October 12, 2026, 14:00:51 pm
Pages: 1 ... 5 6 [7] 8 9 ... 28 Print
Author Topic: My >street/<strip '56  (Read 922678 times)
fahrvergnugen
« Reply #180 on: September 06, 2009, 12:45:23 pm »
Nice project!!
When I look at your work and your innovations it motivates me to go on with my plan för my car.
/Josef
Thanks Jozef,
Sometimes you need some motivation, I usualy get it at DDD, EBI etc.
Can we see your project somewhere, Always nice to see other projects Wink
Cheers Paul.
Josef
« Reply #181 on: September 06, 2009, 13:08:09 pm »
I have som photos from my project but they are taken before the digital era.
If I got the time i will try to make them digital.
New pics will be posted under my "Sleeping beauty" thread.
/Josef
fahrvergnugen
« Reply #182 on: September 06, 2009, 19:18:02 pm »
/Josef
Oh, Is that your trhead.
I will keep my eye on that one. Cool
fahrvergnugen
« Reply #183 on: September 12, 2009, 20:39:25 pm »
Today it was time to start with the steering.
The plan is to use a 1303 pivot to avoid bumbsteer. First I had to make a steeringbox arm fit the pivot, to do this I used a piece of an old steeringbox axle.
« Last Edit: September 12, 2009, 20:41:13 pm by fahrvergnugen » Logged
fahrvergnugen
« Reply #184 on: September 12, 2009, 20:50:30 pm »
Time to try some things Cool
Welded a piece of pipe to the framehead and bolted the steering box, the steering rod is exactly horizontal and perpendicular to the chassis.
Also tacked the pivot in place, the plan is to connect the pivot with the steeringbox, and have a smal rod to the spindles.
Paul.
« Reply #185 on: September 13, 2009, 05:22:28 am »
Paul.
Why not use a Rack & Pinion instead of a stock steering box?
fahrvergnugen
« Reply #186 on: September 13, 2009, 10:02:16 am »
This way I can make the width exactly as I want it to be, an original rack&pinion will be to big, I want the place where the rods are attached to the steering box exactly above the center of the circle that the wheels make when they move up and down.
Paul.
Sven/DFL
« Reply #187 on: September 20, 2009, 13:32:08 pm »
Hey Paul,
Realy nice work! Very impressiv! I´m looking forward to see some more pictures!!!
Sven
fahrvergnugen
« Reply #188 on: September 21, 2009, 11:34:37 am »
Hey Paul,
Sven
Thanks Sven,
As soon as I have time to work on it, I will post again.
Paul.
fahrvergnugen
« Reply #189 on: September 23, 2009, 20:27:29 pm »
between drinking beer, smoking sigarets en talking about DDD#7 (couldn't be there this year Sad), I found a little time for the oval.
Made a longer pipe to mount the steering box at one side and the pivot on the other side, and welded it in place.
It needs some more work, but it's a start.
Paul
fahrvergnugen
« Reply #190 on: September 26, 2009, 19:42:36 pm »
Did some more work on the steering today. To make sure I can remove the pivot when the car is finished, I drilled the trhead out of the pivot and welded nuts on the pivot bracket, This way it is bolted from the outside. Then I shortend the two short steering rods by cutting more thread and then cut it the wright lenght. The longer (middle) rod is cut in the middle, shortend and, after I put in some massive stee,l welded together again.
Hope it works Undecided
« Reply #191 on: September 27, 2009, 02:11:44 am »
Did some more work on the steering today. To make sure I can remove the pivot when the car is finished, I drilled the thread out of the pivot and welded nuts on the pivot bracket, This way it is bolted from the outside. Then I shortend the two short steering rods by cutting more thread and then cut it the wright length. The longer (middle) rod is cut in the middle, shortend and, after I put in some massive steel,l welded together again.
Wouldn't  it be better to flip the pass side arm with the tall side in? that way the Wheels turn the same and it would center the center link evenly??
fahrvergnugen
« Reply #192 on: September 27, 2009, 08:35:16 am »
After looking at my own pic's I was thinking the same, probebly do that Wink
Cheers, Paul.
fahrvergnugen
« Reply #193 on: October 03, 2009, 15:08:28 pm »
I wasn't satisfied with the steering (the rod came in line with the spindle wile the wheels should steer some more), so today I cut out the beam where the steeringbox was mounted on, and placed it further to the front of the car. Now, even when I steer al te way, the rod still has an angle with the spindel.
Paul.
mychatype3
« Reply #194 on: October 04, 2009, 06:19:11 am »
He Paulskie,
hello from the usa, looks good  Wink
Greetings mycha
1968 fastback "in resto"
fahrvergnugen
« Reply #195 on: October 04, 2009, 13:00:01 pm »
He Paulskie,
Greetings mycha
Thanks Mych,
How's Vegas?
Paul.
fahrvergnugen
« Reply #196 on: October 10, 2009, 14:18:09 pm »
While I am still waiting on the last parts for the front suspension, I started with the gearshift system.
I am using a 901 box with the selecter on the undersite of the box, that is why I was thinking to use a cable shift system.
I bought a VW Corrado shifter, and today I started trying some things, it's not finished but you'll get the idea.
fahrvergnugen
« Reply #197 on: October 15, 2009, 20:09:07 pm »
Did some more work on the shifting today.
Made two brackets and installed them, needs some adjusting but I think it can work Cool
Paul.
fahrvergnugen
« Reply #198 on: October 23, 2009, 20:33:20 pm »
When the car is ready I will probebly run it with my type4 2.0 120HP engine, this egine runs very well and is ready to go.
But in the near future I (offcourse) want to be faster, and because the car is not one off the shell the motor also will be different.
So I started collecting some parts;
WBX 1.9 engine.
Megasquirt motor management system.
A probebly to small turbo (golf 1.8 20V)
Water to air intercooler from a Mercedes
Porsche 964 100mm nikasil P/C
Scat split-ports with twin spark (airplane)
And lost of small parts.
Paul.
« Last Edit: October 23, 2009, 21:52:29 pm by fahrvergnugen » Logged
tikimadness
« Reply #199 on: October 23, 2009, 21:02:36 pm »
Hey paul how are you going to make all those different parts to work together?
Put everything in a kettle and cook it for half an hour and see what will come out? Grin Grin
Seriuosly you bought xsome nice stuff hope it will work together.
Michael
NIDGAFWYT
fahrvergnugen
« Reply #200 on: October 23, 2009, 21:49:40 pm »
Michael
Don't these parts fit Cry I thougt it was a plug and play thing, you say it's more plug, pray run and hide Grin Grin
sam P
« Reply #201 on: October 24, 2009, 00:27:16 am »
Wow, those heads look like they've got some serious potential! Lose the twin spark and get some bigger valves in there!  Grin
Love what you're doing. Not an easy project. Good luck!
fahrvergnugen
« Reply #202 on: October 24, 2009, 12:06:08 pm »
The valve size is 40 and 35,5mm i think it's good for a 2,1 turbo.
It's not easy indeed, but it's nice to try something different Cool
Paul.
fahrvergnugen
« Reply #203 on: October 26, 2009, 20:59:13 pm »
Today a bought an 2,1 WBX engine, just for the 76,4mm crank  Shocked
So the new engine will be a 2,4 Cool
Paul.
fahrvergnugen
« Reply #204 on: October 26, 2009, 21:01:58 pm »
Together with my 100mm Porsche nickies this will make a verry nice 2,4 Cool
Paul.
warp
« Reply #205 on: October 28, 2009, 12:43:37 pm »
How do you plan to cool the heads when driving on the street? ...not a lot of cooling fins on those things
/Jacob
fahrvergnugen
« Reply #206 on: October 28, 2009, 16:50:31 pm »
/Jacob
Not sure yet, when i have them in my hands (the are still in the USA) i'll see. Wink
Paul.
fahrvergnugen
« Reply #207 on: October 31, 2009, 21:39:42 pm »
Paul.
This is how the cranck looks like at the moment. Grin
fahrvergnugen
« Reply #208 on: October 31, 2009, 21:44:52 pm »
This week I picked up the brackets to mount the front brakes, and today I put them on.
Paul.
« Last Edit: October 31, 2009, 21:47:36 pm by fahrvergnugen » Logged
JSL
« Reply #209 on: November 02, 2009, 16:08:20 pm »
Love it!!
Still following this thread like a hawk! ;-)
Where did you get the caliper brackets made up? Would it be cool to PM me some details?
Awesome stuff!!!  Shocked
J
