September 22, 2026, 00:43:26 am
| | |-+  Grelland's Ghia
Pages: 1 ... 3 4 [5] 6 7 ... 20 Print
Author Topic: Grelland's Ghia  (Read 373021 times)
Grelland
« Reply #120 on: June 30, 2007, 23:37:16 pm »
Then the piece was trial mounted and the final trimming still remains:
The second picture is taken from the outside of the inner fender, but this view will be lost once the outer panel is attached.
« Last Edit: July 01, 2007, 22:54:35 pm by Grelland » Logged
___________________
Roy
Grelland
« Reply #121 on: June 30, 2007, 23:38:49 pm »
And the final pic show the wheel arc being trial mounted once again, to ensure the fit.
___________________
Roy
Grelland
« Reply #122 on: July 01, 2007, 22:55:33 pm »
And after tonights session, the area now looks like this:
___________________
Roy
Grelland
« Reply #123 on: July 01, 2007, 22:56:38 pm »
Smoe clean-up, and sandblasting, now, and this entire corner of the car can be sealed up :-)
___________________
Roy
Grelland
« Reply #124 on: July 07, 2007, 21:52:28 pm »
And this is how it looks now.
Man, buliding a Ghia from scratch is A LOT OF WORK....
___________________
Roy
Grelland
« Reply #125 on: July 22, 2007, 23:47:31 pm »
Time for some updates, I guess...
I have spent the last few evenings on the inner fender, and have run into several problems...
first of all the area was more rusty than I expected, and that says alot...
Here you can see I have cut away the rotten parts, and the next picture sho where I have stareted to fabricate the missing part of the shelf inside the car.
The last picture show the repair panel being trial mounted
___________________
Roy
Grelland
« Reply #126 on: July 22, 2007, 23:58:34 pm »
and then I had to separate the two layers of the rust panel, as the fit was terrible, and I was not able to shape the double panels..
The second picture show the outer reinforcement panel also attached, and the black stuff around the new panel is a welding primer, making sure all the unaccessable areas are covered. That was also a reason why I separated the panels, as they had no primer or anything where they overlapped.
The last pic show a modification I made in order to be able to fit the body without interfering with the "beetle cup" bar
« Last Edit: July 26, 2007, 22:43:37 pm by Grelland » Logged
___________________
Roy
Grelland
« Reply #127 on: July 23, 2007, 00:00:46 am »
and finally; in order to make sure the quarter panel aligns well with the pressing in the door, I reattached the door once again.
Here you can also see that the frontmost part of the inner fender has been trial fitted.
« Last Edit: July 24, 2007, 00:28:14 am by Grelland » Logged
___________________
Roy
roland
lates are the new splits...
« Reply #128 on: July 24, 2007, 09:07:23 am »
that's mad, impressive work!
« Reply #129 on: July 24, 2007, 09:40:29 am »
which parts of the original  vehicule does it stay  Grin
nice job roy  Wink
fabian
Grelland
« Reply #130 on: July 26, 2007, 22:43:09 pm »
nice job roy  Wink
fabian
It seems only the roof and the top parts of the rear fenders will survive..., ah, also the firewall and most of the engine compartment :-)
___________________
Roy
« Reply #131 on: July 26, 2007, 23:46:22 pm »
Damm Roy It's not in Paint Yet??? LMAO    it's Looking Good
Grelland
« Reply #132 on: July 28, 2007, 22:31:06 pm »
not quite  Wink ... but here is a sneak preview of what this will look like :
___________________
Roy
« Reply #133 on: July 29, 2007, 03:52:56 am »
I Hope you are taking lots of pictures as you go I cant Imagine how many hours have gone in to your car just to get it where it is at now  you have to have a real love for a car to devote the time it takes to do it right.. Car is Looking Great Roy
Grelland
« Reply #134 on: July 29, 2007, 23:35:26 pm »
Yup, I just counted, and I have 748 pictures in the project folder on my computer... And I am definately not counting the hours...
___________________
Roy
« Reply #135 on: July 30, 2007, 02:38:21 am »
LOL why not??  I ll Bet  your making less then 1 cent per hour worked LMAO Grin Grin Grin
Grelland
« Reply #136 on: August 09, 2007, 13:08:55 pm »
Dont rub it in..  Wink
___________________
Roy
Grelland
« Reply #137 on: August 09, 2007, 13:11:24 pm »
Small update:
It seems that the inner fender finally has all the rust removed, and I can prepare for applying some primer, sealer and undercoating before the final coat of paint in this area:
___________________
Roy
Grelland
« Reply #138 on: August 09, 2007, 13:15:37 pm »
There is still some chickenshit to be ground off in the lower part of the first pic, but I had to stop last night, as the noise with the grinder is terrible, having the entire head inside the inner fender...  Still rings...
The next step here is to apply some paint etc on the surfaces that will be un-accessable later, before mounting the last part of the fender lip and quarter panel.
I also made some small progress on the engine, as the plenum for the FI setup is done. I know this engine is not as per the"Cal-look laws", but I really don't care, as I want to learn more about FI and engine management, and figured this engine would be a perfect place to develop these skills :-)
The cal-look is still my inspiration for the overall look and stance of the car, so I hope I still qualify to hang around on this site Wink
« Last Edit: August 11, 2007, 21:01:59 pm by Grelland » Logged
___________________
Roy
Trond Dahl
« Reply #139 on: August 09, 2007, 22:12:50 pm »
With the amount of work you have taken upon yourself and executed with such quality of work, who are we to exclude you just because you run a bit different engine setup... nah.. keep up the good work and keep taking pictures for us :-)
Race car 9.49/236kmt@SCC 2017
yvre
Der Autobahn Scrapers
« Reply #140 on: August 10, 2007, 18:42:10 pm »
I've been following your thread on the STF. I love the design and I'm curious to see how it goes. Planning an intercooler?
Grelland
« Reply #141 on: August 11, 2007, 16:57:51 pm »
Thanks, no, no plans for an intercooler nor a turbo. Believe me, I am also curious as to how it will work :-)
___________________
Roy
« Reply #142 on: August 11, 2007, 19:17:31 pm »
Grelland you are inspiring me to Turbo the T4 in my Ghia (with DTM shroud). Plenum and all looks perfect.Are you welding all this TIG, I only have a MIG.( but also an aircraft TIG welder, if i beg long enough). Have a relaxed Wkend.
« Last Edit: August 11, 2007, 19:22:52 pm by FDK/Hurry » Logged
Grelland
« Reply #143 on: August 11, 2007, 20:59:45 pm »
I'm using a MIG for this. I will ultimately build this in alu, and by then I need to have "converted" to a TIG....
Glad I can be an inspiration for others, even at a cal-look forum :-)
___________________
Roy
« Reply #144 on: August 21, 2007, 17:27:54 pm »
Grelland, where will you locate the injectors ? In the manifolds or in the central box on top...?
Grelland
« Reply #145 on: August 21, 2007, 19:17:27 pm »
They will be located on the manifoils, aiming at the back of the valves.
btw, there has been some updates the last few days, and I have finalised the runners, and here I have mounted the plenum using rubber hoses:
« Last Edit: August 21, 2007, 19:25:12 pm by Grelland » Logged
___________________
Roy
Grelland
« Reply #146 on: August 21, 2007, 19:20:45 pm »
Next on the engine list is to fabricate and mount the injectors, and a few brackets and mounts for various sensors.
I also made some minor progress on the car, as I opened up holes for the rear bumper brackets, and trial mounted the bumper to ensure a good fit against the fenders etc. I also painted the part of the heater channel that will be covered by the outer skin on the quarter panel, so that I can now finalise this part of the car also.
« Last Edit: August 21, 2007, 19:25:56 pm by Grelland » Logged
___________________
Roy
kev d
« Reply #147 on: August 25, 2007, 23:06:12 pm »
Been following this thread for a while - good work!
I`m really interested in your engine, I love seeing new ideas & want to learn about efi & so on, the technology is there - why not use it?
Cheers,
Kev
Grelland
« Reply #148 on: August 26, 2007, 20:09:16 pm »
I also like the thought of utilising newer technology. I will keep you posted on the progress on the engine too.
Progress is a little slow the last few days, as I have been busy organising a local show this weekend,
here's an overview pictures of the show:
___________________
Roy
Grelland
« Reply #149 on: August 26, 2007, 20:10:32 pm »
As you can see, we still have summer here in Norway, so the oulook for next weekend's action at Gardermoen should be the best
___________________
Roy
