September 28, 2026, 19:06:22 pm
Late Looker (type 4)
6
7
8
Topic: Late Looker (type 4) (Read 522822 times)
Re: Late Looker (type 4)
Reply #180 on:
December 09, 2020, 15:55:09 pm »
Finally had some time to machine the cylinders
Cutting them to the correct length.
Machining the fins off.
Cutting them to the final size.
Arnoud
Reply #181 on:
December 09, 2020, 20:58:25 pm »
Hi Eddie!
Good job!Is the material as hard to machine as they say?Did you do this at home ?
Keep up the good work!
Cheers,Arnoud
Reply #182 on:
December 10, 2020, 07:46:33 am »
Quote from: Arnoud on December 09, 2020, 20:58:25 pm
Hi Eddie!
Cheers,Arnoud
I am not a experienced machinist, so i am working a bit slow.
But the fins are the hardest part to machine of, if you go to fast the fins brake and your knife brakes.
But yeah you can only do small cuts at a time.
The mills are not mine, a friend of mine has a ship diesel engine repair shop.
But it is fun to do. Like to do that stuff myself.
Regadrs eddie
Reply #183 on:
March 08, 2021, 09:03:37 am »
Got the cylinders machined to fit the headstuds, I think this is the hardest part of machining to get the cylinders to fit the case.
It is difficult to find a long cutter to do the whole hole in one go.
Reply #184 on:
March 11, 2021, 10:32:24 am »
Got the head fitted, some small adjustments to the hole for the head studs, so the cylinders fit and can move freely.
So one step further. Must say, happy at the moment.
Reply #185 on:
March 18, 2021, 08:30:00 am »
Cylinders do all fit now.
Next up, looking if I got the deck height right and adjust to the correct height.
Reply #186 on:
April 08, 2021, 09:31:52 am »
I bought some type 4 case trough bolts Years ago on here, those anybody know what torque spec they need, or are they the same as stock torque setting.
Thanks in advance
Reply #187 on:
April 08, 2021, 14:59:45 pm »
Quote from: Eddie DVK on April 08, 2021, 09:31:52 am
Thanks in advance
Are they Raceware?
http://raceware-fasteners.com/main-bearing-stud-kits/
If yeas, I will look it up as I have a set myself that I should use soon. Tomorrow latest I should know.
Some of my cars:
Reply #188 on:
April 09, 2021, 07:42:08 am »
Quote from: Frallan on April 08, 2021, 14:59:45 pm
Thanks in advance
Are they Raceware?
Thanks Frallan, but they are not the raceware, they are the 12.9 bolts, you see for sale some times on here.
Reply #189 on:
December 01, 2021, 12:45:42 pm »
Reply #190 on:
April 19, 2022, 09:15:35 am »
Goodday,
Can somebody tell, at what horsepower level you need a bigger fuel line (8mm) on carburetors.
And maybe how you notice this, if possible.
Thanks in advance
Reply #191 on:
April 20, 2022, 19:48:10 pm »
Quote from: Eddie DVK on April 19, 2022, 09:15:35 am
Goodday,
Thanks in advance
Hi Eddie
I am not sure there is a exact hp level, to many variables but 1st sign is usually fuel starvation in 4th gear under hard acceleration
Reply #192 on:
April 21, 2022, 07:23:40 am »
Quote from: richie on April 20, 2022, 19:48:10 pm
Goodday,
Thanks in advance
Hi Eddie
Thanks Richie
karl h
Reply #193 on:
April 21, 2022, 08:10:40 am »
Berg wrote he had no problem with the stock pump and fuel line/IDAs untill the car went into the 12s
that being said, its easy to mount a new 8mm line when the car is off the pan (and a second one because one might go FI in the future)
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
Reply #194 on:
April 22, 2022, 06:38:14 am »
Quote from: karl h on April 21, 2022, 08:10:40 am
That is now, because pan is converted to IRS and off the body, so might as well do it now.
Thanks Karl
mikko k
Reply #195 on:
April 22, 2022, 07:18:30 am »
I would go even bigger than 8mm for future needs…
RMS Boxer Service
Reply #196 on:
May 10, 2022, 10:01:29 am »
Thanks in advance
I am pretty sure you bought the through bolts from me. You got the torque specs etc last year in a PM in this forum.
/Rolf
Reply #197 on:
May 10, 2022, 12:18:17 pm »
Quote from: RMS Boxer Service on May 10, 2022, 10:01:29 am
Thanks in advance
/Rolf
Correct, thanks for that.
Have set them to your spec.
regards eddie
Reply #198 on:
May 28, 2022, 09:05:58 am »
Hmmm maybe started a bit to late this year or the work is far more work than I anticipated.
Trying to make it to EBI this year, off course
Got the floorpan removed from the car, welded in IRS brackets for the new Rancho IRS box.
To match the new built 2.5L this time.
Had to repair here and there some rust problem
Repainted everything.
Longblock ready
Floorpan welded and new coat of paint
Small repairs...
As it stands now ready for the engine
Testing oil pressure, new fuel lines, fuel pressure.
Adjusting cilindertins for the big cilinders.
Fingers crossed
Last Edit: May 28, 2022, 09:12:49 am by Eddie DVK
Reply #199 on:
June 08, 2022, 09:10:52 am »
It s alive.
See film below.
Last Edit: June 08, 2022, 09:12:27 am by Eddie DVK
Reply #200 on:
June 08, 2022, 09:14:39 am »
Congratulations! Always a nice milestone!
Some of my cars:
Reply #201 on:
June 08, 2022, 17:38:49 pm »
Quote from: Eddie DVK on June 08, 2022, 09:10:52 am
It s alive.
See film below.
Excellent
Reply #202 on:
June 09, 2022, 06:40:17 am »
Thanks guys,
I have to say I was very happy.
had a spark
had fuel (well a small leak but repaired that)
had oil pressure
so fired it up, it started at the first go...
Now tuning it a bit for the dyno.
and finish everything so I can go on the dyno
and than to EBI
alex d
Reply #203 on:
June 09, 2022, 08:37:06 am »
congrats! I hope to see it in Chimay
Reply #204 on:
June 22, 2022, 09:49:32 am »
Well a bit of a downfall.
Came back from my holiday with covid,
Been in quarantine since.
so had to postpone my date at the dyno, car had a days work left, which could not be done now.
So could not send one off my buddies either.
Was happy for my holiday that I made it, but did not expect to be coming home sick after the holiday.
Can t do nothing about it, i have tried.
So no EBI this year in my bug, which is unfortunate.
Have to sit this shit out and hope I am well for EBI.
Eddie
Reply #205 on:
October 28, 2022, 10:28:35 am »
Well, went on to tune the carbs, but that did not go according to plan, hit a problem.
The dellorto 45s kept leaking air somewhere, have replaced everything on the carbs, seals, bearings, jets,
swapped them from left to right including the manifolds. But still the air leak would not disappear.
It is idling rough and when you give it gas the revs jump from 2500 straight to 4000 without flooring the peddle.
Did about 20 test, then gave it quits, needed to be somewhere with the car, so swapped the dellorto 45s for the weber 40 I had on my old engine (2.0L ).
Runs smooth at idle and responses well to the gas. (did not go beyond 4000rpms yet).
Altough I think the 40s are a bit to small for 2450cc engine, i stick with it till I got the 45 problem resolved.
Got a question for you guys on here, the 45 dellorto is leaking somewhere at the base, what could this be.
If i spray break cleaner at the base the revs jump up.
Did block the enrichment circuit, they told this could be the problem but it was not.
So open for suggestions.
Reply #206 on:
February 19, 2025, 10:10:20 am »
Ok,
smal update, got the engine sorted out.
Got it to the dyno, made good figures.
Had someone drove in to the back of my car while parked, so did not enjoy a lot last year of my car.
But it is back from the bodyshop repaired.
So will be enjoying it this year.
And did find some cool carbs too with matching type 4 manifolds.
Last Edit: February 22, 2025, 11:17:23 am by Eddie DVK
Clatter
Reply #207 on:
March 18, 2025, 19:06:28 pm »
Love this build. Been following for years.
You go brother…
Reply #208 on:
March 19, 2025, 16:55:09 pm »
Quote from: Clatter on March 18, 2025, 19:06:28 pm
You go brother…
Thanks, did some miles on the engine, but needs to drive it in. So going this weekend for some fast drives..
Keep you posted.
Reply #209 on:
June 07, 2025, 10:56:18 am »
Well got some Remmele heads upgrade. They came by online. Could not resist and bought them and send them to JPM for some valves and porting.
The heads that are on now are modified CU heads which flow well but did not upgrade them from 2.0L to 2.5L in valve size so they have a bit of to small valves for that combo (42x36).
So the Remmel heads have now 46x38 valves which hopefuly get me in the 200HP range... is kind off an obsession for me, then i can rest hahaha.
Last Edit: June 07, 2025, 11:25:12 am by Eddie DVK
6
7
8
