October 12, 2026, 13:34:22 pm
| | |-+  some work
Pages: 1 2 3 [4] 5 6 7 Print
Author Topic: some work  (Read 139951 times)
« Reply #90 on: December 28, 2008, 00:05:53 am »
Hey buddy there is another cool little trick you can do - you should replace ALL the gearbox case nuts and washers with brand new items (maybe stainless Undecided) it just gives the gearbox a really nice detailed finish  Smiley
yes cool idea lee but i'm hurry to fit the gearbox on the car , and replace the engine , and driving again the car
« Reply #91 on: December 28, 2008, 00:35:34 am »
ah come on dude it will only take an hour  Wink Smiley
« Reply #92 on: December 29, 2008, 18:53:56 pm »
today put the short axle on the  side gear
« Reply #93 on: December 29, 2008, 18:59:05 pm »
and testiing the diff inside the gearbox
« Reply #94 on: December 29, 2008, 19:09:09 pm »
put the new paper gasket on the nose
« Reply #95 on: December 29, 2008, 21:03:33 pm »
Now you understand my nickname ...
Hurry Fabs ! Wink Wink Wink Go, Go, Go !
« Reply #96 on: December 29, 2008, 21:32:35 pm »
Grin Grin Grin Grin
« Reply #97 on: December 30, 2008, 17:35:42 pm »
today i removed the gudgeons (lug nut??) , and put longest one for the berg trans mount
« Reply #98 on: December 30, 2008, 18:09:23 pm »
i  put the diff inside the gearbox , add some new paper gasket and close each side
« Reply #99 on: December 30, 2008, 18:11:18 pm »
 Wink
everything turn correctly by hand with the tail box(main shaft??)
« Last Edit: December 30, 2008, 18:58:55 pm by speedwell » Logged
« Reply #100 on: December 30, 2008, 18:38:57 pm »
 Wink
« Reply #101 on: December 30, 2008, 22:17:43 pm »
so it is not in the car yet???  Grin
good work. looks like you are cheking up everything. Lee's idea is a good one though. the new nuts would defintely make it all look even better.
just a question, do you use the one piece booths/ rubbers for the axles? i have them and they are the best investment i have done last year. they don't leak a drop.
« Reply #102 on: December 30, 2008, 22:18:39 pm »
next step will be calculate the number of paper gasket to put with the tube axles if i remember is 3 or 4 Huh
« Reply #103 on: December 30, 2008, 22:32:31 pm »
nicolas are you talking about this parts Huh
yes i've  those one since 99 if i remember well , i never had a problem with , but very hard to put on the axle tube  Roll Eyes
« Reply #104 on: December 30, 2008, 22:54:07 pm »
you need to put some in and see if the tube can move down on it's own weight. if not put in a thicker one or add a thin one until it just slips down. since you powdercoated the gearbox it will be different as before. i am not sure if the paint comes lose or not due to the corrosive gearoil, but i would leave the tubes on the tight side. so it moves down, but maybe not all the way, as the paint will scratch and then you'll have more play afterwards.
good thing about the booths. the first one was hell then i got to know how to do it and now they are on in minutes
besserwisser
« Reply #105 on: December 31, 2008, 15:11:55 pm »
If your sidecovers dint have any papergaskets because they are sealed with o-rings you shouldnt put in papergaskets. If you do you change the preload of the ring and pinjon for the worse. Try to check the play between the ring and pinjon when you have it together. Not more than 0.20 mm.
« Reply #106 on: December 31, 2008, 19:28:03 pm »
thx  Wink
« Reply #107 on: December 31, 2008, 23:34:07 pm »
today i put the left tube axle
 at the begining it was easy , and after the bearing didn't want to come down on the axle and by trying to make it come down, it is half a moon which moved  Undecided
Where from I've of to re-dismount the clips and to put back the half a moon correctly in the sidegear  Roll Eyes Roll Eyes
3 paper gasket for this side
« Reply #108 on: December 31, 2008, 23:40:25 pm »
tomorrow or this week end the right side  Roll Eyes i hope that i wouldn't have the same problem as for the left side  Huh
« Reply #109 on: January 31, 2009, 20:51:57 pm »
some updates  Grin Grin
last week end i put the right swing axles tube , no problem this time  Grin Grin
« Reply #110 on: January 31, 2009, 20:55:52 pm »
 The base of the camber compensator is also settled
« Reply #111 on: January 31, 2009, 20:59:16 pm »
Finally the big day came  Grin Grin Grin Grin i fixed the gearbox on the car  Roll Eyes Roll Eyes
the berg trans mount is on the gearbox too
« Last Edit: January 31, 2009, 21:04:20 pm by speedwell » Logged
« Reply #112 on: January 31, 2009, 21:02:58 pm »
now the brake are ready to be fix on the car , next step will be to receipt the brakes drums  Wink
« Reply #113 on: January 31, 2009, 21:05:27 pm »
Lookin good dude but get rid of those crappy RED mounts! I have a set break/snap on me and its NOT FUN - Trust me I'm not the only one  Smiley
« Reply #114 on: January 31, 2009, 21:13:31 pm »
the rhino silent bloc Huh no problrem with those this year ....... Huh
can you explain lee Huh
« Reply #115 on: January 31, 2009, 22:22:11 pm »
if they are "Urathane" just get rid of them - They will ALWAYS crack  Smiley
« Reply #116 on: February 01, 2009, 02:32:10 am »
i ran red mounts for years no problems!  replaced with solid mounts, now there will be problems!!!!  shake rattle and roll. Grin
roland
lates are the new splits...
« Reply #117 on: February 01, 2009, 18:19:00 pm »
Yeah those red silent blocs are crap, if you're still motivated enough you might wanna change them for original VW ones...
But hey nice job fabs! Wink
« Reply #118 on: February 01, 2009, 18:40:48 pm »
thx roland
« Reply #119 on: February 01, 2009, 19:30:29 pm »
yep what lee and Roland say.
get rid off those red thingies... use originals .
otherwise good job and see you soon.
 Wink
