July 24, 2026, 11:43:19 am
| | |-+  Porsche 6 cylinder tach?
Author Topic: Porsche 6 cylinder tach?  (Read 14090 times)
« on: January 10, 2009, 17:31:38 pm »
How do I get a 6 cylinder Porsche VDO tach to work correctly on a 4 cylinder? Can it even be done? Thanks!
Airspeed
« Reply #1 on: January 10, 2009, 17:41:52 pm »
Yes, it can be done. Mine was originally from a 6-cyl. too and a specialised company (some 20 years ago...) rebuild it to 4-cyl application.
Today Peter Fett in gemany can do 'anything' with a vw and a porsche gauge: www.fett-electronic.de/
Rocket Ron
It's old school for a reason
« Reply #2 on: January 10, 2009, 18:27:37 pm »
the Peter Fett site looks interesting
I like the look of the 100mm twin sender unit ie the tacho with the built in temp gauge
13.12 @ 101.84
Grooving out on life
« Reply #3 on: January 10, 2009, 18:35:03 pm »
Why not just get a 914 tach?
« Reply #4 on: January 10, 2009, 18:55:56 pm »
Because the redline is too low and it only maxes out at 7 grand.
« Reply #5 on: January 11, 2009, 11:21:44 am »
zach, i've got one too.
it can be done for sure. i started a topic one month ago and i was given an address in socal. you'll find it using the search function Wink
bang
« Reply #6 on: January 11, 2009, 15:07:50 pm »
there is a 3 step switch inside. if you drill a hole in the back you can put it to 4-6 and 8 cyl. found a instruction on the internet. i did it on my ovn..
« Reply #7 on: January 11, 2009, 18:29:38 pm »
Thank's Died's! Planned on giving North Hollywood Speedo a call on Monday, but if this is a simple task that we can perform ourselves then I am very interested in that!!
Bang, I can't find the info on the net Huh could you point me in the right direction??
Thanks everyone!
SlingShot
« Reply #8 on: January 11, 2009, 21:07:09 pm »
Is the 1915 going to see over 7k rpm?
Will Race For Beer !!!
« Reply #9 on: January 11, 2009, 21:13:13 pm »
That will probably be absolute max, but I'd like to have a little extra on the dial. The 911S tach will suit the motor perfectly, redline included.
bang
« Reply #10 on: January 11, 2009, 21:57:27 pm »
hey zach think i have pictures somewhere will try to have a look. do you have a email.. dont know how to post pictures on this site
« Reply #11 on: January 11, 2009, 22:02:52 pm »
sacs67@yahoo.com
Thanks!! Smiley
bang
« Reply #12 on: January 11, 2009, 22:05:37 pm »
yes got a picture of my own.. drill 2 holes in the back of the taco one switch is for cyl. think the other is to calibrate.
anyone who can post my picture on the site.?
big bang racing
denmark Grin
« Reply #13 on: January 11, 2009, 22:51:49 pm »
Here it is... Could you explain a little more?? Which holes did you drill, and what has to happen once I get in there?
bang
« Reply #14 on: January 12, 2009, 12:14:42 pm »
i drilled the two holes left from the middel. one of the switches are a 3 setp one the other one is a potentiometer. and the 3 step switch is for 4-6 and 8 cyl. it is some years ago i did it so i cant remember whitch one is what put think u can feel it if you try to turn it.
think the top one is for cyl..  Roll Eyes
« Reply #15 on: January 12, 2009, 12:21:14 pm »
why would you drill hose instead of taking the whole back of the gauge off?
bang
« Reply #16 on: January 12, 2009, 13:58:13 pm »
you cant take the back of. if you want to get inthere you need to take the front off and the glass out. to doo that you need to open the front as an tin can.. then you need to send it to vdo to get a new front ring on..
airstuff
« Reply #17 on: January 12, 2009, 14:02:02 pm »
interesting Tongue
« Reply #18 on: January 12, 2009, 14:08:29 pm »
you cant take the back of. if you want to get in there you need to take the front off and the glass out. to doo that you need to open the front as an tin can.. then you need to send it to vdo to get a new front ring on..
Sorry, but that's not true. It is very easy to simply (but carefully) peal back the rear edge of the trim and remove it, along with the glass. Then you can unscrew the back of the gauge. Refitting means simply bending the edge of the trim back into place. I did all this to repair a speedometer in my Porsche 911.
« Last Edit: January 12, 2009, 14:23:27 pm by Fastbrit » Logged
« Reply #19 on: January 12, 2009, 14:26:02 pm »
you're right uncle keith.
but is there truly a switch?
bang
« Reply #20 on: January 12, 2009, 14:31:08 pm »
on the on i had.. that was a 79 911 6 cyl.. changed it to 4 cyl. Cool
« Reply #21 on: January 12, 2009, 14:34:35 pm »
mine's 10 years older...
« Reply #22 on: January 12, 2009, 14:39:05 pm »
I bet there is – VDO would almost certainly have used the same internals on gauges for a variety of cars. Interesting to check this out... Smiley
