October 13, 2026, 03:51:58 am
Frontrunners, wich size??
Topic: Frontrunners, wich size?? (Read 10020 times)
sven
March 09, 2009, 22:29:52 pm »
Hi,
I have to order a set of frontrunners but I'm confused about the size.
Currently I'm running Michelin 135 FS 15, this is +/- a outer diameter of 23.97", still I see that the most used frontrunner slick is 22"x3.5x15??
Can anybody advise my.
Thx.
Sven
Re: Frontrunners, wich size??
March 10, 2009, 02:49:59 am »
Quote from: sven on March 09, 2009, 22:29:52 pm
Hi,
Thx.
Sven
I am using 24/4.5/15 M/T its really personal preference,the smaller diameter is supposed to help R/T i believe
sven
March 10, 2009, 08:12:31 am »
Thx. Richie,
I gues R/T stands for reaction time?
Maybe this is intresting for a start like we had at SCC ( Orange-green), what system do they use at Santa Pod?
Sven.
March 10, 2009, 08:59:48 am »
Quote from: sven on March 10, 2009, 08:12:31 am
Thx. Richie,
Sven.
The start procedure we used at SCC is called a pro start and I will be very suprised if they do not use the same start procedure at Santa Pod. For street legal races we have the possibility to choose handicap start, yellow, yellow, yellow - green.
March 10, 2009, 10:22:31 am »
Quote from: BeetleBug on March 10, 2009, 08:59:48 am
Thx. Richie,
Sven.
We call that the "sportsman tree" - the green comes on 0.5 seconds after the last yellow, whereas the Pro tree has the green light coming on 0.4 seconds after the three yellows come on together. We use the Pro tree in O/FF, but the E/T bracket classes use the Sportsman tree.
Back on topic, You can also adjust front tyre pressures to alter reaction time - the harder the tyres, the quicker reacting the car.
sven
March 10, 2009, 19:27:58 pm »
Ok, I think I go for MH 24/3.6/15 with enough presure
Thx.
Eric Justus
March 17, 2009, 01:31:46 am »
google the word "roll out" and it will explain everything you need to know about tire size. There is a whol explanation of how your roll out affects your reaction time and your elapsed time. depending on the tree, your application and class you are racing, will depict the type of tire you need to run. I just recently spent a whole night reading up on this. its quite interesting. BTW, the tire size that Richie is running is near close to run of the mill for most applications guys are running.
Eric Justus
HotVWs, SuperVW, Let's Play VW Cal-Look features
Der Kleiner Panzers VW club
sven
March 18, 2009, 20:05:58 pm »
I tried it but didn't find it, can you mention the URL.
Eric Justus
March 19, 2009, 01:40:23 am »
Quote from: sven on March 18, 2009, 20:05:58 pm
http://www.summitracing.com/streetandstrip/tech_content.asp?ID=%7B0C714864-99B8-4C54-8531-F7708F675921%7D
Eric Justus
sven
March 25, 2009, 21:10:28 pm »
Thx.
Seems their is alot to learn, I will need a lot of runs to test it all.
