July 02, 2026, 01:56:00 am
bigsiembowski
in the last 15 years: most popular 'Cal Look' engine combo has been?
Topic: in the last 15 years: most popular 'Cal Look' engine combo has been? (Read 21685 times)
August 11, 2009, 19:54:41 pm »
The early 1970's hot rod VW's.... the 1700 was the hot ticket, with the occasional 1835 or stroker mixed in, as the decade wore on. By the 80's, 94's had come around, and street cars started running 1914's, etc... at least from what I can remember. By the time 1991-92 came around, I had the 2276 in my own car with Super Flows and the Berg K10 cam, and at least up north... it was sort of unheard of to run a "big" motor, at least that big.
But now?
What do you think the signature "cal look" motor will be remembered as, within the last 15 years or so?
Turbo?
I have a feeling I know what most of you will say... and if I am right, I'll post some further thoughts.
Re: in the last 15 years: most popular 'Cal Look' engine combo has been?
August 11, 2009, 20:08:56 pm »
I would say 2276 as featured in the HVWs Blueprinting article with slight variations. But the basic recipe is the same. K-8 cam, 82 or 84 stroke, 90.5/94 pistons, 48 idas, Berg sump, Berg linkage, MSD dizzy, welded or cnc heads, etc.
For a while there almost every engine you saw in mags had the same basic cookie cutter pattern. (Hey it works, why not.) I think the next step will be the 3 liter monsters that are just now hitting the street.
Edit: I must be slow. I just figured out who 1970 is.
Last Edit: August 11, 2009, 20:20:47 pm by louisb
August 11, 2009, 20:28:12 pm »
2276.
44 x 37 11:1CR
There has been a shift over the last few years to running a webcam 86b on the street, though i prefer my 86c
The Ideaman
HVW's 2276, the build that launched a thousand engines.
August 11, 2009, 20:44:39 pm »
2276 with VW journal, 5.4 rods and CNC heads. K8 and 1.4's. Will need very little fitting in engine compartment or trimming of tin. No big shims under Cima barrels.
It is the soldier,
Who salutes the flag,
Who serves beneath the flag,
August 11, 2009, 21:35:06 pm »
As much as I know "it works", the 2276/K8 deal, to me is overrated. From my experience, the K8 in the 2276 has no soul. Sure it runs and it's fast, but they run too much like a 1776/110, just bigger. Easy to drive, even for your mom. Good for 13's, drive it everyday...and so on. And I'm sure a dozen guys will debate it with me, but the powerband is just too plain vanilla. Drop the K8 in a 69mm stroke motor, and it's altogether different.
The 86C? It deserves its revered status. Look back almost 20 yr ago, Schwimmer was gunning high 12's out of the coral rag...same motor that shows up quietly to Nicks every month. Under 4500, as tame as the K8, but above? Better hang on.
Still like to see a resurgence of under 2000cc/high CR/40x35 or 42 x 37/'95%race' cams... 90.5x76, 310 degrees plus... anyone?
bmxnut65
August 11, 2009, 21:43:02 pm »
2276 - fk/89 11:1 ho heads 44x37.5
August 11, 2009, 21:44:24 pm »
Quote from: bmxnut65 on August 11, 2009, 21:43:02 pm
ho heads huh? they put out?
bugnut68
August 11, 2009, 21:55:16 pm »
Without a doubt: 1776, 7:1 compression, 40x35.5mm valves MAX, 1-3/8 heater box header and quiet pack, dual Kadrons or other similar single-barrel carbs. You just can't get reliable power above 7:1 on the street.
bmxnut65
August 11, 2009, 21:58:48 pm »
hey 1970,you got a problem with my og ho's.head uo bitch!!!!!!!!!!!!!!!
August 11, 2009, 22:06:53 pm »
Quote from: bmxnut65 on August 11, 2009, 21:58:48 pm
I don't but their 'pimpin' iz tuff' daddy Notcho does. Bitch.
Bill Schwimmer
August 12, 2009, 03:31:50 am »
Without a doubt it would have to be a 2275cc with big heads ,pump gas & a big cam.
This combo brought reliable 12 sec street sedans to the masses.
I remember when I was 1st putting my motor together the only other person I knew of with a street motor that big was Mark H. however his was a bit milder than mine. I just wanted something that was really fast, but did'nt run on race gas. I ended up building a motor with race spec parts & technology but with no compression.
It seems to have worked out pretty well, maybe I will take it apart some year.
Some people talk about how years ago small cc motors were runnings 12's, I seem to remember most of them having lots of compression, light cars & the motors taking themselves apart all the time.
Bang for the buck, its hard to beat a 2275 w/ cnc heads. It seems like they all make 200hp without even trying. I had to work at mine way back when. Nobody had done it yet..
As for the future 4" bore is here, I drove one the other night, it makes mine seem like a toy.
Last Edit: August 12, 2009, 03:37:50 am by Bill Schwimmer
Eddy Merckx
August 12, 2009, 04:35:37 am »
Quote from: Bill Schwimmer on August 12, 2009, 03:31:50 am
Yep! Thanks for that, Bill. He's right... the future is NOW and it's pretty gosh darned impressive. The engine was barely awake and haulin' arse.
August 12, 2009, 08:08:17 am »
2303CC W/XR310 Babe Erson cam, 44X37 Perf. Tech. heads, Berg 1 3/4 header, IDA's, made some good HP on Bergs dyno. Back when.
August 12, 2009, 10:01:36 am »
Most popular? Anything from 1915 to 2800ccm NA/Turbo/NOS, whatever works on the street for you. Size does not matter - HP does. Anything less than 150hp is borring and I do not want a borring hobby.
Last Edit: August 12, 2009, 14:43:30 pm by BeetleBug
August 12, 2009, 17:52:47 pm »
Bill S' motor became the template I think (for good reason), but I don't think most guys went with as far with cam and heads. And most guys can't run with Bill's car either. I know it was seeing his car go like a bat out of hell @ Sears Pt way back in 1992 that got me to notice his setup. His OEM head motor was leaving my Super Flow head motor in the dust.
I do think cylinder volume vs cam duration coupled with headwork does matter. 175hp that runs up to 6000 is not as much fun to me as 150hp that comes on hard after 4K and goes to 7K.
lawrence
August 12, 2009, 21:25:02 pm »
Quote from: 1970 on August 11, 2009, 21:35:06 pm
This will never be a mainstream movement because it is too easy and cheap to build something larger. The diehards focused on nostalgia will, however, be forever interested. For now I will stick with my 1914; hangon here comes 4k and 7k is not far up the road
"Happiness is a Hot VW!"
Rasser
August 12, 2009, 22:17:14 pm »
Quote from: 1970 on August 12, 2009, 17:52:47 pm
I have to agree with you on that, but you will have fun longer with the "boring" 175hp engine.
And that counts too.
1955 type1
1966 type2 13w deluxe
August 12, 2009, 22:29:52 pm »
1915/K8/IDA best bang for buck for a student cal look engine
August 12, 2009, 22:36:30 pm »
Quote from: Jesse/DVK on August 12, 2009, 22:29:52 pm
I have to agree there.
The Ideaman
August 13, 2009, 02:29:45 am »
Jesse, I'd bet you are right. Probably more 1914's than anything else out there.
It is the soldier,
Frenchy Dehoux
August 13, 2009, 02:58:49 am »
1776 or 2276
Frenchy
Doctor Detail ( Retired )
August 13, 2009, 04:39:08 am »
Quote from: louisb on August 11, 2009, 20:08:56 pm
I think he's hiding from a killer...........seriously.
August 13, 2009, 04:48:13 am »
I think the most popular Cal Look engine combo for the last 15 years has to be the 2276 or 2332/FK-8/44 x 37.5 heads/IDAs. It's a cookie cutter combo that make good power without much thought.
1946vw
August 13, 2009, 05:30:34 am »
84 okrasa, 88 slippers, 42x37.5 Steve Tims heads, crane 320b, Empi 1.4 rockers, 220 hp, now thats a cal-look motor
henk
August 13, 2009, 10:53:08 am »
i think 1776 i know a lot of people who started with a 1776 an then went bigger.
henk!!!
August 13, 2009, 11:32:29 am »
went straight to 1914
, didn't cost any extra than a 1776. Still don't see the point of 1776!
Jeff68
August 13, 2009, 14:51:05 pm »
When my 2110 (82 X 90.5) with 42 X 37.5 valves, IDA's and K10 was recently finished people said that it's an "old school" motor. Is it? I have seen many 2110's around in cars that are regularly street driven. All I know is that it runs really well and pulls hard through all the gears.
I used a K10 cam because I heard a few call the K8 a "Grandma Cam" and I wanted something with a bit more high end power.
From what have seen and heard it sounds as though the 4" bore is the future. If I ever "upgrade" my engine in the future I would definitely look in to a 4" bore combination.
dirk zeyen
August 13, 2009, 20:36:51 pm »
78.4 X 90.5
w120 with 1.25 ratio rockers ( the mark herbert cam read about that combo on the other forum tech articles)
9.1 / 1 compression
steve tims stage one heads
45 dellorto drla
1 5/8 merged with dynomax muffler
a lot fun without trouble
ok this is a farmer engine but it works for me and is fun enough on the streets!!!
dirk
back again!!!
August 14, 2009, 22:51:37 pm »
Quote from: stealth67vw on August 13, 2009, 04:48:13 am
not 89mm x 76mm, Engle 160, 42 x 35 heads by Ray Litz and DCN Webers on ACE manifolds?
dirk zeyen
August 14, 2009, 23:14:17 pm »
engle 160
duration, valve lift?
dirk
back again!!!
