October 12, 2026, 11:28:09 am
| | |-+  How an ugly restolooker became a nice 54 convertible CAL LOOK
Pages: 1 [2] Print
Author Topic: How an ugly restolooker became a nice 54 convertible CAL LOOK  (Read 46588 times)
67worshipper
« Reply #30 on: October 31, 2008, 21:51:04 pm »
peter that steering wheel cover you got on the cabrio is it red or brown? where did you get it? cheers barry
It is a red one I bought at BadCamberg 2 editions ago... I need to find me a brown or beige one for the convertible, but no luck sofar Sad
if you ever get one in the colour you want id like first refusal on the red one please peter Grin
vw hot rod heaven
« Reply #31 on: October 31, 2008, 21:56:01 pm »
nice job and car peter here're some of mine i took at ddd
peter - belgium
« Reply #32 on: October 31, 2008, 22:04:18 pm »
Awesome pics! Thanks Speedwell Cheesy
Builder of the SLAMBULANCE and all other sort of slam stuff (bus and beetle!)
http://slambulance.skynetblogs.be
http://oval57.skynetblogs.be
www.vwsamba.tk
« Reply #33 on: October 31, 2008, 22:08:32 pm »
awesome car  Wink
JeePee/DVK
« Reply #34 on: November 01, 2008, 13:12:38 pm »
Nice car indeed Peter.
Can you tell me what type of Volvo reservoir this is?
peter - belgium
« Reply #35 on: November 01, 2008, 16:03:31 pm »
I do not know the exact type, it is one I found that has the same diameter rubbers as my VARGA dual master so it fitted outright.
I have several reservoirs I use for splitscreen dual circuit converisons, but these did not fit the VARGA MC (although they should fit the beetle ATE dual masters)
www.vwsamba.tk
Jeff / DBR
DER BRÜCKENRENNERS
« Reply #36 on: November 02, 2008, 18:16:45 pm »
I used a reservoir from a late Ford Granada, fits perfect!!
Hotrodvw
« Reply #37 on: November 02, 2008, 18:17:41 pm »
The reservoir os from a 240D volvo........80's I beleive.  Beautiful car by the way!   Cool
« Last Edit: November 02, 2008, 18:25:07 pm by Hotrodvw » Logged
Hose & Fittings
'67 Sunroof
www.ultimateaircooled.com
peter - belgium
« Reply #38 on: November 02, 2008, 21:42:14 pm »
Thanks dudes!
Here are some more movies Grin
Gino the paint master at work, painting the body
<a href="http://www.youtube.com/v/UUCZE8gTYEM" target="_blank">http://www.youtube.com/v/UUCZE8gTYEM</a>
Painting the wings
<a href="http://www.youtube.com/v/Eut6qX_OvdE" target="_blank">http://www.youtube.com/v/Eut6qX_OvdE</a>
And the converts first testdrive
<a href="http://www.youtube.com/v/BgHkaEwg1AA" target="_blank">http://www.youtube.com/v/BgHkaEwg1AA</a>
Driving with a very sleepy girl in the back Grin
<a href="http://www.youtube.com/v/9O4RoaxWWVQ" target="_blank">http://www.youtube.com/v/9O4RoaxWWVQ</a>
« Last Edit: November 02, 2008, 21:46:43 pm by peter - belgium » Logged
www.vwsamba.tk
peter - belgium
« Reply #39 on: November 03, 2008, 14:08:28 pm »
Hey Guys,
I just installed the 3th (in 1000km time) intermediate (and very stock) engine, and I still need to build a basic cal-look looking 1600cc engine for the convertible to get me around till next year so I have some more time gathering and preparing all the proper parts for the 2110cc.
So what I had in mind is:
- Stock 1600cc parts (maybe some weight balancing of rods and pistons, not fully balancing)
- Case full flowed only for external filter. Keep the standard cooling system as it is.
- Standard, blueprinted oil pump
- Standard dual-port heads  (maybe some mild porting on inlet ports and with cc’ing the chambers)
- Cam:  -> I have an original cam, an Engle 110, 120, FK87 and a SCAT C35    recommendations?
- CR??   Recommendations here?
- Carbs:   I have a set of 40 Webers with 28mm vents + a set of 36Webers with 32mm vents  … which set to use? (and the 40weber don’t have those locking screws for the vents so not sure if I can change them out???)
- Lightened flywheel with standard 200mm clutch
- Bosh 010
- Straight cut cam gears? Or just keep the original style?
- Standard lifter or  1.25:1 lifters on HD shafts?
- Would a 1641cc cylinder kit gain much?
- Heat exchangers with standard 4in1 modified to accept my merged INOX header => I want heat in my VW for a change, never had this before:-)
The goal is to just have a nice running engine built with parts I have that will get me to where I want to go. I do not want a high revving, high output, high maintenance engine. That I will keep for the 2110cc Grin I just want a good looking and reliable engine…
Thanks for your thoughts and input!
www.vwsamba.tk
LGK
« Reply #40 on: November 03, 2008, 23:56:42 pm »
I saw the car in real yesterday,amazing paintwork done in "open air"...  Wink Wink
Really nice cab.
For the engine; Go stock cam,mild work on the chambers,3-anlge valve job, 8.5/1 with 36carbs on top.You won't be disapointed/
Steve
peter - belgium
« Reply #41 on: November 04, 2008, 10:48:20 am »
Thanks for the compliment Steve!!
Although the convertible has been prepped and painted in a barn, I think it can stand proudly next to a “professionally” painted car.
I’m very proud of my work since I’m not the body man and I do not really like that part of the resto (I prefer the welding and mechanical jobs!) but I did all the welding, prep work, straightening, primer, sanding, … on this convertible and then had fellow club-member Gino do the final color spraying. With some polishing here and there it turned out great
Thanks for the engine tip. I was also thinking of keeping things as mild and simple as possible on this engine since later on this will be my emergency back-up engine in case me (or a clubmember) needs to spare engine for a while. I will check what to do with that F*c% U# set of heads!
Small question for the carbs, 36Weber with which vents?? If I need to use the 28mm out the 40webers, can I just pull them out… since there is no locking screw on these I assume they are pressed in??
www.vwsamba.tk
JSL
« Reply #42 on: November 06, 2008, 17:19:49 pm »
Absolutely stunning!!! Well done! You make it look all so easy! Hehe
James
peter - belgium
« Reply #43 on: November 23, 2008, 20:29:36 pm »
Another part done, my PBW linkage!
I wanted a robust linkage based on the original speedwell design (and therefore Gene Berg, who used Speedwell design as well), but with all joints on bearings for an accurate operation, because that is what is fundementally wrong with the GB linkages (at least... that is my opinion)!
The design phase: double checking all measurents
Polishing all parts
Assembly
All done!
And with my new breather box as well
Nice and shiny, hé Cool
www.vwsamba.tk
airstuff
« Reply #44 on: November 23, 2008, 22:15:18 pm »
just incredible Shocked
« Reply #45 on: November 23, 2008, 23:30:15 pm »
holy crap, that's some skills you have Wink
« Reply #46 on: November 23, 2008, 23:46:25 pm »
Nice work!!
Doktor
« Reply #47 on: November 24, 2008, 09:06:59 am »
That linkage looks very nice !
Great work dude !  Grin
dr.aircooled
peter - belgium
« Reply #48 on: November 24, 2008, 09:47:14 am »
I also like the looks Grin
Now lets hope it performs as well as it looks! It will soon be tested in Gino’s Cote d’Or panel on his freshly built 1915cc engine!! See the animation picture made by Kama of Gino’s panel:
www.vwsamba.tk
peter - belgium
« Reply #49 on: December 21, 2008, 22:47:20 pm »
Some new work done...
front beam removed to make place for a 4" narrowed beam so I can fit my CSP disks with the sprintstar wheels
Testfitting here
And primered and painted
And the CB performance spindles prepared for installation
And the wheels are blasted and primered. 4" for the front, 5,5 for the rear
www.vwsamba.tk
peter - belgium
« Reply #50 on: May 24, 2009, 20:19:16 pm »
Some updates happened!
The SPRINTSTARS got detailed by Dr. Detail Philip. I hope to get tyres for it this coming weekend!
Chrome versus painted
I also got a cover for the open top! Always handy with this sunny weather Cool
Check-up and finetuning at Steves VW shop. Just to make sure we can make it to the VoWo show!
<a href="http://www.youtube.com/v/McSaplErjLY" target="_blank">http://www.youtube.com/v/McSaplErjLY</a>
« Last Edit: May 24, 2009, 20:33:46 pm by peter - belgium » Logged
www.vwsamba.tk
peter - belgium
« Reply #51 on: May 24, 2009, 20:22:13 pm »
And we made it to the VolksWorld show!!
On the way home again after a great weekend!!!
www.vwsamba.tk
peter - belgium
« Reply #52 on: May 24, 2009, 20:27:03 pm »
Strange at how the color looks different in different pics:
www.vwsamba.tk
peter - belgium
« Reply #53 on: May 24, 2009, 20:32:10 pm »
<a href="http://www.youtube.com/v/ADEygSYY4VI" target="_blank">http://www.youtube.com/v/ADEygSYY4VI</a>
www.vwsamba.tk
« Reply #54 on: May 24, 2009, 21:46:47 pm »
Superb ! Will look great with og Sprintstars. Cool
ESH
« Reply #55 on: May 24, 2009, 21:51:04 pm »
That was a long drive back from the show!  Shocked  Grin
Cool car.  Cool
peter - belgium
« Reply #56 on: May 31, 2009, 20:26:50 pm »
 Grin that is with all that left driving I suppose Grin
I installed my new wheels and tyres today, just need to take some pics! But the 205/70 tyres at the back are looking much better!!
www.vwsamba.tk
peter - belgium
« Reply #57 on: June 03, 2009, 22:26:28 pm »
New wheels, bigger tyres at the back  Grin
Looks better!
www.vwsamba.tk
JeePee/DVK
« Reply #58 on: June 06, 2009, 00:37:06 am »
It looks much better,I like it. Cool
Pages: 1 [2] Print
