October 13, 2026, 05:01:12 am
JPM head/TF1 case build and car mods for Hot rod drag week 2019 in Old cabrio
5
6
7
8
18
Topic: JPM head/TF1 case build and car mods for Hot rod drag week 2019 in Old cabrio (Read 870093 times)
Frank LUX
Back...Soon...hopefully!!!
Re: 4in bore.com and JPM come together in my new engine
Reply #150 on:
April 09, 2009, 14:26:26 pm »
Quote from: richie,uk on April 09, 2009, 11:55:18 am
The missing link arrived today,the JPM 5 bolt rocker set up
Thankyou Johannes,now I can get the motor in the car and see what it does
cheers richie
Very Impressif Richie, very Cool, can't wait to see or hear what it will do this Year....!!!
See you,
Frank
Rasser
Reply #151 on:
April 09, 2009, 19:22:56 pm »
Richie: the AN fitting in the sump, is that the oil return from the Turbo?
1955 type1
1966 type2 13w deluxe
Reply #152 on:
April 09, 2009, 19:32:02 pm »
Quote from: Rasser on April 09, 2009, 19:22:56 pm
No its the oil return from the filter,the filter head has a pressure valve in it that replaces the ones in the case and only supplies the engine with what it needs,any excess pressure[or oil] just goes straight back to the sump where its needed most,the turbo oil return will go into the type 3 dipstick block off plate as its then above the oil level with no restriction
cheers richie
Rasser
Reply #153 on:
April 09, 2009, 23:01:43 pm »
Quote from: richie,uk on April 09, 2009, 19:32:02 pm
cheers richie
Aaah - Nice setup with external pressure valve directly in the filter mount, and then drained to the sump!
You allready answered my next question, by telling me that the oil return from the hairdryer is going in ABOVE the oil level :-)
Last Edit: April 11, 2009, 22:46:21 pm by Rasser
1955 type1
airstuff
Reply #154 on:
April 11, 2009, 12:11:20 pm »
amazing
Reply #155 on:
November 13, 2009, 05:37:49 am »
Well it has been a while,due to the lbs/cubic inch rule here in the class I have been racing in this engine got put to one side to concentrate on my 2332,now with the season over I have got the 4inch bore engine back out again to finish it and get it running.
I have finished the header and trimmed the car a little more to make getting it in and out easier,i have to redo some intake pipes and move the chargecooler then it should be ready to start.
Hopefully sometime next week.Then to the dyno to see what it will do
cheers richie,uk
Reply #156 on:
November 13, 2009, 09:24:53 am »
Quote from: richie,uk on November 13, 2009, 05:37:49 am
cheers richie,uk
Surely with your car being heavier than anything else you could run a bigger engine?
Really looking forward to seeing your car with the big motor. Are you doing any other changes to the car, or keeping it all as is?
Reply #157 on:
November 14, 2009, 03:57:33 am »
Well got some more done today,still got a few pipes to move or redo but its getting close
58vw
Reply #158 on:
November 14, 2009, 04:02:48 am »
lookin good
www.4inbore.com
Angleflows...order them now
Reply #159 on:
November 14, 2009, 04:04:41 am »
And then in
Patte
Reply #160 on:
November 14, 2009, 08:32:17 am »
Sweeeeet
http://bloggis.se/turbofastback
Reply #161 on:
November 14, 2009, 08:36:26 am »
but the question is will it fit in a fastback??? i think Patte will agree?
WCB Hitler's Hot Rod
Reply #162 on:
November 14, 2009, 10:02:32 am »
Reply #163 on:
November 14, 2009, 11:03:07 am »
It'll never run you've left the Kadrons and the 009 off...
Airspeed
Reply #164 on:
November 14, 2009, 20:16:28 pm »
Quote from: richie,uk on November 14, 2009, 03:57:33 am
Richie,
Looking at your header design/lengths, I take it you believe an equal length header is also better for a turbo engine?
Tnx,
Walter
Reply #165 on:
November 14, 2009, 20:42:28 pm »
Quote from: Airspeed on November 14, 2009, 20:16:28 pm
Richie,
Tnx,
Walter
Hi Walter
I have tried too,
it is difficult to fit it in the car and to make numbers 1&3 be anywhere as long as 2&4,I made the one for my 2332 I have been running very similarly and it seems to work ok
cheers richie,uk
kev d
Reply #166 on:
November 14, 2009, 21:02:38 pm »
Reckon you'll get it built & dyno'd before coming back home?
Looks good
Cheers,
Kev
Reply #167 on:
November 14, 2009, 22:15:09 pm »
Quote from: kev d on November 14, 2009, 21:02:38 pm
Looks good
Cheers,
Kev
Hi Kev,was thinking the other day how you have been quiet recently,must have been working to hard
That is the idea,to get it finished and dynoed and some miles on it before I am back,
I only have 4 days here next year before the first race so got to get everythin sorted before
cheers richie,uk
kev d
Reply #168 on:
November 14, 2009, 22:26:09 pm »
I don`t look at it as work mate, I`m helping fund world domination of old vw gassers
Off to Korea tomorow, seeya xmass time
Cheers,
Kev
Reply #169 on:
November 15, 2009, 02:44:54 am »
Well I did the exhaust today complete with muffler,also got most of the boost piping done,got one to weld up still and a pipe to add for the blow off valve,I had to move the chargecooler and plumbing to fit everything in so a couple more hoses to redo.Hopefully I will get all the oil lines and turbo oil return finished tommorow and see what else needs changing,but it is getting close now
cheers richie,uk
Reply #170 on:
November 15, 2009, 07:30:49 am »
Looking very nice and giving me some wicked ideas for my '56
http://selvedgeyard.com/
Airspeed
Reply #171 on:
November 15, 2009, 15:10:21 pm »
Thanks for your reply before
Quote from: richie,uk on December 21, 2008, 20:18:32 pm
also this is the turbo I will be using,its a Turbonetics t72
cheers richie,uk
Richie,
See you have also changed turbos? The picture above is a Garrett right? What type and what considerations to change from the original plans?
Tnx,
Walter
Reply #172 on:
November 15, 2009, 19:43:13 pm »
Quote from: Airspeed on November 15, 2009, 15:10:21 pm
cheers richie,uk
Richie,
Tnx,
Walter
Well I am not really sure,sometime over the summer I changedmy mind
Yes it is a garrett.
cheers richie,uk
Berger
www.bugrent.no
Reply #173 on:
November 15, 2009, 22:01:16 pm »
Quote from: richie,uk on November 14, 2009, 22:15:09 pm
Looks good
Cheers,
Kev
cheers richie,uk
Does this mean you are bringing the car back to UK next year?
Excited to see how the new engine performs, looking good
This is my simple religion:
-Be cool
-Don't be an asshole
Reply #174 on:
November 16, 2009, 01:17:50 am »
Quote from: Berger on November 15, 2009, 22:01:16 pm
Looks good
Cheers,
Kev
cheers richie,uk
Hi Oyvind,no not in the forseeable future,with a race every other weekend here it is to much fun to bring it back and only have a couple of decent races per year to attend.I am planning on bringing a car to race at SCC this year,its not quite the same just helping others race, but that will be the only one in europe I think I will do in 2010 so it better be good
Walter thining about the turbo thing some more,the problem with taking to much time getting something finished and running is that your brain has more ideas and more options and improvements become available,I have to get this finished and running now as I already have version 2 in my head
cheers richie,uk
JS
Reply #175 on:
November 16, 2009, 08:07:13 am »
Quote from: richie,uk on November 16, 2009, 01:17:50 am
cheers richie,uk
IŽll put the kettle on.
Signature.
Berger
www.bugrent.no
Reply #176 on:
November 16, 2009, 16:55:03 pm »
Looks good
Cheers,
Kev
cheers richie,uk
cheers richie,uk
Nice!
Hope it`s turbo powered and does Richie-wheelies then. We`ll have the track ready for you!
-Be cool
Airspeed
Reply #177 on:
November 16, 2009, 22:32:14 pm »
cheers richie,uk
Yeah, know what you mean. My engine is just (dyno'd last week) running really good as well (in my case 'just' 350 hp
) and I also have already new ideas and even bought parts for an upgrade while I have not even ran it with this newly found power...
But don't be shy, what GTxxR is it? 40, 42 or worse?
Reply #178 on:
November 17, 2009, 00:04:04 am »
Richie -- How are you firing the injectors since you are running 2 per cylinder?
? Thanks Harold
Reply #179 on:
November 17, 2009, 02:38:03 am »
Quote from: Fiatdude on November 17, 2009, 00:04:04 am
? Thanks Harold
Harold,
first set of 4 as required,then the 2nd set either over 85% throttle,10000 rpm[these 2 settings are adjustable in ecu mapping]
or when the 1st set get to 50% duty cycle the 2nd set kick in
cheers richie,uk
5
6
7
8
18
