November 02, 2026, 20:31:51 pm
| | |-+  The Stance Thread
Pages: 1 2 [3] 4 5 ... 15 Print
Author Topic: The Stance Thread  (Read 562525 times)
« Reply #60 on: February 07, 2009, 16:13:06 pm »
What is the height/width difference between a 205/70 and a 205/65?
In answer to my own question, the have the same tread width but the 70s are just under an inch higher.
Can you fit a 215/65 on a 5.5 rim?
« Last Edit: February 07, 2009, 23:30:25 pm by louisb » Logged
67worshipper
« Reply #61 on: February 07, 2009, 16:20:09 pm »
this is jade as youve seen before built by luke(the ideaman) 4.5 and deep 6s anodized with 145xzxs and bridgestone 205/70s.cb chrome shocks alround.type 3 rear drums and discs on the front.cb 2inch narrowed beam,cb dropped spindles all powdercoated.bus snubbers and sway a way race axles.
vw hot rod heaven
Rocket Ron
It's old school for a reason
« Reply #62 on: February 07, 2009, 16:40:31 pm »
nice looking car mate Cool
13.12 @ 101.84
Grooving out on life
Stephan S
« Reply #63 on: February 07, 2009, 18:16:45 pm »
Rims: 15x5 Flat-4 BRMs
Front tires: Kleber 145-15s
Rear tires: F70-15 Firestone wide-O-oval (they are slightly higher than the Pirelli 205/70-15 I previously had); short axles
Stock VW beam with a pair of Sway-A-Way adjusters; rear suspension might be slightly lower than stock
Porsche 356B aluminum drums
bluestar
D.A.S member
« Reply #64 on: February 07, 2009, 18:56:22 pm »
My wife 1300 70' :
Front : type 181 "the think" complète beam with sway-a-way and CB spindles with dics , 19mm Sway-Bar , "Spax" adjustable shocks and 145-15 Firestone F-560
Rear : Stock heigh , type 3 drums , Spax" adjustable shocks and Kleber 195-70-15 tires
In this config , that car have a very very good grip on the way ( thats better , my wife is on the steering (joke offcourse !! ))..
67worshipper
« Reply #65 on: February 07, 2009, 20:26:54 pm »
nice looker stephan.do they still make those firestone wide-o-ovals? might help being taller with a 1.21 fourth gear.
vw hot rod heaven
Stephan S
« Reply #66 on: February 07, 2009, 22:54:15 pm »
Coker Tire is selling these Firestones.
Check out www.cokertire.com
67worshipper
« Reply #67 on: February 07, 2009, 23:37:48 pm »
ive just looked at the coker website thanks stephan.theres also a G70/15 below the F which is slightly taller again but i cant see what the difference is between the two.any ideas?
vw hot rod heaven
« Reply #68 on: February 07, 2009, 23:43:01 pm »
Say, isn't that out front of the Holiday Inn where Rayburn, DKK Fred and KS have their secret "meetings?" Kiss Kiss Kiss
« Reply #69 on: February 07, 2009, 23:58:23 pm »
You should know – we used your private suite! Cool
PS - love the new mirrors on the ceiling. Not sure about the chains, though. Jayburn found them a little cold, but Carlos liked them.
JS
« Reply #70 on: February 08, 2009, 00:00:32 am »
F70 is like 215/70, G70 is like 235/70.
Signature.
67worshipper
« Reply #71 on: February 08, 2009, 00:24:27 am »
thankyou.
vw hot rod heaven
Jason Foster
7.69 87mph 12.35 106 mph
« Reply #72 on: February 08, 2009, 04:06:53 am »
  yes louis you can fit a 215/65 15 on a 5.5 rim. It works quite nice.
« Reply #73 on: February 08, 2009, 04:10:07 am »
Those M&H dots?
Lanny Hussey
« Reply #74 on: February 08, 2009, 05:08:52 am »
Lanny,
  Did you always have the narrowed beam on that car?
Yes, a 2" beam until around 2002 or so, then 3". It's the disc/spindle combo that caused problems.
Jason Foster
« Reply #75 on: February 08, 2009, 06:57:56 am »
Those M&H dots?
   Yes louis they are 215/65 15   MH dot's
  Lanny I've always thought your '67 was kick ass.
herrvee
« Reply #76 on: February 08, 2009, 12:54:17 pm »
herrvee, very cool car
thanks jason
Matty c
« Reply #77 on: February 08, 2009, 15:00:46 pm »
145xzx
2" cb narrowed front beam
cb dropped spindles
stock shocks
rear,
all stock apart from koni red adjustabes
205/70s
wheels are flat four
67heaven
67worshipper
« Reply #78 on: February 08, 2009, 15:50:45 pm »
white lookers do look boss Cool
vw hot rod heaven
TiDi
« Reply #79 on: February 08, 2009, 15:52:39 pm »
Where are the white letters on the Wide Oval?
They do them also without???
Thanx Matteo
4 Wheel Ripperz - http://cal-look.tumblr.com/
67worshipper
« Reply #80 on: February 08, 2009, 15:59:35 pm »
i think theyre only on one side so can face inwards.the pattern isnt directional either.
vw hot rod heaven
TiDi
« Reply #81 on: February 08, 2009, 16:13:54 pm »
Cool  Grin Grin Grin
I didn't think that solution  Roll Eyes Roll Eyes Roll Eyes
I don't remember how's the "dark" side but if is like that I like it....
Cornpanzer
« Reply #82 on: February 08, 2009, 16:41:09 pm »
What a great thread! Some stunning cars on here!   Here is my contribution.
Front - OEM beam narrowed 2.75".  CB dropped spindles and a couple small leaves removed to counteract the stiff ride caused when narrowing the beam/torsion leaves.  4" American Racing Torque Thrusts with Mich 145 XZX tires.
Rear - Stock suspension with 7" Americans and 7W Firestone slicks recapped by Caldwell many moons ago.  Approx .250 spacer behind wheel
Goal was to have the same gap between tires and fender lip and have the tires as close to the lips as possible without rubbing.  None of that silly tucked look.  IMO, the 145 matches the shape of the front fender opening better than the 135 plus give just a tiny bit more rubber on the road.
'67 Turbo Sedan
Ultra VW Contributor
« Reply #83 on: February 08, 2009, 17:42:42 pm »
Nice pic, Dave! Cool Cool Cool
67worshipper
« Reply #84 on: February 08, 2009, 18:51:29 pm »
ive always like those torques dave Cool are they porsche pattern ones?
vw hot rod heaven
« Reply #85 on: February 08, 2009, 19:11:06 pm »
Now this is one tough lookin' ride. Nice car!
HAHAHA!!! You two crack me up.
Cornpanzer
« Reply #86 on: February 08, 2009, 19:45:28 pm »
Thanks Sarge and Mark.  Yep, those are Porsche pattern Americans.
'67 Turbo Sedan
bluestar
D.A.S member
« Reply #87 on: February 08, 2009, 19:57:53 pm »
Crazy agressiv car Dave , now I can have good dream for the next nigth !!!
67worshipper
« Reply #88 on: February 08, 2009, 20:39:04 pm »
ive noticed having looked closely at this picture that daves not running an antirollbar on his front beam.i dont run one myself but i know people are split on this to run or not to run.whats the views?
vw hot rod heaven
Cornpanzer
« Reply #89 on: February 08, 2009, 21:00:09 pm »
Well, the car has been on either slicks or recapped slicks for more than 10 years and it now has a spool, so turning performance is going to be lousy no matter what.   Smiley  Plus, when I narrowed the beam, there were no narrow sway bars available.
But in a more mild mannered car with radials all the way around, I see no reason not to run a sway bar.
'67 Turbo Sedan
