October 12, 2026, 09:15:17 am
| | |-+  My >street/<strip '56
Pages: 1 ... 4 5 [6] 7 8 ... 28 Print
Author Topic: My >street/<strip '56  (Read 922141 times)
fahrvergnugen
« Reply #150 on: August 10, 2009, 20:20:17 pm »
"old man"  Shocked  Grin .
You lazy kids?, seems like the old guy's have to do all the work Wink
Cheers,
Paul.
fahrvergnugen
« Reply #151 on: August 10, 2009, 20:24:58 pm »
paul you also got me looking every time
i like what you are doing.....
Thanks Hans, appreciate it.
Looking forward to your update.
Paul.
fahrvergnugen
« Reply #152 on: August 13, 2009, 07:08:15 am »
The beam sits on its final place, just tackwelded for now.
Closed the bottom of the framehead and fliped the pan again.
Paul.
« Last Edit: August 13, 2009, 07:10:34 am by fahrvergnugen » Logged
fahrvergnugen
« Reply #153 on: August 13, 2009, 07:10:10 am »
I had to do some measuruing again, just to be sure Wink
Put on the new urethane bushes and placed the a-arm, the front mounts wil be in the spare wheel area.
Paul.
fahrvergnugen
« Reply #154 on: August 19, 2009, 19:21:28 pm »
After I dropped the Porsche beam in the frame head, I had some gabs tp fill.
Made 2 pieces out of 3mm sheetmetal and welded them around the beam.
Paul.
« Last Edit: August 19, 2009, 19:24:28 pm by fahrvergnugen » Logged
fahrvergnugen
« Reply #155 on: August 19, 2009, 19:30:18 pm »
Now it is time to build a jig so that I can copy the Porsche mounting points to the beetle pan.
fahrvergnugen
« Reply #156 on: August 19, 2009, 19:31:52 pm »
Left front, back and upper mounting point where it should be.
Paul.
« Reply #157 on: August 20, 2009, 05:02:19 am »
are the upper strut mounts going to clear the hood?? looks high in the picture
fahrvergnugen
« Reply #158 on: August 20, 2009, 06:45:18 am »
I sure hope so Embarrassed . It only looks high in the picture, the original (Porsche 914) is verry low at the front.
Paul.
fahrvergnugen
« Reply #159 on: August 26, 2009, 20:15:11 pm »
Shubee2's post made me a little worry, so yesterday I started measuring again  Embarrassed.
All looks good the hight and even the width fits in/unther the innerwings.
Then I finished the right front suspension mounting points (and did the left side over again Embarrassed) then I cut the 914 innerwing piece to the wright width and welded it together.
Fixed the innerwing piece with some temp. steel and bolted the complete right suspension on.
I must say, I am pretty pleased with the result so far. Cool
jamiep_jamiep
« Reply #160 on: August 27, 2009, 09:50:47 am »
Impressive!
fahrvergnugen
« Reply #161 on: August 27, 2009, 11:10:53 am »
Impressive!
Thanks, progress is slow but i'll get there.
Paul.
fahrvergnugen
« Reply #162 on: August 29, 2009, 13:19:21 pm »
After I finished welding the Porsche innerwings together and smooted the weld, it was time to take a piece of '66, bolt a fender to it, start cutting and see how it all fits.
Again; I am so pleased with the result Cool
Paul.
tikimadness
« Reply #163 on: August 29, 2009, 16:12:10 pm »
Good work Leepu!! Grin Grin Grin
Michael
NIDGAFWYT
Black Sheep
less is more
« Reply #164 on: August 29, 2009, 16:14:26 pm »
Nice , that looks like it grew there  Cool
« Last Edit: August 29, 2009, 16:20:27 pm by 49-rag » Logged
13.03 @ 98mph
fahrvergnugen
« Reply #165 on: August 29, 2009, 20:15:53 pm »
It did, now I am waiting till the rest of this beetle will grow on. Grin Grin
Paul.
fahrvergnugen
« Reply #166 on: August 29, 2009, 20:17:39 pm »
Michael
I went to the zoo for some inspiration Grin
Paul.
fahrvergnugen
« Reply #167 on: September 02, 2009, 20:18:47 pm »
It was time to start with the steering and ride hight, but first it seems like a good idea to see it on the ground with 4 wheels on it.
And indeed, this was a good plan Cry
The first problem i saw when it was on four wheels; this thing is pretty narrow for a circuit/drag/street car Shocked
Second problem; a bid of camber is nice, but this is cray Shocked, Back to the drawing board. Embarrassed
This is what I want;
Camber =>  Front -1 deg   - Rear -1.5 deg
Caster   =>  Front 6-7 deg - Rear  N/A
Toe      =>  Front 0 deg    - Rear -15' (toe-in)
Paul.
kev d
« Reply #168 on: September 02, 2009, 22:37:10 pm »
Hi Paul,
Just a thought, is the distance between the strut tops & lower wishbones standard?
Also has the angle of the struts (forward & back) been retained?
If you can keep the distances and angles `factory` the camber etc should be ok, if the track width has been modified it should still work as long as the upper & lower mounting points have been moved an equal amount (within reason), although bump steer may become an issue if the steering rack pivot points no longer correspond with the wishbone pivots.
Thats when it becomes an engineering job way beyond me! Grin
A set of wheels with a different offset will cure the `narrow` look though.
Cheers,
Kev
fahrvergnugen
« Reply #169 on: September 03, 2009, 07:35:12 am »
Hi Paul,
Cheers,
Kev
Hi Kev,
The track width has been modified and the upper & lower mounting points have been moved an equal amount, at least thats what I thought I did Embarrassed
When all the wheel angles are like I whant them to be, I will start with the steering. This will be special made to avoid bumbsteer. The width can/will be adjusted with offset and spacers.
Paul.
JSL
« Reply #170 on: September 03, 2009, 13:54:26 pm »
Hey,
Just wanted to say this is such an awesome thread! Love following this! Really hope it all works out!!
Cheers,
J
fahrvergnugen
« Reply #171 on: September 03, 2009, 19:47:46 pm »
Thanks J,
It will work out, just need to do things slow and sometimes twice Embarrassed
Paul.
PS. still don't want to tell me what collor your car is? Grin
« Last Edit: September 03, 2009, 19:56:33 pm by fahrvergnugen » Logged
JSL
« Reply #172 on: September 03, 2009, 20:29:22 pm »
Hahahaha! Was that you!!
Hehehe It depends who gets to paint first!!  Grin
I know its silly, just dont want to be accused of copying someone, anyway your a little way off needing paint just yet  Wink When your closer to to needing paint lets talk  Grin
What your doing is awesome dude! Loving the build!
Cheers,
J
fahrvergnugen
« Reply #173 on: September 03, 2009, 20:58:02 pm »
Cheers,
J
Yep that was me Cheesy
Indeed I don't need paint yet, don't worry when I need paint (and I still haven't chainged my mind) we will talk Kiss
Thanks again.
Paul.
67pickup
« Reply #174 on: September 05, 2009, 14:28:14 pm »
Amazing work and innovation, never heard of anyone doing this before! Good luck, I'm impressed!
fahrvergnugen
« Reply #175 on: September 05, 2009, 19:45:46 pm »
Amazing work and innovation,  Good luck, I'm impressed!
Thanks.
Thats one of the things why I like this idea Cool
Paul.
fahrvergnugen
« Reply #176 on: September 05, 2009, 20:00:07 pm »
To fix the camber problem I was thinking of narowing the lower beam and fill it out with spacers, after measuring this meant that I needed 4cm spacers on each side Shocked. I DON'T WANT 4CM SPACERS Angry.
I started measuring the oval body again, and I seem to have 6cm width more than I thought Tongue.
I widened the upper strut with 6cm and after some fidling with the upper adjusting I have a -1deg. camber reading on my digital angle thing. Cool
Black Sheep
less is more
« Reply #177 on: September 06, 2009, 09:34:06 am »
That looks better  Cool how are you planning on mounting the forward A arm mounts ?
 Would think this is gonna need quite a substantial bit of engineering bolted up to the frame head  Wink
13.03 @ 98mph
fahrvergnugen
« Reply #178 on: September 06, 2009, 09:53:06 am »
They will be welded in the spare wheel area and bolted to the cage.
Paul.
Josef
« Reply #179 on: September 06, 2009, 10:33:01 am »
Nice project!!
When I look at your work and your innovations it motivates me to go on with my plan för my car.
/Josef
