November 07, 2025, 08:20:34 am
351867 Posts in 28821 Topics by 6907 Members
Latest Member: Wenzel
| | |-+  AssHull's '67 project
Pages: 1 ... 16 17 [18] Print
Author Topic: AssHull's '67 project  (Read 550898 times)
AssHull
« Reply #510 on: February 16, 2021, 22:26:20 pm »
Its been too long. Life got in the way of getting this thing dialed in. Couple of kids, college degrees, and cross-country moves. Been re-inspired to get back to the garage though. Got several new parts and plans in stock though. Want to work on some suspension. Got an electrical gremlin that I'm trying to figure out.The clock may never work right but its time to re-engage.
andrewlandon67
« Reply #511 on: February 17, 2021, 03:38:24 am »
Who needs a working clock, keeping time while driving only matters when you're racing  Wink
14.877 @ 88.85 mph
He who waves at 911 drivers
« Reply #512 on: April 07, 2021, 04:21:27 am »
This is gonna be good!!!
Anyone here live in Florida by chance??
Andrew, thanks for the quote!
andrewlandon67
« Reply #513 on: April 08, 2021, 16:00:31 pm »
Well this is the most excitement I've gotten checking into the Lounge in a while... Zach, it's a damn good quote if I do say so myself.
I'll be keeping my eyes open...
14.877 @ 88.85 mph
« Reply #514 on: October 04, 2025, 00:59:56 am »
« Last Edit: October 04, 2025, 01:12:33 am by Zach Gomulka » Logged
« Reply #515 on: October 04, 2025, 01:14:07 am »
https://youtu.be/nRdllODvFJ4
« Reply #516 on: October 04, 2025, 15:54:34 pm »
really nice to see that car back on the road.
« Reply #517 on: October 04, 2025, 18:10:04 pm »
This car has covered very little ground since it was built, Chris never really had a chance to get it dialed in. Last weekend I helped rectify that. The suspension needed some fine tuning- it had settled down too low, had no front sway bar and the tires were 15+ years old and hard as rocks.
We installed beam stiffeners, 14mm Thing sway bar, raised the left rear ≈1" and adjusted the front up a scosh. And new tires (185/60's, 215/65's) which saved over 11lbs. It’s far more composed and controllable now. Some adjustments still need to be made on the sway bar (standard sway bar on 2" narrowed beam) but it's getting there and a huge improvement over where it was.
The front end grips very well now but the rear end with its original 21mm torsion bars, Z bar delete with camber compensator feels pretty sloppy to me. Feels like it's ready to lift off oversteer when pushing it. I wonder if earlier 22mm bars would be a decent improvement (math says 20% stiffer) or go with some much larger SAW 24mm bars...
andrewlandon67
« Reply #518 on: October 08, 2025, 16:17:27 pm »
Whose beam stiffeners did you go with? I've been debating getting a pair for my '67, the Empi ones look like crap but the CSP ones might not fit my 2" narrowed beam.
14.877 @ 88.85 mph
« Reply #519 on: October 17, 2025, 03:39:15 am »
They were original VW. I put CSP on the GTV years ago and from memory they seem to be exactly the same. This ‘67 also has a 2” beam and the stiffeners do just barely fit… however the grease zerks are now inside the clamps (inaccessible) and I did have to trim away the steering stop bracket but it wasn’t being used anyway.
jerem56
« Reply #520 on: October 17, 2025, 11:39:21 am »
Just discover your topic today! nice car, love your dash as it's quite similar to mine, and i got 914 buckets too  Grin
follow me on instagram : jerem_56oval
andrewlandon67
« Reply #521 on: October 21, 2025, 16:03:56 pm »
Good to know about the steering stop bracket interference, that's something I actually like having on my car so I'd be pretty wary of having to cut into it too much. I meant to mention in my earlier response as well, going to 22mm rear torsion bars is a smart idea, I have a newer Empi camber compensator on my car which definitely helps but having a stronger spring rate and maybe stiffer spring plates could really keep the rear planted.
14.877 @ 88.85 mph
« Reply #522 on: November 02, 2025, 15:05:40 pm »
Looks great!!
« Reply #523 on: November 02, 2025, 15:16:57 pm »
The steering stop wasn't being used and as I found out most narrowed beams don't come with one anyway so it wasn't a big loss. It's totally fine without it.
We've ordered new SAW 24mm torsion bars but they're backordered so It'll be a little while before they find their way in. I did the math and that's 70% stiffer than the 21's. The rear control/handling with the original bars is not great. The car has always had a SAW camber comp but I really am starting to think that style is not beneficial, I think the EMPI/CB type will actually act more as a sway bar so we may swap in one of those in the future.
