!!
Woper says Hi
Martin
www.taylormachine.co.uk
OFF/500
58vw
« Reply #145 on: August 08, 2008, 01:24:22 am »
holy crap batman Shocked
www.4inbore.com
Austin Larsen
« Reply #146 on: August 08, 2008, 04:20:39 am »
that looks like a CNC to me
A D^MN 5 AXIS CNC at that
WITH A ATC!!!!
« Reply #147 on: August 08, 2008, 05:59:17 am »
WITH A ATC!!!!
Looks like a Haas VF-0 or VF-1. I've got 9 years on these machines.
karl h
« Reply #148 on: August 08, 2008, 07:43:47 am »
how much would a CNC set be?
ugly duckling
« Reply #149 on: August 11, 2008, 02:47:53 am »
i have to say these manifolds blend very nicely to the head ( smooth transition) not like  other brand heads that i have worked on. the angle flowes are deffenetly match port freindly.UD
