September 22, 2026, 08:27:56 am
| | |-+  26mm torsionbars
Author Topic: 26mm torsionbars  (Read 8861 times)
wide-5
« on: February 11, 2009, 10:47:32 am »
Hey.
I'm about to convert to 26mm torsionbars in the rear of my 60 -1.
My question about this is, what's the preload on bars like this? Or do they have any preload at all?
Petter
vwtaiwan
« Reply #1 on: February 11, 2009, 10:53:46 am »
Hey.
Petter
I installed 30mm torsion bars on 56 bug with stock weight, and the bars just change 2 degree when put on the ground.
« Reply #2 on: February 11, 2009, 12:09:11 pm »
I`m afraid you have to try to find out. I have 28 mm and do not have any preload at all, still a bit to high. Some recommend 1/4" above the stop and I will try that later.
Best rgs
BB
« Reply #3 on: February 11, 2009, 19:43:01 pm »
I went to 26 mm on my Mex, and had to go one spline lower to get to standard height.
Ron Greiner
DKP II
« Reply #4 on: February 13, 2009, 01:26:47 am »
I put 26 mm bars into my 68 bug and set the pre load @ 11 degrees on left side and
10 degrees on right side.
if they are new bars you will have to reset them after a while.
wide-5
« Reply #5 on: February 13, 2009, 10:10:30 am »
Great answers.. Smiley
Thank you guys.
Petter.
wide-5
« Reply #6 on: February 22, 2009, 23:05:11 pm »
Something went wrong with my order, so i got a set of 28mm instead..
No worries about that.. I'm just happy.  Grin
So then I try this 1/4" over the stop theory.
Thanks again..
Petter
« Reply #7 on: February 23, 2009, 09:05:35 am »
Thanks again..
Petter
And you will find out that it will be close to perfect... in my eyes  Smiley
« Reply #8 on: February 23, 2009, 09:20:28 am »
Are you racing the car? I have 28's on my car, installed with 0 preload, but I think that might be a mistake... the ride height is perfect but it still squats to much on a glued track... I need to think about how to solve it.
wide-5
« Reply #9 on: February 23, 2009, 21:55:26 pm »
In the moment i'm just prepairing my ride to join the race later.  Wink
The engine i have, is just a mild mod 1600. So it's not much of a racer..  Cheesy
But later i hope to get a more powerfull engine, and start racing a bit..
