September 23, 2026, 22:27:47 pm
TriPower ????
Topic: TriPower ???? (Read 11470 times)
johnl
TriPower ????
May 07, 2009, 19:06:31 pm »
I've been e-mailing with a fellow who has a VW with something I've never seen. I'm curious to know if any of you know anything about this setup. Attached are some of his comment regarding how this system works and also a photo of the setup.
"The system works like a progressive system, center carb is for startup, low to mid range, it has a high air correction jet, .225, so it leans out at high rpm's. The side carbs, Tillotsons, work like vacuum secondaries, they are shut down during low to mid rpm's but open via a spring loaded center linkage, at higher rpm's. Tillotsons have a 25mm venturis and an adjustable jet which makes them perfect for this use. I got a higher highway speed now, I can go about 70-75, but, I don't like to drive that fast."
simon uk
Re: TriPower ????
May 07, 2009, 20:26:30 pm »
Hi john, I understand there is a thread on this on thesamba, in the old speed forum. It certainly is pretty trick looking! I might try and find it in a minute and post the link on here.
simon uk
Re: TriPower ????
May 07, 2009, 20:30:18 pm »
yep, here it is:-
http://www.thesamba.com/vw/forum/viewtopic.php?t=276715
johnl
Re: TriPower ????
May 07, 2009, 20:40:54 pm »
Quote from: simon uk on May 07, 2009, 20:30:18 pm
yep, here it is:-
Simon,
Thanks for the link. Very interesting concept.
Re: TriPower ????
May 08, 2009, 01:38:06 am »
Whoa... pretty bizarre concept.
Re: TriPower ????
May 08, 2009, 03:22:20 am »
John,
That's actually my tri-power kit sitting on my kitchen table !
The person on the Samba built a replica of it.
These were actually produced way back when.
I have a 36hp version (shown) and also a 40hp version.
Richard Roth
Re: TriPower ????
May 08, 2009, 17:59:02 pm »
The video of it running is sooo cool
Just seeing all of those throttles crack open at the same time is awesome!
johnl
Re: TriPower ????
May 08, 2009, 20:45:31 pm »
Quote from: Richard Roth on May 08, 2009, 03:22:20 am
John,
Richard Roth
Wow, you had the fastest ktchen table in town !!! Do you still have it and who actually built them?
Re: TriPower ????
May 08, 2009, 21:08:03 pm »
Weird, but interesting to see it running.
Re: TriPower ????
May 09, 2009, 01:32:09 am »
Quote from: johnl on May 08, 2009, 20:45:31 pm
John,
Richard Roth
Yes, I still have them.
I have a small collection of what I think are unusual vintage intakes.
I have never been able to find out the name of the company that made that particular set-up, but I know of two other original kits that are identical to mine.
The guy on the Samba was trying to buy it from me, and when I wouldn't sell, he made his own.
Re: TriPower ????
May 09, 2009, 01:48:52 am »
This thread just gave me a horrible idea for a gasser
Re: TriPower ????
May 09, 2009, 01:50:37 am »
Dig the way that engine looks, Nico.
ESH
Re: TriPower ????
May 09, 2009, 11:14:18 am »
I think there's something similar going on with the engine on the '52 in the back of the Wolfsburg West catalogue.
Re: TriPower ????
May 09, 2009, 21:31:21 pm »
Mat, can you post that photo ?
Re: TriPower ????
May 09, 2009, 22:13:19 pm »
I think the one in the back of the WW catalog is just a normal 25/36hp motor with Solex/Okrasa carbs and manifolds doing a balancing act on the cylinder head tin.
ESH
Re: TriPower ????
May 10, 2009, 12:00:43 pm »
Quote from: Richard Roth on May 09, 2009, 21:31:21 pm
I'll dig it up and scan it later at some point.
Quote from: Zach Gomulka on May 09, 2009, 22:13:19 pm
You're probably right, seem to remember there being three carbs in the picture but no idea how they got there...
ESH
Re: TriPower ????
May 24, 2009, 11:01:27 am »
A bit of a delay but here it is, Zach was right.
