September 22, 2026, 04:04:52 am
| | |-+  JPM head/TF1 case build and car mods for Hot rod drag week 2019 in Old cabrio
Pages: 1 ... 8 9 [10] 11 12 ... 18 Print
Author Topic: JPM head/TF1 case build and car mods for Hot rod drag week 2019 in Old cabrio  (Read 860529 times)
« Reply #270 on: October 29, 2014, 18:15:48 pm »
Did you change to a TF1 case ?
-Alex-
« Reply #271 on: October 29, 2014, 20:06:52 pm »
Looks TF-1 case Wink
« Reply #272 on: October 29, 2014, 21:18:20 pm »
Hi Udo
yes I did, I sold everything except the heads from this engine a couple of years ago to fund other projects and have been slowly gathering parts to build it again, I got the case earlier this year and got the thrust conversion done on it by Shawn while I was back home, it was sitting here ready when I got back out here
Berger
www.bugrent.no
« Reply #273 on: October 29, 2014, 22:18:28 pm »
Nice to see that you are back on this project again  Smiley
I don`t remember, what was your PB with this car?
This is my simple religion:
-Be cool
-Don't be an asshole
« Reply #274 on: October 29, 2014, 22:30:20 pm »
9.23@152mph Cool
https://www.youtube.com/watch?v=MIZnvWwLiMA
https://www.youtube.com/watch?v=uiP7ZzrRgxU
« Last Edit: October 29, 2014, 22:57:11 pm by richie » Logged
« Reply #275 on: November 05, 2014, 20:56:45 pm »
nice to see that project getting a re-boost  Grin
and excuse my ignorance, but what is a TF1 case? who makes them and what are some of the main features? ( i see type4 bearing conversion and the oil outlets,???)
spoolin70
« Reply #276 on: November 05, 2014, 21:40:13 pm »
http://precisionalloy.com/pages/tf-1.html
Some info here Nicolas  Wink
Wray
« Reply #277 on: November 06, 2014, 08:50:34 am »
Nice
Richie can i have one  Grin
Wray
« Reply #278 on: November 09, 2014, 10:00:12 am »
thank you.
« Reply #279 on: November 09, 2014, 15:32:57 pm »
Nice
Wray
Case or Engine Shocked Grin
Should have more updates this week, hope to get case back tomorrow, I had a slight change of plan so more work is being done to it
Wray
« Reply #280 on: November 11, 2014, 04:59:11 am »
Ha Ha Both like the shinny bits they'd go well with all my old S**ters Roll Eyes
Did you ever manage to dig out those pictures for me?  Wink
need something to cheer me up at work  Sad
Wray
Wray
« Reply #281 on: November 14, 2014, 06:08:35 am »
So how did it run last night any good times?
Wray
Taylor
« Reply #282 on: November 14, 2014, 06:42:19 am »
Last night for you is still today for him. Haha He's probably still at the track.
Wray
« Reply #283 on: November 14, 2014, 08:51:48 am »
Jings you are right i am exactly 12 hours ahead as not even in the UK Shocked
do they have a web cam as could have been watching it instead of working!
Wray
« Reply #284 on: November 14, 2014, 17:30:28 pm »
Wray
No Shocked  I was renewing my license so have to do 6 observed passes, 2 60 fts, 2 1/2 passes then 2 under 6.39, after the 3rd pass I heard a noise and quick inspection shows possible valve seat moved,number 4 exhaust valve is not shutting properly so that was it for the night, it still has the old 2386 engine in it so will get it out and torn down today and see how bad it is
« Reply #285 on: November 15, 2014, 00:20:11 am »
Back to the thread.
Crank gear has been narrowed and I got that back, still waiting for the case but it was nearly done when saw it today while collecting the pistons.
They are special order with dished top, heavy duty thick wall wrist pins and gas ports, hopefully they are plenty good enough for what we hope to achieve.
« Reply #286 on: November 15, 2014, 09:28:18 am »
They look really nice Richie!
Best rgs
-K-
« Reply #287 on: November 17, 2014, 07:53:15 am »
I like that thickwall wristpin.
« Reply #288 on: November 18, 2014, 00:22:21 am »
I got the case back this morning, all converted for a roller cam set up Cool  This is why it took a little longer to do
« Reply #289 on: November 18, 2014, 00:26:55 am »
With the case back I could mock it all up for cylinder length, that is now done so next cylinders can be shortened, I got these ARP through studs, nuts and washers as an upgrade for the supplied case hardware
« Reply #290 on: November 18, 2014, 02:40:56 am »
and the pump fits, figuring out a suitable pulley is the next problem, this fits but i want to try get a large a diameter as I can on it to keep fan speed a little reasonable
Wray
« Reply #291 on: November 18, 2014, 04:59:39 am »
Mmmm Interesting
Quick couple of questions
1) does the roller cam set up give you any more space for stroke bore or is it just a better more modern reliable setup?
2)
Is it going back on the street Grin
« Reply #292 on: November 18, 2014, 05:04:39 am »
Cam timing and lift can be far more radical with a roller cam.
« Last Edit: November 18, 2014, 05:06:36 am by Zach Gomulka » Logged
Jonny Grigg
« Reply #293 on: November 18, 2014, 07:46:55 am »
What cylinders are you using Richie?
No Compromise. O/FF111
« Reply #294 on: November 18, 2014, 08:01:12 am »
Nice Richie!
I see the case is machined for some kind of support box on the outside of the roller lifters? Or what is it? Not much meat left on the side of the case  Grin
Taylor
« Reply #295 on: November 18, 2014, 08:54:37 am »
It's machined like that so he can install the lifers and wishbone as a unit from the outside.   Then a machined piece with the pushrod tube countersinks gets bolted to the side.
« Reply #296 on: November 18, 2014, 17:01:55 pm »
Mmmm Interesting
2)
1] No more room, but with this case which has 0.100 cam drop there is already more room for stroke if needed
2] Yes, there is something i want to do and it involves lots of street driving
« Reply #297 on: November 18, 2014, 17:02:39 pm »
AA's
« Reply #298 on: November 18, 2014, 17:06:01 pm »
Exactly Smiley  It has a thick plate that fixes to the outside to allow more room as the lifters are so long, then the pushrod tubes sit in this plate
I havent got them yet, they are still being machined but I knew that wouldnt stop me getting stuff done yet
« Reply #299 on: November 18, 2014, 20:10:22 pm »
Methinks that either the Power Tour dudes or the Fastest crowd are in for a surprise........
 Cool
