October 12, 2026, 18:18:44 pm
Late Looker (type 4)
5
6
7
8
Topic: Late Looker (type 4) (Read 526795 times)
Re: Late Looker (type 4)
Reply #150 on:
November 23, 2019, 13:06:44 pm »
1 step further, placing the sleeves for type 1 lifters.
So the Pieper lifters will operate perfectly.
Garrick Clark
Reply #151 on:
November 24, 2019, 09:57:57 am »
Looking good. Those 2 threaded plugs in the pic, I use those as an in/out for an external filter and delete the original filter mount to make that area a bit neater.
Air cooled Engine builder
Reply #152 on:
November 24, 2019, 10:31:39 am »
Quote from: GARRICK.CLARK on November 24, 2019, 09:57:57 am
I like that solution too.
But you loose the oil pressure bypass, I don t know if i want that.
Do you have a solution for that?
Garrick Clark
Reply #153 on:
November 24, 2019, 11:58:21 am »
I haven't found it to be a problem.
Plus
I have the piping as follow
Out of case
Into filter. Located on rear bumper mount
Out of filter
Into oil cooler over gearbox
Out of cooler into upright type 1 cooler
Out of type 1 cooler back into case.
You will need a non return valve as I did.
The original type 4 cooler has a block off plate that has a loop on it, so oil can circulate at that point.
This might read as being complicated but it isn't.
The main mod of drilling and tapping the plugs on your case has been done.
Mines been this way for 10 yrs.
Last Edit: November 24, 2019, 12:00:10 pm by GARRICK.CLARK
Reply #154 on:
November 25, 2019, 08:00:24 am »
good info, will look in to this.
Garrick Clark
Reply #155 on:
November 25, 2019, 13:34:53 pm »
For the upright cooler I use a doghouse cooler mount that's had the oil holes underneath welded up and threaded unions at the back of the mount fitted for oil in / oil out.
Reply #156 on:
November 30, 2019, 08:56:06 am »
Yet another question, I like to install the CSP Type 1 10mm chromoly head studs, but I can not find casesavers from M12x1.5 to M10.
Does somebody sell those?
I can find the casesavers to M8, but then the question is are those head studs strong enough for my set up?
Thanks in regards
Garrick Clark
Reply #157 on:
November 30, 2019, 09:49:56 am »
Last Edit: June 09, 2020, 10:02:17 am by Garrick Clark
Reply #158 on:
January 19, 2020, 08:20:02 am »
Got me some old school rocker covers.
Scored on the samba
Last Edit: January 19, 2020, 08:28:18 am by Eddie
Reply #159 on:
March 07, 2020, 08:42:47 am »
Ok will try it here also
Can somebody tell the brand of these 'Nickies'?
They are all aluminium. (no Biral)
These are the only markings I can find.
These are 100mm ones
Head size 114.75 mm
Case size 108.52 mm
mikko k
Reply #160 on:
March 07, 2020, 10:41:57 am »
Nickies from LN Engineering?
https://lnengineering.com/
These are 105mm from LN.
Last Edit: March 07, 2020, 10:53:02 am by mikko k
Reply #161 on:
March 07, 2020, 11:16:33 am »
Whooo thanks Mikko for those pictures..
Mine look a bit different then your pictures, doesn t have 5 cooling ribs on the head side,
and has less cooling fins overal.
So don t think mine are LN nickies.
An Other member pointed me to QSC ones... now I checked the cooling fins I am tempting to
think they are QSC.
But please keep ideas coming.
mikko k
Reply #162 on:
March 07, 2020, 11:52:48 am »
Reply #163 on:
June 09, 2020, 06:57:18 am »
It is Decision time,
Got 2 options, everything else is ready so can start building.
But really don t know what to choose.
The well known tough Deutz cylinders or the QSC aluminium Cylinders.
Maybe you guys have some experience with both or just the one.
Disadvantages or advantages???
Like to hear from you?
Thanks in advance
Eddie
Last Edit: June 09, 2020, 10:13:10 am by Eddie
Reply #164 on:
November 20, 2020, 15:05:55 pm »
Ok got a question for the specialists,
I want to kmow if this comprsession ratio will work or you guys say, that s a no no.
Building a 78 x 100 engine with 48cc chamber heads with a webcam 86b Lobecenter 108.
The advertised compression ratio is about 9.5:1 for this cam.
But with a (preferd) 1.3mm deckhight my ratio will be 11.5:1. we have 98 gasoline.
But would this compression ratio be ok?
Thanks in advance
Eddie
Ps it got all the light parts in there JE pistons TP type 1 lifters Hbeam rods, balanced counterweigted crank.
mikko k
Reply #165 on:
November 20, 2020, 16:17:41 pm »
Quote from: Eddie on June 09, 2020, 06:57:18 am
Thanks in advance
Eddie
Sorry that I haven’t noticed this before.
I would use aluminium ones. Gets heat away better.
But you need to clear out that you have right kind of piston rings to use with these cylinders.
Deutz cylinders have been used also and they are fine too.
mikko k
Reply #166 on:
November 20, 2020, 16:21:47 pm »
Quote from: Eddie on November 20, 2020, 15:05:55 pm
Thanks in advance
Eddie
Street use? Drag race only? What kind of heads and valve sizes? Efi / carbs? Exhaust?
Reply #167 on:
November 21, 2020, 12:06:48 pm »
Thanks Mikko,
Cal look so mostly street and sometimes strip
Heads ported with 42/36, 45 Dellorto carbs and turbo thomas 42/41mm merged header
Programmable ignition.
Hope this helps
Reply #168 on:
November 21, 2020, 12:10:01 pm »
Quote from: mikko k on November 20, 2020, 16:17:41 pm
Thanks in advance
Eddie
JE Pistons with there pro seal piston rings.
Hope this helps
mikko k
Reply #169 on:
November 21, 2020, 12:54:42 pm »
Quote from: Eddie on November 21, 2020, 12:06:48 pm
Thanks Mikko,
Hope this helps
With this info, I would go something like 10:1 cr. More cr will produce more heat and possibly more problems at street use.
mikko k
Reply #170 on:
November 21, 2020, 13:07:51 pm »
Quote from: Eddie on November 21, 2020, 12:10:01 pm
Thanks in advance
Eddie
Hope this helps
I think that you should know what kind of cylinders are the piston rings ordered for. If you haven’t said about aluminium cylinders, I would quess that rings are for iron cylinders. But I’m not sure. I think that you should check the order.
Reply #171 on:
November 22, 2020, 09:37:10 am »
Quote from: mikko k on November 21, 2020, 13:07:51 pm
Hope this helps
Well both the cylinders and pistons were internet bargains, so the rings came with pistons, don t know the history.
Did check the ring gaps and those are tight so have to modify them.
Reply #172 on:
November 22, 2020, 09:43:15 am »
Quote from: mikko k on November 21, 2020, 12:54:42 pm
Thanks Mikko,
Hope this helps
The heat problem with type 4 in a beetle isn t a big problem. will have a look but with 10:1 my deckheight becomes more than I would like, (2.6 mm) did unshroud the heads a bit.
Thanks again Mikko
Last Edit: November 22, 2020, 09:52:35 am by Eddie
mikko k
Reply #173 on:
November 22, 2020, 13:32:57 pm »
Quote from: Eddie on November 22, 2020, 09:37:10 am
Hope this helps
Ok, in this case, I would use deutz cylinders. Or, the other way would be to order new rings from JE to suit to the aluminium cylinders.
mikko k
Reply #174 on:
November 22, 2020, 13:39:14 pm »
Quote from: Eddie on November 22, 2020, 09:43:15 am
Thanks Mikko,
Hope this helps
Thanks again Mikko
In this case I would modify combustion cambers to be bigger to get lower cr.
MegaRookie
Reply #175 on:
November 22, 2020, 18:27:59 pm »
Hi Eddie, 10:1 doesn't sound very strange for a street engine with a web 86b. But your deck is a bit too high in my opinion. I should aim for max. 1.5 and try to unshroud the heads some more to not raise the cr to much.
Enjoy the build!
Mark
Reply #176 on:
November 23, 2020, 07:32:38 am »
Quote from: mikko k on November 22, 2020, 13:39:14 pm
Quote from: MegaRookie on November 22, 2020, 18:27:59 pm
Enjoy the build!
Mark
I had them unshroud a bit around the valves, what can I do more on a type 4 head to gain more cc s in the head?
Regards Eddie
mikko k
Reply #177 on:
November 23, 2020, 15:39:14 pm »
Do you have picture from combustion cambers?
Reply #178 on:
November 24, 2020, 07:24:24 am »
Yes, have a picture.
See here
Last Edit: December 01, 2021, 12:42:31 pm by Eddie DVK
mikko k
Reply #179 on:
November 24, 2020, 17:11:28 pm »
Take your cylinder in to head and drow a circle from inside cylinder to head. The you can expand compustion cambers close to cylinder walls. You can see circle and wanted shape from my picture.
5
6
7
8
