August 12, 2026, 14:08:44 pm
the list
Topic: the list (Read 44962 times)
the list
June 16, 2008, 12:25:51 pm »
so what is there still to do to get to EBI?
here is my list:
engine!!!! i have to have one
brakes: residual pressure valves, bleed, check things
headliner: seems fixed, but not tested so might have to do it again; it comes down when i open the windows...
rear suspension: is a notch to low and the adjustable springplates are not fitted yet
front is not alligned, can only do it when i have an engine.
what i have done the last week:
headliner, refitted and made some perforations
batterycut-off (i like racecars
tach mounted in the dash
empi padded wheel fitted and the horn made to work again.
brakes refitted after being reground.
cleaned the interiour
runningboards repainted
onepiece windows made work a bit better (still not perfect, but i am getting there. still no regrets fitting them
hope everyone is still motivated to GET IT DONE
Re: the list
June 16, 2008, 14:48:20 pm »
sounds cool nicolas!
any pictures perhaps? can't wait to see it at EBI! hope you make it
DVK ~
ESH
Re: the list
June 16, 2008, 15:13:38 pm »
1. Sort 'some stuff' out.
We're taking a more relaxed approach to European travel this year.
Possibly.
Wünderwolff
aka Dr. Jeckill
Re: the list
June 16, 2008, 17:20:52 pm »
Get the European Bugtour at Chimay organised
You all better get those cars running longer than a 1/4 mile
Wünderwaffe are Go!
wolfswest
Re: the list
June 16, 2008, 18:41:34 pm »
install the fuchs caps on the rear wheels (axles are too long so I need a sort of an adaptor)
I have 2 drips (don't know the word for druipers, dutch guys help me out plz
) and I need to polish the car untill they are gone
install my new floorcarpet
make my dash look a little bit more attractive as it does now. (I will weld it in the winter and make a super clean dash)
clean, polish, wax it the best I can
Jordy/DVK
Re: the list
June 16, 2008, 19:35:38 pm »
Quote from: nicolas on June 16, 2008, 12:25:51 pm
Nothing... because I can't come to Chimay for the EBI 2...
DVK ~
"The Full-Throttle Cruisers"
1951
medium brown splitwindow beetle
(resto in progress)
1968
Cal-look(-a-like)
(my daily driver)
roland
lates are the new splits...
Re: the list
June 16, 2008, 20:25:15 pm »
Quote from: wolfswest on June 16, 2008, 18:41:34 pm
Yeah 0.5 cm spacer, i had a set on the 68 when it had long axles. I'll give them to you if you want...
empicolector
EMPI RULES
Re: the list
June 16, 2008, 20:56:47 pm »
Today i've finished to clean all the parts to fit and the wheels and the interior who really need it
the rest must be done this week
some paint minor job for this saturday
wolfswest
Re: the list
June 16, 2008, 21:18:42 pm »
Quote from: roland (DAS) on June 16, 2008, 20:25:15 pm
Hey Roland, that would be super! how much do you want for them? you can pb me so we don't mess up the topic.
Re: the list
June 16, 2008, 21:26:36 pm »
hey you guys are not messing up the topic IMHO, i would like to see people helping eachother out like this. so everybody can scratch things off their list and make it all to EBI.
wolfswest
Re: the list
June 16, 2008, 21:35:34 pm »
Quote from: nicolas on June 16, 2008, 21:26:36 pm
that's a fact...
Another thing... I'm thinking on painting the "ears" on my 72 green like my car so that they are less obvious... Nicolas, you have seen my car, (or others that have seen him) Would it be an upgrade? Should it be easy for a professional painter to paint that kind of plastic?
Re: the list
June 16, 2008, 21:44:59 pm »
you can do it yourself, you just need to go to a shop and get a primer for plastic parts like rearvieuwmirrors, and a spraycan with the same colour. there are no great flat surfaces, so you might be able to do it yourself. it will be more subtle for shure.
cal-look.net
Re: the list
June 17, 2008, 00:04:32 am »
My list!
finish sound proofing,about 80% done - man my fingers and back are sore!
fix headlights and find a fuel sender!
oil change, MOT & tune up from Ian at Wolfsburg Performance
oh and try to get decklid to latch!
then go go go!! . . .
. . . maybe fit Berg linkage from Don Bulitta if the postal service pulls it's finger out!!
Re: the list
June 17, 2008, 00:14:23 am »
Right here we go :
1 - finish off engine - fixing a oil leak from the dyno stand, plus general freshen up
2 -
Bleed and refit x4 brake drums
DONE
3 - MOT
4 - check tracking - seeing as its NEVER been done
5 - REFIT Engine
Well those are the main ones but there are about 20 other small jobs I can't be bothered to mention - Don't worry She'll be there
Last Edit: June 18, 2008, 22:08:32 pm by monkiboy
Re: the list
June 18, 2008, 21:04:37 pm »
had a phonecall today and if all goes well i might be able to pick up the engine next week... so i am getting nervous AND i will be changing the rear suspension to pass the time...
lowfastbus
WUNDERWAFFE
Re: the list
June 18, 2008, 21:42:40 pm »
I had a "small" list off things to do:
fix cracked exhaust
service brakes
service engine
But when working on the interior off a AC at work today, I decided my car needs one to for EBI
So now the list also contains:
respray interior
make new custom dashboard
buy and install carpets
make door and quarter panels
recover those panels
If all goes well this could still be done...
Jelle
http://dragvws.skynetblogs.be
WUNDERWAFFE
The Knuckle Buster
Re: the list
June 18, 2008, 22:07:46 pm »
GET A NUT OUT OF THE INSIDE OF MY CRANKCASE
Re: the list
June 19, 2008, 07:35:38 am »
Quote from: monkiboy on June 18, 2008, 22:07:46 pm
do i hear rebuild?
empicolector
EMPI RULES
Re: the list
June 19, 2008, 08:05:34 am »
yesterday I work on the car
ignition ( 010 + empi tansisparks)
exhaust
were done
today will work on bumper
Re: the list
June 19, 2008, 12:03:45 pm »
Quote from: nicolas on June 19, 2008, 07:35:38 am
do i hear rebuild?
Not quite yet - I just need to get the dizzy drive out
ESH
Re: the list
June 19, 2008, 12:09:21 pm »
Quote from: monkiboy on June 19, 2008, 12:03:45 pm
...I just need to get the dizzy drive out...
Ignore my PM, you just answered the question.
Damn
Re: the list
June 19, 2008, 12:10:25 pm »
Like my friend Rob said though -
AT LEAST I KNOW IT FELL INSIDE THE CASE
! Just imagine if I DID NOT see it fall in there
Last Edit: June 19, 2008, 12:12:19 pm by monkiboy
Re: the list
June 19, 2008, 13:44:21 pm »
ITS FIXED!!!!!!!!!!!!!!!!!!!!!!
THANKYOU RICHIE - YOU ARE THE MAN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Just needed to turn the engine upside down
Re: the list
June 19, 2008, 14:45:05 pm »
Quote from: monkiboy on June 19, 2008, 13:44:21 pm
Only to happy to help out
ESH
Re: the list
June 19, 2008, 14:49:36 pm »
... Just needed to turn the engine upside down ...
At least a Buggy's light enough to tip over!
Re: the list
June 19, 2008, 15:43:42 pm »
Can't do anything, WAAAIIITING for parts.
Re: the list
June 19, 2008, 15:59:04 pm »
Quote from: Mat Sanchez on June 19, 2008, 14:49:36 pm
Re: the list
June 19, 2008, 17:43:34 pm »
so funny, but kuddos to richie (again) simple ideas are best! got it from a shoebox, but it is oh so right.
Re: the list
June 19, 2008, 17:48:24 pm »
Quote from: nicolas on June 19, 2008, 17:43:34 pm
He's the man and I owe him a beer thats for sure
Re: the list
June 19, 2008, 23:00:58 pm »
I have install new doors tonight.
I should make a very good cleaning and polishing of my car. Country roads are dirty
I bought a 1835cc engine from a friend, but time is a little bit short to install it. lots of little things to do I'm a waiting for some parts.
And it has a Porsche cooling...
