September 21, 2026, 22:43:40 pm
|-+  Tyre kicking
| |-+  Off Topic
| | |-+  pulley install with engine in car
Author Topic: pulley install with engine in car  (Read 8559 times)
lawrence
« on: July 13, 2008, 18:04:31 pm »
Does anyone have any good tips on getting a berg pulley installed with the engine in car.
"Happiness is a Hot VW!"
Sam K
« Reply #1 on: July 13, 2008, 21:26:44 pm »
If it's one of the "big" pulleys, you might need to take of the breast plate and the exhaust. On my car, I also have to use loctite (preferably the green stuff) or my Berg equaliser seems to work it's way loose after a couple months.
« Reply #2 on: July 14, 2008, 01:16:00 am »
It's do-able, but a huge pain in the ass.  My current engine has a Berg equalizer that I had to remove and re-install because of a slight leak at the oil pump.  When you get ready to install, warm the center of the pulley a bit with a propane torch (not much!!) and it will go a bit easier for you.  Good luck!
John Rayburn
« Reply #3 on: July 14, 2008, 01:18:54 am »
Depending on how tightly it fits the crank, sometimes it's just easier and faster to pull the engine.
I also park at Nick's.
« Reply #4 on: July 14, 2008, 02:02:51 am »
Not if your old and fat  Roll Eyes
lawrence
« Reply #5 on: July 14, 2008, 02:41:20 am »
Yeah, I do not really want to pull the engine, but that is the right way to do it. That way I can lock the flywheel and torque the bolt properly. I was thinking of fabing some longer bolt that could push the pulley on, but that would probably ruin threads on the crank or something. Then I would have to tear the engine apart. It could use a slight increase in compression though... Grin
Sarge, I do not fall under either of those categories. Grin Sorry buddy. Thanks for the advice guys.
ian c
« Reply #6 on: July 14, 2008, 08:21:53 am »
you will , son . you will ...,
(o\ ! /o)
lawrence
« Reply #7 on: July 17, 2008, 06:04:56 am »
The new berg pulley is on and it looks good! I used a heat gun to warm the pulley and it went on very easy with a few smacks from a rubber mallet. Red loctite on the bolt threads and torqued to 80 ft. lbs.
I am glad I pulled the engine because I found a few other problems: Split in intake manifold gasket and what looks to be a leaky pilot shaft seal.
« Reply #8 on: July 17, 2008, 07:54:29 am »
The secret is never to pull your engine or, indeed, work on your car at all. That way you never get to discover new problems... Wink Cheesy
« Reply #9 on: July 17, 2008, 12:10:57 pm »
Unfortunately it means you have to drive an Alfa Romeo... or in my case, an old Passat! Cheesy
