July 01, 2026, 17:08:55 pm
bigsiembowski
some work
6
7
Topic: some work (Read 122181 times)
Re: some work
Reply #180 on:
March 16, 2009, 21:21:09 pm »
today i remove the left carbs and cleaning this one , nothing special inside this one
here're a few picture of the inside and different parts for those who haven't seen a stromberg carbs
Last Edit: March 16, 2009, 21:47:28 pm by speedwell
Re: some work
Reply #181 on:
March 16, 2009, 21:28:56 pm »
on my needle is written 11 and to be better with my 1200 i need a 9x
Re: some work
Reply #182 on:
March 16, 2009, 21:33:36 pm »
Here is the tank ,where is the fuel with ballcocks and saw the screw(pointeau) for the level of tank
Re: some work
Reply #183 on:
March 16, 2009, 21:41:58 pm »
Here is the pointeau screw(idle screw
) , I had to leave that with the smallest number, that is 1.5, the new one in the repair kit of was 1.75
Re: some work
Reply #184 on:
March 16, 2009, 21:45:12 pm »
here's the oring who goes between the manifold and the adaptators
It seems to me strong to crush, I am going to change him
Re: some work
Reply #185 on:
March 16, 2009, 22:40:26 pm »
Quote from: speedwell on March 16, 2009, 21:45:12 pm
That looks like your problem right there dude - that Oring is not seated correctly
Re: some work
Reply #186 on:
March 17, 2009, 15:12:13 pm »
i will change it
Re: some work
Reply #187 on:
April 05, 2009, 10:26:44 am »
friday i changed the o ring on the left carb ,and nothing special
same noise
, the car doesn't run correctly , and being remembered to me of some thing which wasn't well put on the carb from the right (membrane of the boiseau) , after that the car run very wel ,l no power lost everything turns well , i was happy
but yesterday i turn the key , the engine syatrted well , ok , i put pipes for the breather box he goes for a small trip to enjoy the engine ,no problem
return at house , i said i will adjust the wealth screw , and oups the engine doesn't turn well anymore oh shit
I unsettle the top of the carbu and move the boiseau ,to see if the wealth screw goes up and down well and the absolutely nothing she blocks , ok for the x time i unsettled the carb, have it recleaned, and greased, I put quite back in place, gone back up the whole and always the same thing that does not still work,
Re: some work
Reply #188 on:
April 05, 2009, 10:37:29 am »
i removed the spark plugs to see if she received the voltage from the ignition , I confirm, I felt well him
but after watching the color of the spark plugs they seemed to be new, no black color of carburation, of or I deducts that from it or, there are no sparks in at the sparks plugs, where from the mixture air / fuel doesn't burn, or then the fuel doesn't arrive correctly in the combustion chamber
last thing i will check, will be the ignition we(nicolas & i) will chnage this 010 by an 019 is it a good choice
let me know what do you think
thx
fabs
Re: some work
Reply #189 on:
April 05, 2009, 11:34:38 am »
It is there to understand nothing, I have just taken out the car and everything works
pfff stupid english carbs
yvre
Der Autobahn Scrapers
Re: some work
Reply #190 on:
April 05, 2009, 15:39:39 pm »
Quote from: speedwell on April 05, 2009, 10:26:44 am
same noise
huh???
Go slowly, and change only one thing at a time!
Re: some work
Reply #191 on:
April 05, 2009, 17:49:21 pm »
It works now
it seems that the cylinder (boiseau) inside the carbs sizes sometime.
Re: some work
Reply #192 on:
April 05, 2009, 19:03:01 pm »
Quote from: yvre on April 05, 2009, 15:39:39 pm
same noise
huh???
that's what i 've done yves one thing at a time go to the quick and cox today and the car run "well" some adjust at the carb will be fine
Re: some work
Reply #193 on:
April 07, 2009, 18:51:27 pm »
cool fabs! glad to hear it worked out.
so, the next job is to lower the rear end?
DVK ~
Re: some work
Reply #194 on:
April 07, 2009, 19:23:19 pm »
Yeah, the back end needs to come down some. BTW, your car is now my wallpaper.
Re: some work
Reply #195 on:
April 07, 2009, 21:28:03 pm »
same noise
huh???
VERY VERY good advice dude
Re: some work
Reply #196 on:
April 08, 2009, 12:08:24 pm »
Quote from: 67-indeed/DVK on April 07, 2009, 18:51:27 pm
thx yes we will lower the rear a little
Re: some work
Reply #197 on:
April 09, 2009, 19:02:54 pm »
today nicolas and i worked on the engine ,we made some fine tune on the carbs , and adjust correctly the advance on the 010
after having to replace the boiseau and the needles , the engine turned already well, but we noticed that the boiseau of the right carb didn't come down again profoundly,where from we have still unsettled the carb to see why he didn't lower , and there a small adjustment at the fuel screw(idle jet
) and we go back up the whole
and the engine turns very well
thx for the help nicolas
beetletom
Re: some work
Reply #198 on:
April 09, 2009, 19:27:22 pm »
Quote from: speedwell on April 08, 2009, 12:08:24 pm
2 inner splines!
Re: some work
Reply #199 on:
April 10, 2009, 07:29:50 am »
Quote from: speedwell on April 09, 2009, 19:02:54 pm
no problem, glad i could help and get that thing going again. hope it stays like this and the idle stays like it was running yesterday. always nice to learn new things
Quote from: beetletom on April 09, 2009, 19:27:22 pm
2 inner splines!
nah! that would be an 80's looker, what Fabs is after is a 70's looker and they were quite high to todays standards. but very nice on his car. so it needs to get rid off that positive camber and nothing more.
6
7
