September 22, 2026, 17:00:07 pm
| |-+  Wanted
| | |-+  Throttle lever for Weber 48 IDA
Author Topic: Throttle lever for Weber 48 IDA  (Read 11614 times)
« on: March 11, 2009, 12:58:26 pm »
I still need one throttle lever for my IDA's as I have two of the same right now...
here's the parts chart:
http://www.racetep.com/weber/48IDA.pdf
So, I'm looking for part no. 37A but then the mirror image (if you get what i mean?). The lever for the other side carb. Which, when installed, would point up to the left.
I attached Henry Oelker's engine to make it clearer; I have the lever on the left hand side (cylinder 3&4) and i need the right hand one.
Let me know if you can help out.
Thanks!
« Last Edit: March 11, 2009, 13:01:19 pm by 67-indeed/DVK » Logged
« Reply #1 on: March 11, 2009, 21:28:34 pm »
It doesn't exist.  You'll have to make it.
« Reply #2 on: March 11, 2009, 21:34:32 pm »
you mean i have to bend the other one around?
i have a small bag from jaycee with the other no. 37 and two of the same parts with welds on the back instead of the little tip that sticks out?
do you know what i mean?
« Reply #3 on: March 12, 2009, 16:20:56 pm »
37A is not A part Needed. the carbs all have the same throttle stop what you need comes with your linkage kit you dont change what came with the IDA's unless you are using the Berg linkage which comes with new throttle stops
« Reply #4 on: March 12, 2009, 16:31:18 pm »
the thing is, that part didn't come with my tayco linkage. i just have the arms, with the rotating "eye" bolt that bolts onto the throttle levers and one of my carbs doesn't have this part. i'll take a pic of what i do have later today.
thanks for the help!
« Reply #5 on: March 13, 2009, 05:40:56 am »
I think this is what you are looking for?? http://www.thesamba.com/vw/classifieds/detail.php?id=671264
« Reply #6 on: March 15, 2009, 15:01:28 pm »
yeah, those are the ones i have!!
should i mount those instead?
« Reply #7 on: March 15, 2009, 21:44:12 pm »
you need them on both carbs so the stops will work, if you are using berg linkage his replace those. other linkages still use those, the tayco linkage would bolt on the shafts after these, the tayco ones dont replace the weber ones
« Last Edit: March 16, 2009, 05:03:35 am by Shubee2 (DSK) » Logged
« Reply #8 on: March 15, 2009, 22:04:07 pm »
wow, i didn't get that. is that one sentence? Wink
« Reply #9 on: March 16, 2009, 05:04:15 am »
lol read it agiain  lol
« Reply #10 on: March 16, 2009, 10:54:22 am »
Beware, those arms have the post in the wrong spot.  Where it is now, the throttle plates go past full throttle.  When you do this, the air flow takes a dump.
« Reply #11 on: March 16, 2009, 11:55:17 am »
ok, so then i'll mount no. 37 the other way around so that the stop won't be used but it will be pointing in the right direction for the linkage?
« Reply #12 on: March 21, 2009, 14:04:39 pm »
diederick, i may have this lying around somewhere,
i ll check...
it was from my csp bellcrank linkage
lawrence
« Reply #13 on: March 21, 2009, 21:40:11 pm »
I have a pair of throttle arms, very similar to the ones pictured above, that I purchased from a different weber supplier. I have never been really pleased with them because they do not sit flat against the the idle screw and carb body like the nice original weber parts. I would also be interested in some arms for tayco/hexbar linkages.
"Happiness is a Hot VW!"
