September 22, 2026, 01:15:01 am
| | |-+  1200turboT1
Pages: [1] 2 Print
Author Topic: 1200turboT1  (Read 51655 times)
Jesse Wens
« on: May 05, 2009, 11:50:36 am »
and something else, fuel will be propane
« Last Edit: March 01, 2013, 16:04:37 pm by ruffbiker » Logged
JSL
« Reply #1 on: May 05, 2009, 13:41:35 pm »
Awesome!
This is something I wanted to do to my 1200cc as I have about 3 motors at home so can rob lots of parts!  Smiley
Is this a standard/stock 1200cc long block? I was told two things that put me off when talking with others about doing this.
1) There are issues with the oil flow on a 1200cc case therefore a 1300cc case (or bigger) are better to use as they have better oil flow.
2) The 1200c crank can only rev to around 4000rpm before it flex's and will either snap or cause serious damage
Have you done anything to over come these issues? Or do you just not care Grin Hehe
Would love to read more about your build! Wink What turbo/carb you used etc
Cheers,
J
jamiep_jamiep
« Reply #2 on: May 05, 2009, 16:27:58 pm »
Looks like a fun project ruffbiker!
« Reply #3 on: May 05, 2009, 22:24:09 pm »
Interesting....more info please.  Shocked
Jesse Wens
« Reply #4 on: May 06, 2009, 12:00:05 pm »
It used to be a box standard late 1200 so it has the big oilchannels and the 2 relief pistons. I don't know the history of this engine but it fired right up and drove without trouble.
Next thing I did was swap the heads for 1300DA heads, ad the 1.1 ratio rockers ,4 in 1 exhaust, 009 dizzy , put on a narrowed doghouse fanshroud with fan and cooler. With the shroud narrowed I could fit 2 36mm dell drla's. This was a great engine, good fueleconomy, responsive and faster then a stock 1600. I also believe that the cranckshaft might be the weak link in all this but I revved the engine unill there was no tomorrow and it still lives. I did give it the single gene berg springs.
Next thing on the planning, turbo...
First try was just that , a try. The car was slower than before. The turbo was to big and the exhaust piping let of the bit of pressure that could have made it do something.
This is the second and more calculated try.
The propane will be brought in before the turbo (like drawthrough), but the throttle is behind the turbo (like blowthrough).
Hope to go to injection oneday but this will do for now.The plenum is waterjacketed and will be cooled by water going through the vaporiser (vaporisers freeze up when you don't heat them). We will add a coil through the exhaust or a cooler to bring the system in balance. Guess it wil need extra heating though. We'll be racing bugin, das drag day and the two circuit dragdays from keversite.nl in the fall. see you there
JSL
« Reply #5 on: May 06, 2009, 13:22:36 pm »
WOW!! Thats SWEET!  Shocked
Cant wait to see it run!
So good to hear all this can be done to a little 1200cc  Grin
Time to get inventive in the garage!  Wink
I wish you all the best with your INSANE 1200cc!!
Please please post more pics and info when you can!
J
Paul da Graca
« Reply #6 on: May 13, 2009, 12:18:38 pm »
What will the HP/PK/BHP will be on this motor!!!  Grin
I will be buildling a 2332cc motor with a turbo that in our calculation will give me 300pk!!!  My 66 bug is going to love me!
Jesse Wens
« Reply #7 on: May 17, 2009, 13:44:04 pm »
yours will be twice as big so mayby mine will have 150hp?
Would be nice
Jesse Wens
« Reply #8 on: May 26, 2009, 11:51:10 am »
Engine has ran. Tuning the litle beast has begun.
First outing end of june, dynorun will be made too.
yvre
Der Autobahn Scrapers
« Reply #9 on: May 26, 2009, 22:16:02 pm »
I'm really curious to see how this thing runs!
JSL
« Reply #10 on: May 27, 2009, 10:55:43 am »
Me too!! It sounds awesome!!! Keep us all posted ruffbiker!  Wink
Airspeed
« Reply #11 on: May 27, 2009, 13:41:10 pm »
2) is pure  bollocks! where did you 'read' that?
If well build, those cranks with their tiny 77mm pistons can run well over 6K rpm  Wink
JSL
« Reply #12 on: May 27, 2009, 17:03:47 pm »
Hahaha!! A little harsh maybe but ok Grin
"1200 cranks are good to 5,000, mine often sees 5,500rpm.....they snap at anything over 6,000.......but flexing starts as low as 4,000rpm......
(if you flex them too much, metal fatique sets in and it may snap at tick over when you least expect it !!)
Bearing life on 1200 cranks often used above 4,500 is very short...expect less than 10,000 miles. The centre main wears on the sides but top to bottom remains untouched......."
Yeah so I was 500rpm under. This is from a thread on VZI called HOT 1200 ok so its general rule of thumb. But makes sence to me and its a good read! Smiley
Depends how lucky you are I guess  Grin
Cheers,
J
Airspeed
« Reply #13 on: May 30, 2009, 18:52:34 pm »
Ah, well, if you have read it on another forum, it must be true then.. Tongue
It must be a 'callook thing' I don't understand...  Cheesy Grin
Proof your 'lend' statement is bollocks:
1200 tuning challenge am 1Mei Meeting Hannover germany this year.
This turbo 1200 has a stock 1200 case, crank and rods and was tuned by a friend of mine: www.turboboxer.de
Das Auto:
The engine was restricted because of a limiter set accidently a 6100 rpm, while the engine clearly wanted more...
Your were saying?  Grin
Jesse Wens
« Reply #14 on: June 01, 2009, 19:16:57 pm »
Just made the first testdrive. It's going to be an interesting summer.
Drives like a dream.
JSL
« Reply #15 on: June 01, 2009, 22:13:33 pm »
Sweet!
Great to hear its running like a dream!  Grin
I just started the strip down and check over of my little 1200cc project, all looks good! Cant wait to get stuck in!  Cheesy
Ruffbiker, do you mind me asking what carb & turbo you are using?
Please keep pics and updates coming  Cool
J
Jesse Wens
« Reply #16 on: June 06, 2009, 12:16:55 pm »
The turbo comes from the psa group (citroen peugeot)
It's the one used on the 1400cc diesels in several of the smaller cars.
should be easy to find
The engine in my setup doesn't have a carb. It's liquid propane powered and is fueled by a venturi that's located between the turbo and the airfilter.
Throttlebody is after the turbo and is from a bmw motorcycle.
To answer the question coming, yes gas is going through the hot turbo and no it doesn't explode.
see you all this summer
going to
budel
ebi3
spa
ddd
kcd practicedays
yvre
« Reply #17 on: June 06, 2009, 20:29:49 pm »
What about a pic of the car so we can find you at those events?
JSL
« Reply #18 on: June 07, 2009, 12:36:49 pm »
Yes! A pic of your ride would help find you  Wink
I just picked up a Garret T2 and 1300 twinport heads for my little 1200cc motor :-)
I definitely going to EBI3 & BugJam
J
Jesse Wens
« Reply #19 on: June 09, 2009, 21:51:03 pm »
We ran the car at ebi last year with a 1200 with double drla's.
At ddd with a try out turbosystem wich was slower then the carb engine.
So yes, we we're the slow,crapy car from last year
That's when we decided to do it the right way, this way.
Come over this summer when you see us, we love the looks of disbelieve  Grin
« Last Edit: June 09, 2009, 21:52:49 pm by ruffbiker » Logged
yvre
« Reply #20 on: June 10, 2009, 08:47:18 am »
I remember it now...
Jesse Wens
« Reply #21 on: June 12, 2009, 16:46:25 pm »
We've certainly improved in looks, let's hope the timeslips will be equaly better
Jesse Wens
« Reply #22 on: July 06, 2009, 11:56:57 am »
15.421 @ ebi3
1200cc turbo lpg
no trailerqueen
AntLockyer
« Reply #23 on: July 06, 2009, 19:14:14 pm »
Nice work!!!
12.618 @ 104.87mph
sven
« Reply #24 on: July 06, 2009, 20:25:32 pm »
this is definitely thinking out of the box.
Good luck and see you at the track.
Sven
JSL
« Reply #25 on: July 07, 2009, 11:22:47 am »
15.421 @ ebi3
1200cc turbo lpg
no trailerqueen
Hey Ruffbiker!
Watched you race! It ran sweet! Well done for such an impressive time on such a small motor!
Shame I couldnt find you later to chat and have a look at it,  but very impressive! Well done!
J
« Reply #26 on: July 08, 2009, 16:54:59 pm »
it was fun seeing that car race. great fun indeed.
see you guys again at the next event.
jamiep_jamiep
« Reply #27 on: July 09, 2009, 08:44:30 am »
Wow, thats a great time for a 1200!
Jesse Wens
« Reply #28 on: August 11, 2009, 18:25:30 pm »
we're still running a standard camshaft.
Now a new one is needed and I thinking what would suit the engine better.
A bit more lift, same duration and bigger lobe center....
Anybody knows something like that or do I have to have a custom one made?
any help appreciated.
How fast can a 1200cc engine go....?
mr horsepower
« Reply #29 on: August 14, 2009, 20:30:46 pm »
untill it blows up jesse
7.2 litre topfuel engine 8000 hp
1.2 litre vw on nitromethane thats 1320 hp in theory.
gr henri
Pages: [1] 2 Print
