September 22, 2026, 13:30:47 pm
| | |-+  My >street/<strip '56
Pages: 1 ... 18 19 [20] 21 22 ... 28 Print
Author Topic: My >street/<strip '56  (Read 908130 times)
fahrvergnugen
« Reply #570 on: January 02, 2013, 21:48:03 pm »
New year, new workshop  Cool
The project who used the most welding wire, got the biggest space. I won Grin
Paul.
fahrvergnugen
« Reply #571 on: February 20, 2013, 21:23:54 pm »
Finally did some work on VWrankenstein again.
Started working on the upper Shock mounts
Took out the rubber, shortend the the Porsche mount and made a plate to close the underside of the Porsche mount.
Test fit the bearing Busch
Underplate fits like a glove.
After some welding and grinding, I fitted the bearing. Looks pretty original. This bearing fits the Golf1 shocks perfectly
Bottomview
Paul.
fahrvergnugen
« Reply #572 on: February 22, 2013, 21:40:31 pm »
Today again found some time for VWrankenstein.
To make sure there was enough space for wheel movement I bought Golf1 shocks. The Golf1 shock are about 5,5cm shorter.
Here's the difference.
Now the struts had to be shortend too.
And again some trail fit. (I used the wrong (too big) wheels)
Paul.
thehanz DVK
« Reply #573 on: February 22, 2013, 21:45:01 pm »
Goed bezig jonghu
Looking good Paul...always like to read your progress
fahrvergnugen
« Reply #574 on: February 22, 2013, 21:52:19 pm »
Thanks Hans,
Good to hear that from a perfectionist Cool
fahrvergnugen
« Reply #575 on: February 23, 2013, 15:57:33 pm »
Today I started by fixating the front wheel (brakedisk) at the wright camber and caster.
Made the innerwing mount to fit the innerwing, fixate everything again and made the first tackwelds. It's coming along just fine I think.
Paul.
Black Sheep
less is more
« Reply #576 on: February 23, 2013, 19:05:46 pm »
 I know your not finished yet Paul but I'd be looking to tack some strengthening webb's to those towers , as I'm not sure the shape of the inner is quite up to the potential extra pounding from the shock tops  Undecided
Looking good though bud  Cool
13.03 @ 98mph
fahrvergnugen
« Reply #577 on: February 23, 2013, 19:13:42 pm »
Thanks Glenn,
The roll cage is gonna take care of the extra strength. Wink
Black Sheep
less is more
« Reply #578 on: February 23, 2013, 20:55:45 pm »
OK cool , I did wonder if you could put a cross brace in top to top ? should help matters a bit .
13.03 @ 98mph
fahrvergnugen
« Reply #579 on: February 23, 2013, 21:13:53 pm »
Yep, the cage will run from under the dash to the top mounts and will end in the spare wheel well, on the A-arm front mounts. from top to top will be a removeble brace.
fahrvergnugen
« Reply #580 on: March 02, 2013, 14:27:02 pm »
The horn bracket had to move, no suprise what was under there.
So a little repair was needed.
The right front suspension is ready (for now), so it's time to start doing it all again on the left side.
Paul.
fahrvergnugen
« Reply #581 on: March 09, 2013, 14:13:26 pm »
Change of plans. I wasn't happy with the A-arm mounts I made in the spare wheel well, so I took out the grinder and started all over again.
No way back now.
Made a new spare wheel well bottom. I will make a lower part in the middle for the battery.
Paul.
fahrvergnugen
« Reply #582 on: March 13, 2013, 15:09:49 pm »
The new plan is getting shape.
Paul.
kev d
« Reply #583 on: March 13, 2013, 22:53:00 pm »
Looking good Paul Cool
Kev
fahrvergnugen
« Reply #584 on: March 14, 2013, 20:16:53 pm »
Kev
Thanks Kev  Wink
fahrvergnugen
« Reply #585 on: March 23, 2013, 13:40:51 pm »
Today I copied the right A-arm mount to the left.
Now it's time to weld it, grind it and weld it in place.
Paul.
tikimadness
« Reply #586 on: March 23, 2013, 15:28:18 pm »
Paul.
Hurry up you slacker Grin Grin
Michael
NIDGAFWYT
fahrvergnugen
« Reply #587 on: March 23, 2013, 21:32:08 pm »
Paul.
Michael
I'm working on it, not sitting on my ass in London  Grin
tikimadness
« Reply #588 on: March 23, 2013, 21:49:15 pm »
I've actually been  working over here. I even sold a car that wasn't even mine Grin Grin
Bringing back a lot of cool stuff.
Michael
NIDGAFWYT
fahrvergnugen
« Reply #589 on: March 23, 2013, 22:17:18 pm »
Michael
Selling other peoples car is easy :-)
Have à good one mate.
fahrvergnugen
« Reply #590 on: March 29, 2013, 21:22:39 pm »
Spare wheel well is in place and welded, almost ready for the next challance
Paul.
kev d
« Reply #591 on: March 30, 2013, 20:25:58 pm »
That new wheelwell looks much better Cool
Getting there!
fahrvergnugen
« Reply #592 on: March 30, 2013, 22:13:15 pm »
Getting there!
Thanks Kev, my thoughts exactly.
fahrvergnugen
« Reply #593 on: April 13, 2013, 21:32:10 pm »
Time to close the sides of the spare wheel well (inner wings)
Made a new sheet metal piece and welded it in place.
All nice again
Fitted the left A-arm so that I can start on the upper mount. Also tried the Porsche skitplate. It's a small piece to protect the front of the torsiontube.
Next step; change the front strut again. Now I will weld the top piece of a golf strut to the Porsche strut. This way the golf shocks will axially fit
Paul.
fahrvergnugen
« Reply #594 on: April 17, 2013, 12:54:16 pm »
On the left side the hood releasecable has to move
The hood releasecable will run on the front of the topmount, you can also see the top of the shock coming through the innerwing.
Starting to look like where getting there.
Paul.
fahrvergnugen
« Reply #595 on: April 20, 2013, 13:46:33 pm »
Bit more done to the frontwheel suspension.
Paul.
Andy Sykes
« Reply #596 on: April 20, 2013, 16:26:55 pm »
Nearly there now  Grin
fahrvergnugen
« Reply #597 on: April 20, 2013, 19:49:34 pm »
You funny guy. Tongue
fahrvergnugen
« Reply #598 on: April 27, 2013, 13:20:50 pm »
That's about right.
Shortend the other side and welded the golf1 piece on top.
Paul.
mr horsepower
« Reply #599 on: April 27, 2013, 19:11:00 pm »
Nice work dude
Let me know when youre done.
Then we will race .
Gr henri
