November 04, 2026, 04:39:30 am
cut or not to cut
Topic: cut or not to cut (Read 8337 times)
banditina
cut or not to cut
May 20, 2008, 04:37:01 am »
HI, i have a beetle 1963 with BRM flat4 5" Michelin zx 145's, I am thinking a 4cm narrowed beam or a stock beam....
cut or not to cut... this is the problem...
stock beam or -4cm beam for a cool cal look...
tnx
www.stinkingass.blogspot.com
http://die-kriegs-maschine.blogspot.com
http://www.oldclan.it
IF YOU THINK YOU'RE TOUGH INSULT A KAFERMAN!
Rocket-Racing
Re: cut or not to cut
May 20, 2008, 07:22:18 am »
I would go with the stock beam.
This is a matter of taste but in my opinion a real looker doesn't need the wheels tucked further in than necessary. A narrowed beam is ok if you need it to make the wheels sit right due to offset issues, but you should have no problems at all with the Flat4 BRM's and 145's.
Last Edit: May 20, 2008, 14:43:34 pm by Rocket-Racing
Bewitched666
Bewitched
May 20, 2008, 07:33:56 am »
Cut beam aint callook
Fast vw beetle's rule
71CALRIPPER
May 20, 2008, 10:34:02 am »
I think it depends on your brake set up , if your running drop spindles or disc up front, it might increase the track ? In that case Narrow it enough to return it to stock.
Rob
benssp
www.callookvw.com
May 20, 2008, 11:08:16 am »
Do it just enough to bring the wheels back into the original position
www.vwheritage.com
My Job
www.bernardnewbury.co.uk
My Team
any work related enquiries to
ben@vwheritage.com
YMCA
Frank LUX
Back...Soon...hopefully!!!
May 20, 2008, 11:37:05 am »
Quote from: Bewitched on May 20, 2008, 07:33:56 am
So there is another Reason for my Car then not being a Cal-Look...
I kept the Chrome and my Front Beam is narrowed 2.5cm per Side...
That was done because of the CSP Disk Brakes that widened the Track and the F4 BRM's with 145's started to rub against the Fenders...
Frank
Bewitched666
Bewitched
May 20, 2008, 11:50:23 am »
I agree with 54caldub
alex d
May 20, 2008, 12:06:01 pm »
I wouldn't cut unless you had rubbing issues, which should not be the case with those wheels and tyres!
May 20, 2008, 12:48:34 pm »
Quote from: Frank LUX on May 20, 2008, 11:37:05 am
You are doing it all wrong...!! next thing you will be telling us is that you are fitting N20!! Or that you are trailering it!!
banditina
May 21, 2008, 00:35:13 am »
tnx guys...
i have stock brakes.... anywere because "Cut beam aint callook " ......not cut!
stock beam
i restart my job with another beam
best regards..
May 21, 2008, 06:10:52 am »
If it rubs, cut it just enough to clear.
