September 24, 2026, 18:15:30 pm
| | |-+  How to lock out the 009 distributor?
Author Topic: How to lock out the 009 distributor?  (Read 19625 times)
airstuff
« on: July 21, 2008, 20:17:43 pm »
Hi people,
Can someone please explain,what  needs to be done to the distributor in order to get it locked up(ignition curve)?
Pics would help also....
Thanks.
« Last Edit: July 22, 2008, 20:27:46 pm by cal-look » Logged
airstuff
« Reply #1 on: July 22, 2008, 20:26:35 pm »
come on guys,is it a secret? Cheesy
« Reply #2 on: July 22, 2008, 20:31:55 pm »
Yeah... how come Ratto's holdin' out on us? C'mon, Jim. We know that you know how to do this.
 Grin
gibber!
« Reply #3 on: July 22, 2008, 21:03:00 pm »
Did I hear somewhere about threading a bolt through the case of the dizzy to prevent it from fully advancing... and therefore making it possible for you to arrest the advance where you want?
Or am I way off.... Huh
1967 1500 Beetle
1970 Karmann Ghia
SSVWC member
« Reply #4 on: July 22, 2008, 21:21:34 pm »
i thought it had something to do with welding weights into the dist...
Mike Lawless
« Reply #5 on: July 22, 2008, 21:25:46 pm »
There's a limit tab on the base plate that limits the amount the advance mechanism can move. You can bend that tab to the point that advance is locked out. Otherwise, perhaps spot weld the advance plate to the base plate.
2006 PRA Super Gas Champion
2002-2003 DRKC Champion
http://www.lawlessdesigns.com
« Reply #6 on: July 22, 2008, 21:30:56 pm »
We used to just tack weld the advance weights @ BH, I even saw jerry lock one with a self-tapping screw.
« Reply #7 on: July 22, 2008, 22:16:54 pm »
i think i got a 009 that is locked by the Ideaman;
i ll try and make a pic...
« Reply #8 on: July 22, 2008, 22:28:40 pm »
here it is...
OldSpeed
1300 Addict.
« Reply #9 on: July 23, 2008, 12:51:07 pm »
This is how Kevdonlon01 from VZI did his:
Quote
The next thing was to modify my 009 dizzy to limit the advance to 24 degrees as per again ourkids thread first as he says you have to have an understanding of how the mechanism works,this is a centrifugal advance distributor that relies on weights moving out as the distributor rotates untill max advance is met,the total advance is too much for a turbo so has to be limited
first strip the dizzy down to its component parts and identify what does what,the pic below shows the weight (with the plastic pad) and the stop it hits as it moves out
the next thing to do is drill and tap the stop for a 3mm grub screw
reassemble the dizzy and pop out the cover on the side,this will allow you to rotate the rotor arm so you can see the new grubscrew inside and adjust it to limit your advance
using a protractor i marked a line 7 degrees clockwise of the original timing mark, i drew a line on the rotor arm and lined it through,then using a screwdriver i opened the weight towards the grubscrew untill the line on the rotor arm lined up with my mark 7 degrees away, i then adjusted the grubscrew onto the weight and this should now limit its advance
and with the rotor arm removed for clarity (weights being held against the grub screw stop)
When my engine is running i will set the timing at 24 degrees at 3000 revs and lock it off,according to what the timing is when it idles i may slightly adjust where the weights are limited to but always resetting to 24 degrees at 3000 revs (basically only the idle timing will change then)
Disclaimer,i am no expert on this,i have tried to follow previously done work and include pics as i go along,dont moan at me if you follow this and your motor blows up,mine will have already gone and i'll have too much work on my hands putting it right to worry
 Wink
airstuff
« Reply #10 on: July 23, 2008, 15:47:13 pm »
great Smiley going to do mine tomorrow  Cool
