October 28, 2026, 17:47:57 pm
352330 Posts in 28962 Topics by 6929 Members
Latest Member: Hanibal1
| | |-+  Notchback Racing
Pages: 1 ... 7 8 [9] 10 Print
Author Topic: Notchback Racing  (Read 357119 times)
Ragtop
8.93 at SCC 2012
« Reply #240 on: August 06, 2019, 23:06:38 pm »
Heads are done!
Ragtop
8.93 at SCC 2012
« Reply #241 on: November 06, 2019, 23:04:52 pm »
All finished! Time to put it back in the car 😃
« Reply #242 on: November 07, 2019, 08:35:32 am »
Excellent,be good to hear it make some noise again Cool but before you start it put that oil filter in the bin and get something else, even a mann vw early golf/scirrocco replacement is better Shocked The quality of those Frams is awful now Angry
Ragtop
8.93 at SCC 2012
« Reply #243 on: November 07, 2019, 09:31:32 am »
I was not aware that they were bad. I have used them for years. Which ones should you use then?
spoolin70
« Reply #244 on: November 07, 2019, 10:12:38 am »
Great update and nice to see a twin scroll manifold for a change  Smiley
Can I ask what size the pipe is ? 2 inch outside or smaller ?
Thanks and good luck
Darren
« Last Edit: November 09, 2019, 09:49:20 am by spoolin70 » Logged
« Reply #245 on: November 07, 2019, 19:07:26 pm »
We are using wix 51515r which is direct swap,but for your deal i would be using something you can take apart and look inside regularly to see its all good
Fram changed owners I believe and quality went to shit, there are a couple of videos on youtube about it showing what they are like inside now Shocked
WhiteTrash
« Reply #246 on: November 08, 2019, 09:50:35 am »
There are threads on most Yank car forums all about the shit quality of Fram filters.
https://gbodyforum.com/threads/another-fram-story.75251/
Here's a video. They really are crap.
https://www.youtube.com/watch?v=iTNJLEV8CG8
Frank
HOFF#67
PPRMicke
« Reply #247 on: November 08, 2019, 22:09:42 pm »
Finns wix i kungälv Johan
/// Micke
Ragtop
8.93 at SCC 2012
« Reply #248 on: November 15, 2019, 21:37:09 pm »
It’s in the car!
dannyboy
« Reply #249 on: November 15, 2019, 22:29:36 pm »
epic  Cool
8.77@156.8mph
O/FF 60
« Reply #250 on: November 18, 2019, 11:58:57 am »
Underbart att se den komma ihop.
Håller med om varningstecknet på HP1.
På en sådan maskin så är ju ett filter du kan ta isär, klart en fördel.
Kört System1 sedan 1985 och väldigt nöjd.
Liiite sugen på ett sådant filter som kompisen Jocke Dahlgren har i sin dragster. Dock en bit på dyra sidan, tycker jag.... en dag kanske. över 400 dollar.
http://goodvibesracing.com/ClearViewFilters.htm#4in-Filters
Ragtop
8.93 at SCC 2012
« Reply #251 on: December 15, 2019, 17:21:25 pm »
It’s tight but it fits. I think I found the place for the WG tube
« Reply #252 on: December 15, 2019, 18:13:02 pm »
Awesome  Grin
Henrik Hagen
« Reply #253 on: December 21, 2019, 22:33:57 pm »
Was that the biggest turbo you could your hands on?  Grin
Ragtop
8.93 at SCC 2012
« Reply #254 on: February 12, 2020, 07:48:29 am »
Added the Co2 boost control
Ragtop
8.93 at SCC 2012
« Reply #255 on: February 12, 2020, 07:50:29 am »
Hmm strangely the pics turned sideways
brewsy
« Reply #256 on: February 12, 2020, 21:30:21 pm »
Rag,
How does that work?
Will the CO2 be used across the boost solenoid to keep the wastegate closed?
Ragtop
8.93 at SCC 2012
« Reply #257 on: February 24, 2020, 18:06:28 pm »
Rag,
How does that work?
Yes, you put a target boost on the magnetic valves. The first ones let´s the CO2 pass from the bottle at for instance 3 bars and the second valves regulates it down to what pressure you want on the hat on the WG.
Basti
« Reply #258 on: February 25, 2020, 08:14:31 am »
Not 100% correct Wink))
The first one tries to adjust the pressure in the top of the wastegate correct, the secon one release the pressure of te top of the wastegate.
As this is a closed loop Control with a pressure sensor both valves can regulate Wink
Just my 2 Cents Wink
- black 62 cal look beetle
- Pro Mod Race car
Ragtop
8.93 at SCC 2012
« Reply #259 on: February 25, 2020, 21:34:09 pm »
You are absolutely correct 😃
spoolin70
« Reply #260 on: February 27, 2020, 13:31:25 pm »
Hi
What size is your manifold/header please ?
I'm thinking of going 1 3/4 inch on my engine (2789cc) but I've seen a few that look smaller diameter but they are also smaller engines.
Darren
Ragtop
8.93 at SCC 2012
« Reply #261 on: March 23, 2020, 19:01:10 pm »
Hi
Darren
Sorry for late response, they are 46,5 mm approx 1.8”
spoolin70
« Reply #262 on: March 24, 2020, 20:08:50 pm »
Excellent  Smiley
Thank you for the reply, helps me make my mind up which size to use.
Good luck and keep the updates coming.
Darren
Ragtop
8.93 at SCC 2012
« Reply #263 on: March 26, 2020, 16:33:19 pm »
Wanted a bit better control of launch than on a button. Added this sensor and bracket
samotorsport
« Reply #264 on: March 27, 2020, 13:58:45 pm »
Cool solution , but what does it control ? I usually let go the staging brake and of i go .
But this looks interesting to me
Ragtop
8.93 at SCC 2012
« Reply #265 on: March 27, 2020, 21:34:01 pm »
It’s for launch control. As soon as the pedal passes the sensor the EFI will get a signal that this has happened and then will handle what will happen with clutchmanagement and retarded ignition and what boost to run.
samotorsport
« Reply #266 on: March 27, 2020, 21:34:56 pm »
Thanks for the infos ! Sounds great !
Ragtop
8.93 at SCC 2012
« Reply #267 on: April 09, 2020, 19:27:26 pm »
One step closer, FT550 started.
« Reply #268 on: April 09, 2020, 19:31:47 pm »
Excellent Cool
spoolin70
« Reply #269 on: July 13, 2021, 22:46:49 pm »
Must be time for an update
Please  Smiley
