September 22, 2026, 10:57:47 am
| | |-+  berg 5 speed
Author Topic: berg 5 speed  (Read 9667 times)
« on: October 26, 2008, 19:55:29 pm »
i wanted to know what is needed for a complete 5 speed.
right now i am able to buy a kit but there need to be some parts machined by berg or modified. i am not sure what work or price is involved to do all that.
so what i can make up is that it is a 'basic' kit and i still need to have my arms modified by berg. and i also need the pinion for the fifth gear. i am not sure what i am talking about here as i don't know much about the work involved. but all help or insight is welcome.
thanks
« Reply #1 on: October 26, 2008, 21:17:20 pm »
The main shaft and the pinion shaft need to be lengthened by the Bergs.  That should be included in the kit purchase.  You can buy a one piece main shaft from a few different sources so it won't need to be lengthened.  I had mine done a very long time ago.  The cost must be through the roof by now.
« Reply #2 on: October 26, 2008, 22:18:57 pm »
Most cost effective route is to buy a complete trans.... hopefully the gear ratios work in your favor!
Does Berg have the kits in stock right now?
« Reply #3 on: October 27, 2008, 00:23:15 am »
As far as I know the lenthened main sharft comes in the kit - they are no longer " lengthened" they are a new one piece item (so I was told) I'm not sure what else you'll need but keep me posted dude - you know I have an interest in this one Wink Smiley
G-dog
« Reply #4 on: October 27, 2008, 00:50:57 am »
I have a lengthened 5speed mainshaft that I did not use for sale....
Yeah I know-just another 67.....
redbluebug
« Reply #5 on: October 27, 2008, 01:44:49 am »
As far as I know Bergs still lengthen the mainshaft. It depends on what you want your trans to do.  Are you looking for a ultra-close ratio for a high strung, narrow power band?  Or something a little less wild?  In my case I went all out with a new mainshaft.  About $500-550 a couple of years ago, I'm sure it's more now.   You can also have Bergs mate your stock mainshaft with a autostick shaft to make a closer ratio, but then you have a three piece shaft.
In the end how much  $$$ do you want to spend?
Sam K
« Reply #6 on: October 27, 2008, 05:21:23 am »
I did quite a bit of research on 5 speed a coupe years ago and what I was told is that the lengthened mainshafts are fine for a milder engine, but two different people that I know broke them with high HP stroker engines and slicks. In the end, I decided to build a very tough 4 speed with stock ratios since I don't race my car much.
« Reply #7 on: October 27, 2008, 07:59:54 am »
thanks for all the help so far.
i thought indeed it all would be included, but it is not... so that is why i ask all these questions here. the kit is not superexpensive so i thought it is good investment. i could benefit from the longer 5th and safe a lot off fuel from the lower rpms at highwayspeeds. but i am not all to sure if i can get all the parts needed and i am not planning on buying all parts seperately as it would be a lot more expensive to buy everything and have someone put it all together adequately...  Undecided
but if you have the missing parts i am always open to offers so PM me please.
yeah i would like to buy one complete, but i have a good trans now that i could use as a basis and i have found the kit. but if i do find one complete it might be a better option in the end. and i found the set on the net, i have no idea what Berg makes at the moment nor for what price.
i hope i can get more info as i want that 5 speed as well. i don't really know what speeds i can drive once i install my 3.88 RP with a 1.21 th... i hate it getting passed by by stock beetles on the freeway cruising at 4000...  Roll Eyes (maybe i could drive at 5000, steady  Roll Eyes
« Reply #8 on: October 27, 2008, 16:01:23 pm »
I did "hear" that the one piece aftermarket mainshafts for B5s may not be available for much longer.  It was a one time manufacturing run and the sales of them do not warrant another batch.
You can still take a 4 speed aftermarket mainshaft with your custom gears and have it lengthened.
A lengthened mainshaft is no weaker than if it was in a 4 speed.  The extra length is way down at the 5th gear end.  There is no torque transmitted through the joint when in the first 4 gears.
axam48ida
« Reply #9 on: October 28, 2008, 05:53:16 am »
What ratio and how much? also is it for a early or late kit??
« Reply #10 on: October 28, 2008, 21:17:49 pm »
get in line  Grin
« Reply #11 on: October 29, 2008, 01:29:17 am »
Definitely a late kit.  I'm pretty sure it is a 3.78/2.06.
« Reply #12 on: October 29, 2008, 21:13:47 pm »
Nicolas
Do you want the 5-speed for racing or street use ? What engine do you have ?
I have a complete GB 5-speed kit with a new 3,87 ring and pinion including shifter . It only needs a 1,2, gearset and i am thinking about selling it
« Reply #13 on: October 29, 2008, 21:26:35 pm »
Nicolas
the engine right now is a 1776. and i have a build gearbox with some good gears, but 4th is a 1.21 it has been dragraced but rebuild. i do want a berg 5, but i still want to be able to go racing. but not with slicks any time soon and a bigger engine is a bit on hold as well for now. but if i get a 5 speed i hope it can withstand some dragracing. please PM me for details regarding the transmission.
