October 13, 2026, 04:37:21 am
128hp at the wheels (so far) Kadron 1915cc
Topic: 128hp at the wheels (so far) Kadron 1915cc (Read 38410 times)
February 17, 2009, 22:14:35 pm »
1915, round port 40 x 35.5, Engle VZ15, 8.4:1 and
Kadrons
made 128hp/5500 at wheels with real thin fuel curve.
source: Holleran's Performance, Pinole CA
more to come
Last Edit: February 18, 2009, 20:08:25 pm by Jim Ratto
peach_
Re: 128hp at the wheels (so far) no tuning
February 17, 2009, 22:16:05 pm »
SAS RENN-WAGENS
and proud
#CALLOOKDRAGS
67worshipper
February 17, 2009, 23:45:02 pm »
sounds great jim
keep us updated
vw hot rod heaven
lawrence
February 18, 2009, 00:19:18 am »
Is this sheep's motor? When the weather gets nice I want to take my car over there and see what it will do on the chassis dyno. I know it made 132 flywheel hp @ 6000.
"Happiness is a Hot VW!"
February 18, 2009, 00:24:16 am »
No it is a 356 kit car that John built the engine for. Sheep's motor is a 1800cc single port.
February 18, 2009, 00:24:32 am »
that sounds really really good!
good ol' vz cam and kadrons, aye?
tell us more
Last Edit: February 18, 2009, 00:36:49 am by 67-indeed/DVK
DVK ~
February 18, 2009, 00:40:10 am »
it was just a simple 40 x 35.5 motor, stock rockers, Kadrons, low CR. The guy brought it to John as a basket case from MO Fo .... you know who. I thought the hp and torque so far looked good for what it was.
should make for a fun streeter in a 356 kit car.
67worshipper
February 18, 2009, 00:49:02 am »
id be happy with that
vw hot rod heaven
bilboa2
February 18, 2009, 03:06:22 am »
BUT.. who triicked the heads... airspeed,? nice #'s.
February 18, 2009, 05:32:58 am »
Hi Bill
they're actually CNC CB 044's that John did some work on chambers on.
Re: 128hp at the wheels (so far) Kadron 1915cc
February 18, 2009, 20:46:24 pm »
139hp @ 5900rpm today on 180 mains in those Kadrons and 131 ft lb @ 4900 (at the rear wheels)...
more to come...
67worshipper
February 18, 2009, 21:17:39 pm »
fuckin ell thats pretty damn good on the ol kadrons. whats the next step then jim.
vw hot rod heaven
February 18, 2009, 21:21:09 pm »
get the thing back to the customer and tell him to be careful driving it!
I'd like to see what it would do with some real carburetors... at least 44IDFs.
Funny, John said he wanted a simple streeter that his customer could putt around in. I advised him on the combo...
Oops.
February 18, 2009, 21:46:39 pm »
amazing! what could it be that gives this engine so much power?
it is a lot more than you'd expect from looking at the specs.
i'm hoping another combo you advised will work as good
DVK ~
Rasser
February 18, 2009, 23:03:14 pm »
Thatīs like 150-160hp on the flywheel
It just sounds "wrong", I would have guessed that combo at 100-110 at the flywheel. A 1915 with a VZ15 cam and 40x35,5 heads and kadrons putting out that big amount of horsepower(150-160), just sounds insane.
If it is showing the exact horsepower, then it truely is impressive, no doubt!
Im guessing that this is a joke, right ?
1955 type1
1966 type2 13w deluxe
67worshipper
February 18, 2009, 23:06:12 pm »
Quote from: Rasser DK on February 18, 2009, 23:03:14 pm
perhaps this thread will keep going until april the 1st
vw hot rod heaven
February 18, 2009, 23:10:13 pm »
no joke.
John normally does hot rod 911 stuff. He knows his way around assembly. I think it is a recipe that just works. the carbs have venturies that have been opened to 34mm, hence the big mains this thing needed to fuel it. Looking at a fuel curve of 12.5-12.8 on last pull. The VZ15 is not a "tame" cam by any means, look @ duration @ .050 and advertised... see how narrow that spread is. I've used this cam before in under 2000cc and have always been impressed, no make that, amazed, at how it screams. I've been saying for 15 years, the VZ15 and kadrons with small ports are a mean combination. I know, I know... 'what about valvetrain wear, what about lifter bores, what about all that noise?'.... yeah, well , how about them numbers?
I had customers running this cam in street cars @ BH, never had a valvetrain failure.
Rasser
February 18, 2009, 23:10:29 pm »
Quote from: 67worshipper on February 18, 2009, 23:06:12 pm
Or it could just be 10-11 months to late ?
1955 type1
February 18, 2009, 23:11:51 pm »
February 18, 2009, 23:12:24 pm »
impressive jim, hope my brother's vz 14 and kadrons kick butt, too
DVK ~
February 19, 2009, 00:07:19 am »
Maybe A.J. Sims Kadrons???
February 19, 2009, 01:56:18 am »
Not sure about the carbs. All the involvement I had has been over the phone. The jets had been drilled and marking ground off, so John dug thru his stuff and made some work. who knows what
was
in it.
The specs are... VW case, c/w VW crank, VW rods, Vz15 straight up, Cb lifters, Cb CNC 40 x 35 with chamber work, manton tapered pushrods, Vw rockers, swivel feet, 8.4:1, full flow 30mm pump by me, some backyard 4 into 1 header, 009, nothing really magic.
Hotrodvw
February 19, 2009, 06:08:28 am »
Where's the dyno sheet Jim??
Hose & Fittings
'67 Sunroof
www.ultimateaircooled.com
Dick Mitchell
February 19, 2009, 07:12:37 am »
Wow! Those numbers are REALLY impressive!
besserwisser
February 19, 2009, 07:48:32 am »
Could be the results of high lift short duration,high port velocity. Just my guess.
Fasterbrit
February 19, 2009, 09:46:02 am »
That is truly impressive Jim! Would love to see the dyno graph and see where the motor comes on song. What rpm will she pull?
OFF#23 OUTLAW FLAT FOUR
www.outlawflatfour.com
www.air-kraft.com
www.marcomansiperformance.com
February 19, 2009, 14:12:05 pm »
I'd like to hear the K-Dog bark on that. Sounds like a real mighty mouse.
February 19, 2009, 16:53:52 pm »
John said he'd get me the sheet sometime, gotta fix a printer or something. After his driving impressions, he said it comes into its own around 3800 and he took it to 6600. he said it will ride the rear snubbers thru 3rd gear. How much does a 356 glass replica weigh, anyway?
I'd like to see him do this to a real 356B or something. For the amount the Porsche guys spend on machine work alone you could darn near double the power and give them some ulcers on some backroads. Damn VW's
February 19, 2009, 19:41:15 pm »
Quote from: lawrence on February 18, 2009, 00:19:18 am
Hi lawrence, John said to give him a call anytime... 510 724 6944
Going to take fan belt off today and see how it runs on the dyno today.
lawrence
February 19, 2009, 19:48:07 pm »
Cool!
