October 13, 2026, 07:17:27 am
JPM head/TF1 case build and car mods for Hot rod drag week 2019 in Old cabrio
8
9
10
11
18
Topic: JPM head/TF1 case build and car mods for Hot rod drag week 2019 in Old cabrio (Read 870363 times)
ESH
Re: 4in bore.com and JPM come together in my new engine
Reply #240 on:
December 01, 2009, 14:08:02 pm »
Quote from: richie,uk on November 30, 2009, 21:22:56 pm
... we have to keep up with all that modern rubbish people drive now ...
I'm not sure but I don't think you'll have too much trouble there.
Jesus
Reply #241 on:
December 01, 2009, 15:20:02 pm »
Quote from: WhiteTrash on November 30, 2009, 00:05:24 am
Nice work.
Where's you glovebox lid gone? You're not saving weight now
And nice to see the sun is shining. Don't forget to bring your shorts and flip flops when you come back in a few days. You'll need them to get through all the floods and rain, trousers & trainers just get too wet.
Frank
Aint that the TROOTH!
Sounds awesome Richie, Thanks for taking the time to upload some clips!
Reply #242 on:
December 01, 2009, 18:25:47 pm »
Quote from: Neil Davies on December 01, 2009, 12:30:42 pm
Well after the last few days of driving it and being happy with the way it is working,today I took the header & exhaust off to get them coated.One of the drawbacks of having the turbo where it sits on my car is heat gets drawn directly into the cooling fan,I am trying to minimise this and coating the entire exhaust will help alot.I should have it back by thursday then dyno time
Thanks to everyone for there positive comments,I know that what I am doing is not traditional "Cal look" but pushing the boundaries of what you can do to a Aircooled VW engine and keep it somewhat streetable was alot of what Cal look was about,and we have to keep up with all that modern rubbish people drive now
cheers richie,uk
Richie, how about having a large diameter pipe from the back of the fan going down to a duct under the car somewhere? So the air the fan picks up isn't from alongside the turbo or the header?
I am going to do something like that but there are so many things in the way it will have to be 2 or 3 smaller tubes.
cheers richie,uk
Reply #243 on:
December 01, 2009, 18:56:23 pm »
Hey Richie -- can you see what i did -- a snorkel I guess -- -- worked very well
and it was only about an inch thicker at the fan intake
Last Edit: December 01, 2009, 18:59:23 pm by Fiatdude
http://selvedgeyard.com/
Fasterbrit
Reply #244 on:
December 01, 2009, 20:09:54 pm »
Sounds real sweet Mr Webb! Looking forward to the dyno run
Matt
OFF#23 OUTLAW FLAT FOUR
www.outlawflatfour.com
www.air-kraft.com
www.marcomansiperformance.com
Reply #245 on:
December 05, 2009, 23:21:09 pm »
Got the header and exhaust back from the coaters,will put it back on later and go have some more fun
cheers richie,uk
Marty
Reply #246 on:
December 06, 2009, 17:18:11 pm »
Very nice Richie!
ugly duckling
Reply #247 on:
December 07, 2009, 05:10:13 am »
lookin SHINEY
is that for some show car your building
great job!! UD .
www.dprmachine.com
www.4inbore.com
jeffsvwspeed@gmail.com
Fonz
Still struggling with speed humps!
Reply #248 on:
December 08, 2009, 17:42:03 pm »
Quote from: ugly duckling on December 07, 2009, 05:10:13 am
lookin SHINEY
great job!! UD .
What do you mean?.....he
only
builds polished show cars doesn't he?!
pupjoint
Reply #249 on:
December 11, 2009, 06:59:54 am »
Quote from: richie,uk on December 19, 2008, 19:28:09 pm
Going to use these new style bugpack head studs with the fine thread on the head end
and I will set the case up to delete the oil relief plungers and run this Scat pressure relief filter head
with a return to the sump which should help give more consistent oil pressure
and in theory keep the oil cooler
cheers richie,uk
hi richie, nice work.
i see you mentioned that you deleted the relief plungers, welded the original doghouse cooler location shut and ran the Scat pressure relief filter head, care to explain how this works?
the filter head is fitted on the oil filter mount?
how about your oil cooler? from the pump to filter and filter to cooler? what oil cooler you using?
appreaciate if you have pics for these.
thanks.
Reply #250 on:
December 11, 2009, 20:24:53 pm »
Quote from: pupjoint on December 11, 2009, 06:59:54 am
cheers richie,uk
thanks.
No problem,1st the oil cooler passages are welded up as when the case is opened up for this size cylinders it cuts into the oil passage down from the cooler on number 3 cylinder,so a rod is machined to be an interferance fit in this passage,pressed in then sealed through welding the top end,so the otheroil cooler hole is now obsolete so welded shut as well.
It is set up like a normal full flow case,oil out the pump cover to the filter,then to a remote cooler[a mocal 18 row] and back to the case,the only real difference is the oil pressure is controlled by a valve in the oil filter mount/head and has a 3rd oil line that takes excess oil back to the sump.
pupjoint
Reply #251 on:
December 12, 2009, 06:30:09 am »
ok, thanks richie, i understand now, also after reading everything on the other thread on 4 inch bore.
yes, i think Jaycee also has a similar oil filter mount with the 3rd oil line. sweet.
bilboa2
Reply #252 on:
December 18, 2009, 16:03:42 pm »
richie, just wonderings as I saw the pic of the e85 gas station shot, Did you buy the station wagon from clark griswold ?. bill
58vw
Reply #253 on:
December 18, 2009, 17:07:15 pm »
Quote from: bilboa2 on December 18, 2009, 16:03:42 pm
now thats funny
www.4inbore.com
Angleflows...order them now
Reply #254 on:
December 18, 2009, 18:30:08 pm »
The Family Truckster!
RhoadsVW
Reply #255 on:
December 19, 2009, 02:03:19 am »
You knockin my Jeep? Don't let Sal E see you. Dave Rhoads
Der Renwagen Fuhrers
Reply #256 on:
December 19, 2009, 14:30:49 pm »
Its a mid 80s jeep and its the best workhorse I ever used
As Dave R mentioned its his and I just borrow it when needed,it has proberly had more aircooled engines carried in it than most on here have ever seen
And no one bothers you in it,it looks like it has a disease or 2
Anyway back to the topic
Reply #257 on:
December 19, 2009, 19:24:22 pm »
yep! got more vids?
it is very impressive. can't say anything else besides what has allready been said. it truelly is 'callook' in a modern way.
Martin Greaves
10.88@128.58
Reply #258 on:
December 19, 2009, 19:48:52 pm »
That a great Jeep apart from it top speed is about 58mph and it take about 10 minutes to get to it.
andy M.
Reply #259 on:
December 19, 2009, 20:41:39 pm »
Quote from: gold65turbo on December 19, 2009, 19:48:52 pm
Just like your bug!
L.B.C.R.
Reply #260 on:
December 19, 2009, 21:22:32 pm »
Quote from: andy M. on December 19, 2009, 20:41:39 pm
Just like your bug!
it's just too easy.
Sal E
Reply #261 on:
December 21, 2009, 22:48:37 pm »
That thing's like 'Christine', all it'll play is Lyndsay Buckingham's Holiday Road and it seems to be hung up on pump 5.
Quote from: RhoadsVW on December 19, 2009, 02:03:19 am
Your Jeep?
Quote from: richie,uk on December 19, 2009, 14:30:49 pm
As Dave R mentioned its Sals and I just borrow it when needed,it has proberly had more aircooled engines carried in it than most on here have ever seen
I think that's part of its charm.
OK... (better run fast, hopefully see it at Sacramento, Vegas or Fontana sometime)!
Reply #262 on:
January 09, 2010, 07:30:29 am »
Richie -- That 850 you were looking for
http://losangeles.craigslist.org/sfv/cto/1537493576.html
bedjo78
Reply #263 on:
July 07, 2010, 06:34:27 am »
Hi Richie...
How's the engine performing? Hows the Case handling the boost? what boost you put in?
TF1 4inch bore case & JPM heads come together in my new engine
Reply #264 on:
October 28, 2014, 18:57:57 pm »
Its been a while as my focus was on the new cabrio, but now I have some time I am back to the old car.
Just started on version 2,just mocking up to see what needs doing to the case etc, but I do have pretty much everything to put it together
TomJ
Re: 4in bore TF1 case with JPM heads engine build for old cabrio's new engine
Reply #265 on:
October 28, 2014, 19:37:10 pm »
Looks very nice...
Please put it on pallet and ship to Dubai
Reply #266 on:
October 28, 2014, 20:36:40 pm »
Your nail polish is a nice colour
Reply #267 on:
October 28, 2014, 22:08:45 pm »
Quote from: leec on October 28, 2014, 20:36:40 pm
spanners
Reply #268 on:
October 29, 2014, 14:54:18 pm »
;)that's what happens when you drop a well oiled crank onto yer toe
Best regards, spanners.
Reply #269 on:
October 29, 2014, 16:45:51 pm »
Come on now Lee you know its not mine if its green, now if it was yellow maybe
Anyway brief update, got everything figured out in the case I think, got to get a little machining done to the front oil pump area as the pump I am going to use is too big in diameter on the mounting area and doesn't fit flush and I also need to narrow the crank gear a little as its real close to the case so will get them dropped off today, I ordered pistons yesterday so when they arrive and case is back i can do cylinder length
8
9
10
11
18
