November 02, 2026, 21:11:36 pm
| | |-+  another "won't work" engine
Pages: 1 [2] Print
Author Topic: another "won't work" engine  (Read 18635 times)
« Reply #30 on: February 27, 2009, 19:12:47 pm »
I'm going to look for a ratio rocker cam with about 230-240' @ .050. I think you're right, and I hate to build something with a window of power 1000rpm long
How bout a FK-41? .240@ .050 X .364" cam lift .510 w/1.4s. With the fast ramps, you could get away with less carburetion.
« Reply #31 on: February 27, 2009, 19:22:01 pm »
I was looking @ Fk7 or Cb 2241
« Reply #32 on: February 27, 2009, 19:30:29 pm »
FK-7 and the FK-41 are pretty close.
« Reply #33 on: February 27, 2009, 19:35:14 pm »
41 sure is rampier. I like that. Still moderate lift. Good call John.
« Reply #34 on: February 27, 2009, 23:28:31 pm »
2241, is that the CB cheater cam?
« Reply #35 on: February 27, 2009, 23:41:12 pm »
No. .424" lift and .286 (240@.050) duration. Close to an Engle 100.
« Reply #36 on: February 28, 2009, 02:30:40 am »
If you are willing to "play", a TSC10 on 108 LC could be really interesting to explore in a set up like that. (But with stock or max 1,25 rockers
Some time ago, I was trying tofigure out ways to improove performance on a dual port 1776 with a stock 34 Pict. i then took the CB 2239 grind on the intake (234 @ 0,50) and made a milder exhaust side. (230 @ 0,50) and wit 12 degree less seat duration. It idled better than stock, had great torque, 110 lbs, but the upper end hp lacked a bit. So I abandoned the cam and went for one with more duration on both sides. - lost some bottom end but gained midrange & upper end hp. and thatīs what I wanted with that one.
« Reply #37 on: March 01, 2009, 04:56:26 am »
.503" @ valve w/ rockers, 262' @ seat. 230@ .050
Dougy Dee
« Reply #38 on: March 01, 2009, 20:07:25 pm »
Single port. 30PICT3. Why not old skool? VZ14 or 15.
Pages: 1 [2] Print
