October 13, 2026, 00:33:54 am
| | |-+  My >street/<strip '56
Pages: 1 ... 12 13 [14] 15 16 ... 28 Print
Author Topic: My >street/<strip '56  (Read 923828 times)
« Reply #390 on: August 18, 2010, 17:48:10 pm »
Nice work!
Here is a little tip about Wolfparts new part:
fahrvergnugen
« Reply #391 on: August 18, 2010, 19:31:05 pm »
Nice work!
That really looks good, but I can weld a lot for € 197,-- each side Wink
Paul.
« Reply #392 on: August 19, 2010, 00:10:34 am »
I hear you loud and clear Cheesy
fahrvergnugen
« Reply #393 on: September 08, 2010, 20:57:20 pm »
not much done lately. vacation and a little boy's birthday on my weekly beetle day, but the biggest time goes to restoring the corner on the end of the heaterchannels, what a PITA.
The original form was long gone, so I had downloaded some pictures and started modeling metal.
It's a corner you can't see when the car is ready, but I like it to look original.
Paul.
fahrvergnugen
« Reply #394 on: September 11, 2010, 18:56:31 pm »
Finally finished the left corner. When the body is back on the channels I will cut the corners at the wright length.
Nice fit, only have to grind the welds down and use some lead to smooth things.
On to the right site.
Paul.
« Reply #395 on: September 11, 2010, 19:26:39 pm »
Hi Paul Are you going to Hook up A Heater? are you going to need to Relocate the Heater Channel Tubes looks like are going right in to the torison housing?
fahrvergnugen
« Reply #396 on: September 11, 2010, 19:47:47 pm »
Heating is for sissy's, I cut the tubes on the outside and will weld them shut (rear suspension is in the way) on the inside they will stay for the original look Wink
Paul
« Reply #397 on: September 11, 2010, 21:50:19 pm »
Heating is for sissy's, Wink
Paul
I will Remind you of that when you are freezing your a** off LMAO!!  Grin Grin
fahrvergnugen
« Reply #398 on: September 12, 2010, 08:22:44 am »
Paul
Grin
I live in the warm south of the Netherlands. Tongue
BossHogg76
« Reply #399 on: September 17, 2010, 11:10:19 am »
I've only just joined this site, and have spent a thoroughly interesting hour reading through your thread, it's amazing work.
fahrvergnugen
« Reply #400 on: September 17, 2010, 11:28:16 am »
Thanks, and welcome.
Paul.
fahrvergnugen
« Reply #401 on: October 02, 2010, 13:52:42 pm »
After 3 week doing nothing on the car, I finally started again.
The left crosmember is ready, so it is time to start on the right side.
This is where I started with.
And the result after hammering, grinding, bending, cutting and welding a few hours.
Almost there Cool
Paul.
« Last Edit: October 02, 2010, 13:55:26 pm by fahrvergnugen » Logged
fahrvergnugen
« Reply #402 on: October 09, 2010, 16:40:32 pm »
Finally the crosmember is done, When the body is on it's place i will modify the endpieces of the crosmember and probably do the bumb over again.
The heaterchannel was to long on the front and to short on the rear, I did not want to redrill my floor so I had to dismantle the channel.
The bottom of the channel will be mounted on the floor and then make the top fit.
Looks nice on the inside
Now that I opened the channel, I bare metaled the bottom and I will put some decent paint on it
Paul.
« Reply #403 on: October 09, 2010, 21:42:39 pm »
Wise move, and as always, great work!
fahrvergnugen
« Reply #404 on: October 10, 2010, 08:50:05 am »
I am also glad I did this, Thanks.
« Reply #405 on: October 10, 2010, 18:20:38 pm »
x2 !
fahrvergnugen
« Reply #406 on: October 10, 2010, 19:39:24 pm »
x2 !
 Kiss
fahrvergnugen
« Reply #407 on: October 13, 2010, 20:01:33 pm »
Sanded the inside of the heaterchannel, thought about polishing it but went for paint instead Grin. Also welded some extra strength in the seatbelt mount, I am not sure I am gonna use it tough.
fahrvergnugen
« Reply #408 on: October 16, 2010, 20:23:11 pm »
After I painted the inside and bottom of the channel, I sprayed antirust on it and some inox spray on the welding areas. Now it was time to fit it in it's new position..
I placed the channel 1/2 an inch backwards on the bottomplate.
Back fits like a glove now.
The firewall can be mounted without a problem
Paul
« Last Edit: October 18, 2010, 11:43:25 am by fahrvergnugen » Logged
fahrvergnugen
« Reply #409 on: October 27, 2010, 20:39:55 pm »
Finally the channel is ready, but after welding and grinding it was torn a lot Angry
So I fixated the channel and fired up the torch, after it was heated I tried to torn it back.
And that worked.
Next step is the firewall, I decided to use and repair the leftovers Tikimadness donated.
Paul.
fahrvergnugen
« Reply #410 on: October 30, 2010, 20:01:48 pm »
Today I cleaned up the firewall that was cut out of a '54. The firewall or innerwings where replaced or repaired in the past, it was not spotwelded but had a lot of welds around the edges. But it came out pretty nice.
This firewall was cut out because of it's weight, but the heaterchannels had to stay. this is why I had to repair the corners, it was not rusted but cut around the heaterchannels.
Paul.
fahrvergnugen
« Reply #411 on: November 06, 2010, 14:28:19 pm »
Done Cool
Paul.
fahrvergnugen
« Reply #412 on: November 10, 2010, 21:24:41 pm »
After some grinding, bending, drilling and a lot of hammering, the left channel fits properly.
Dereck
« Reply #413 on: November 10, 2010, 22:50:16 pm »
Super neat work
Follow me on Twitter: http://www.twitter.com/vondirk
Follow the progress of my Project '66: http://wackyracers.posterous.com/
JSL
« Reply #414 on: November 11, 2010, 10:15:36 am »
I love these updates!!!
Coming along beautifully!  Grin
J
fahrvergnugen
« Reply #415 on: January 12, 2011, 21:16:58 pm »
Found some time to work on the car again Cool
The underside of the left doorpillar was bad, of course Angry
time for a Hoekie of Hooky Smiley
First I had to shorten it, this way the bracing could stay in it's place.
fitting
It only needs some welding. Cool
Paul.
fahrvergnugen
« Reply #416 on: January 15, 2011, 14:48:31 pm »
This morning it was time to finish the doorpillar.
Welded the hooky piece.
Normally you can not reach the inside, mine is still open and it is double sheetmetal so I also welded the inside.
Then I dismantled the door (this is very heavy with all the parts and glass in it) and checked the gap, I must say ; I am very pleased with it.
Paul.
fahrvergnugen
« Reply #417 on: February 17, 2011, 20:27:06 pm »
Not much time lately, but still a Little progress.
This piece of the trunk was a little thin, also the holes didn't mach the new kick panel. so I replaced the top of the kick panel by a wider piece, this way I can close (weld) all the holes.
Paul.
fahrvergnugen
« Reply #418 on: February 17, 2011, 20:31:02 pm »
All the holes are closed again. before paint I will put some lead filler on it and it will be as new again, offcourse I will do the corners first.
« Reply #419 on: February 18, 2011, 13:16:00 pm »
I'll say it again but it's an impresive bodywork  Cool
