June 09, 2026, 18:45:29 pm
Latest Member: mvptkfjb
| | |-+  AssHull's '67 project
Pages: 1 2 [3] 4 5 ... 18 Print
Author Topic: AssHull's '67 project  (Read 671215 times)
SlingShot
« Reply #60 on: December 23, 2008, 06:13:23 am »
<a href="http://www.youtube.com/v/dhUFxaauNTE" target="_blank">http://www.youtube.com/v/dhUFxaauNTE</a>
 Wink Cheesy
Will Race For Beer !!!
« Reply #61 on: December 23, 2008, 14:56:34 pm »
Dammit Sling, not yet! Not til we get it painted!! Angry
AssHull
« Reply #62 on: January 04, 2009, 00:30:04 am »
Now that the pan is all done, Zach and I started doing some of the metal work.  Drilled out the spot welds to make the rear apron removable.  Also pulled a couple pounds of un-needed weight.  Decided that I'm not going to run a heater in the car (luckily I live in Arizona where it was almost 70 degrees fahrenheit yesterday) so we removed all traces of the stock heater today. Didn't have any gas for the welder so we were not able to weld up any of the holes yet. Probably get to that on Monday when the store is open. Going to work on it more tomorrow. I'll update on the progress.
Cheers!
« Reply #63 on: January 04, 2009, 21:51:05 pm »
Shortly after that post yesterday we got bored again so we had another go at it Smiley Asshull removed all of the factory seal channels around the hood and decklid openings in preparation for Mexican Beetle seals that mount directly to the hood and decklid for a cleaner look. He also cut out the bottom of the rusty A pillars to fit up the replacement pieces from Hooky's Panel shop. I started on fabbing up a convertible decklid, in the words of the great Jeremy Clarkson, "How hard can it be?" Roll Eyes I've still got a touch of trimming to do, but so far I am very pleased. 'Course I haven't welded it up yet and that's usually where I get impatient and fuck it all up Cheesy
« Last Edit: January 04, 2009, 21:52:56 pm by Zach Gomulka » Logged
« Reply #64 on: January 04, 2009, 21:54:42 pm »
Wünderwolff
aka Dr. Jeckill
« Reply #65 on: January 05, 2009, 21:24:35 pm »
That work on the decklid is so nice, really inspiring. I wonder how long I can wait before getting out the grinder.
And by the way, the other work is equally inspiring, but I already cut the heating channels in my car  Grin And it is minus 10 degrees celcius tonight  Roll Eyes
Wünderwaffe are Go!
« Reply #66 on: January 05, 2009, 22:39:27 pm »
Thanks for the kind words Smiley It really isn't that hard, pretty straight forward actually. Just took my time, and so far so good. I'm going to start welding it up tonight as we finally got some gas for the MIG...
« Reply #67 on: January 06, 2009, 05:27:40 am »
I plug welded the brace back in first to restore the proper shape of the lid, then I trimmed the vents to the exact shape of the opening. Now I need a couple Vise-Grips with deep throats so I can weld the vents up the rest of the way...
SlingShot
« Reply #68 on: January 06, 2009, 05:47:21 am »
Bring in those rusty vents to the shop so we can bead blast em, before you weld it in. That way we won't have to cut the decklid in half to fit it in the cabinet  Wink
Rocket Ron
It's old school for a reason
« Reply #69 on: January 06, 2009, 09:28:52 am »
first time I've seen it done like that, taking the top rail off
you make it look too easy  Embarrassed
13.12 @ 101.84
Grooving out on life
yvre
Der Autobahn Scrapers
« Reply #70 on: January 06, 2009, 10:12:11 am »
Mmmm deap throat....
Nice work!
« Reply #71 on: January 07, 2009, 04:41:32 am »
Hi Zack what did you use to cut the deck lid with?
« Reply #72 on: January 07, 2009, 17:38:21 pm »
Just a cut-off wheel, angle grinder to clean it up, and a stone to get the inside curve.
« Reply #73 on: January 07, 2009, 18:47:45 pm »
Are you going to remove the brace again to finish off the welds on the inside? when I did mine I just tacted a bar from one side to the other then installed the brace after it was welded and ground down then removed the bar
« Reply #74 on: January 07, 2009, 19:21:03 pm »
I've thought about that, but I think I will just get it as close as I can without removing it again. A Dremel and a steady hand will do wonders Wink
« Reply #75 on: January 09, 2009, 01:57:16 am »
Tacked into place... and fully welded. What a pain in the ass that was! AssHull is grinding the welds flat as I type this...
« Reply #76 on: January 09, 2009, 02:26:15 am »
How Bad did it warp? WHEN YOU WELDED IT UP?
« Reply #77 on: January 09, 2009, 02:36:27 am »
Looks like the same method they used in an article of HVWs a few years ago. Nice work.
« Reply #78 on: January 09, 2009, 02:53:50 am »
A couple spots got a little squirrelly from the heat, but not bad at all. Once it's ground down I'll take a body hammer and straighten it back out. I'm very pleased thus far Smiley
AssHull
« Reply #79 on: January 09, 2009, 05:01:13 am »
Finally finished grinding down all of the welds.  Took a little patience (didn't want to heat it up too bad) but here we go. Warped a little between the welding and grinding but Zach took a body hammer to it to straighten it out. Hit it with a coat of paint just to get a feel for the look. All in all, turned out pretty well I think.
« Reply #80 on: January 09, 2009, 13:49:44 pm »
Not bad at all. Very nice work. He welds, he does upholstery, what more could you ask for.
« Reply #81 on: January 11, 2009, 02:50:18 am »
Welded up the trim holes, washer nozzle, and it seems like a million other things today. Ashtray also went the way of the Dodo. AssHull just made up some very precise panels from the sheetmetal from the donor decklid to get rid of everything not needed on the dash. Gonna go tack them in now. The dash will be very clean and all business when everything is all said and done Smiley
« Last Edit: January 11, 2009, 02:53:56 am by Zach Gomulka » Logged
Wünderwolff
aka Dr. Jeckill
« Reply #82 on: January 11, 2009, 10:01:42 am »
Sneak preview of the result  Wink Shocked Cool
Wünderwaffe are Go!
« Reply #83 on: January 11, 2009, 18:19:57 pm »
Hey that's cool, thanks! Finished dash will not be so bare though. Hazard light switch will be in the center where the ashtray used to be, and a cigarette lighter (power outlet, really) will be opposite of the ignition switch. And it will be painted VW Blue! Smiley But more importantly...
'68-'69 911S tach in the speedo hole...
Early 914 speedo (100mm) to the right of the tach...
And an early 914 combo gauge (also 100mm) on the left
Still looking for said gauges, so if anyone has what we need give us a shout! Smiley
« Reply #84 on: January 11, 2009, 22:04:47 pm »
AssHull cut holes in the inner roof structure for twin Hella rocker style dome lights, 911 style Smiley
« Reply #85 on: January 12, 2009, 01:10:54 am »
Black boogers!!!
roland
lates are the new splits...
« Reply #86 on: January 12, 2009, 01:25:41 am »
 Grin nice..
« Reply #87 on: January 12, 2009, 11:58:58 am »
nice work.
i wanted to do the same thing with 3 of my porsche gauges but i changed my mind.
 Wink
« Last Edit: January 12, 2009, 12:40:15 pm by 67-indeed/DVK » Logged
beetletom
« Reply #88 on: January 12, 2009, 17:42:45 pm »
nice work!!!  Cool
AssHull
« Reply #89 on: January 13, 2009, 02:03:44 am »
Went down and picked up a couple gauges from a junkyard here in Phoenix. They didn't have the Tach that I wanted so I'll have to keep an eye out for that still.
