September 19, 2026, 06:03:22 am
Bad Habit
The 4" Bore Thread
11
12
13
14
17
Topic: The 4" Bore Thread (Read 598262 times)
stealth67vw
Re: The 4" Bore Thread
Reply #330 on:
December 29, 2012, 23:27:00 pm »
Quote from: andy198712 on December 29, 2012, 21:08:21 pm
moving up to heads, are there any other options out there that are street worthy other then:
Super Flows
Angle Flows
JPM's
IE anything my bank wont disown me over?
Comp Eliminators
John Bates
JB Machining Services
12.34 @ 108 mph 1/4
7.76 @ 89mph 1/8
Reply #331 on:
December 29, 2012, 23:27:22 pm »
The one rule about heads is -- Look into your wallet and see how much you can afford to spend -- lay it out on the counter -- -- -- --
Heads are the one thing that can really help the performance of your car and you won't regret the money spent
http://selvedgeyard.com/
andy198712
Reply #332 on:
December 29, 2012, 23:37:10 pm »
Being possibly the most bang for your buck too I guess!
58vw
Reply #333 on:
December 30, 2012, 20:09:53 pm »
Quote from: MeXX on December 28, 2012, 22:45:25 pm
Quote from: 58vw on December 28, 2012, 21:55:59 pm
great pics mexx
THX Tim
What pistons do U prefer
MeXX
venolia are good...j&e also...trying a set of Cp's in new engine now..lighter for sure that the venolia..
www.4inbore.com
Angleflows...order them now
MeXX
Reply #334 on:
December 30, 2012, 21:42:06 pm »
Quote from: 58vw on December 30, 2012, 20:09:53 pm
Hi
What forging number do they have ?
I have tried till now: X100A and 28-1
The next I will try will be: X115 R
MeXX
Last Edit: December 31, 2012, 09:14:15 am by MeXX
Drag or Die
Shag55
Shag Leone, SL-1racing
Reply #335 on:
December 31, 2012, 00:37:27 am »
I have used Wiesco, JE, Venolia and now CP on the new motor. I love the CPs best. Oh but mine are just babies and don't fit I this trend. Only 92mm
Shag55.sl1racing@gmail.com
Facebook at SL 1 racing
MeXX
Reply #336 on:
December 31, 2012, 09:21:56 am »
Quote from: Shag55 on December 31, 2012, 00:37:27 am
Dear Shag
I've used Wiesco because they were of the shelf.
I've used Venolia custom pistons traditional design very rigid and forgiving.
I've used CP pistons X box forgings very innovative and professional design.
And Shag who says size doesn't matter ?
MeXX
Drag or Die
Reply #337 on:
December 31, 2012, 09:56:50 am »
I have build one wbx engine with 101's for racing only , it has 280 hp with 51 carbs , he has run 10,9 in a street car this year . But i would never build this engine size with less hp for german street driving - autobahn -
Last Edit: December 31, 2012, 15:37:59 pm by Udo
www.Udobeckertuning.de
Eddie DVK
Reply #338 on:
December 31, 2012, 12:10:17 pm »
Quote from: Udo on December 31, 2012, 09:56:50 am
Why not not Udo?
I have been collecting parts for a 4'' type 4 engine, deutz cilinders(100mm) and JE pistons de rest stock. (71 crank, CU heads, hoping a JPM cam).
Is this not ok for street use? Because will be a street engine.
Regards Edgar
Regards Edgar
Reply #339 on:
December 31, 2012, 15:38:51 pm »
On a type4 it is ok , this engine has 12mm more space between the cylinders
MeXX
Reply #340 on:
December 31, 2012, 16:26:15 pm »
Quote from: Eddie on December 31, 2012, 12:10:17 pm
Why not not ?
Regards Edgar
Dear Edgar
I'm 100% with Udo 4 inch with type 1 bore spacing (112mm) (doesn't matter what case: WBX, Autolinea, Scat, Autocraft, AF1; ARPM) is not good for street use.
The reason is the cooling or better the lack of it between the cylinders: if you have 112mm bore spacing and 101,6 bore there are 10,4 mm left for two barrels, cooling fins and space for cooling air for the bottom (hotter) side of the cylinders.
You have three possibilities:
1. Thin barrels cooling fins and space for the cooling air.
2. Thicker barrels no fins and little space for the cooling air.
3. Seamees cylinders with no space for the cooling air.
UC
MeXX
Last Edit: December 31, 2012, 16:41:35 pm by MeXX
Drag or Die
MeXX
Reply #341 on:
December 31, 2012, 16:40:55 pm »
Dear Edgar
As there are a lot of 4 inchers on street U have some possibilities to overcome this problems:
Take heads with a lot cooling fins like Thorsten Pieper or JPM's.
Take nikasil instead of casted iron barrels lower friction means less heat and aluminum can transfer the heat better from the hot sections to the ones where there is more cooling.
If you take nikasil 100mm Porsche is better than 101,6 as it is thicker and superior in quality.
Run oil squirters and really huge oil cooler to transfer air cooling to oil cooling.
Low CR and low horsepower produces less heat. (but who wants a 4 inch low HP mill
Thinking of running E85 it would make everything much cooler.
MeXX
Last Edit: January 01, 2013, 08:27:56 am by MeXX
Drag or Die
Reply #342 on:
December 31, 2012, 18:14:13 pm »
Edgar has a type4 so he has original good heads for that bore .
Shag55
Reply #343 on:
December 31, 2012, 21:46:53 pm »
( And Shag who says size doesn't matter ? )
When it is N/A it does! Bigger bore = bigger intake=more power!
In my case ( turbo ) bigger bore = less efficiency, more heat and less strength.
dangerous
Reply #344 on:
December 31, 2012, 22:22:14 pm »
Quote from: Shag55 on December 31, 2012, 21:46:53 pm
When it is N/A it does'nt! (haha)Bigger bore = bigger intake= less air speed=less power!
I edited your post Shag, ha ha!
Erlend / bug66
Global Moderator
SCC Event
Reply #345 on:
December 31, 2012, 22:49:49 pm »
Kinda depense on what you are after. Most hp pr liter or most hp overall. The NA engines with the highest number of hp pr liter must combine the fastest airspeed, most flow, most suitable bore and optimal stroke to push out the hp it needs. Or you can build a 3liter type 4 with 300hp.
It's much, much cooler to have 235-245hp from a 1915cc than 300hp from a LARGE type 4
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
Shag55
Reply #346 on:
December 31, 2012, 23:15:25 pm »
How about 375 or more from a 74x108, or 230 from a 74x88?
What about turbo motors?
Erlend / bug66
Global Moderator
SCC Event
Reply #347 on:
December 31, 2012, 23:39:57 pm »
Quote from: Shag55 on December 31, 2012, 23:15:25 pm
Nice numbers
Turbo beats it anyway
The '67:
The '59:
Not yet..
dangerous
Reply #348 on:
January 01, 2013, 03:44:20 am »
Hi Shag, Turbo motors will likely benefit from the large throats,(and bores)
but it is a bit hard to tell, since there are good numbers from even small bores.
Even tiny engines make great power with boost so long as the tune is right.
No disrespect to anyone with my observations,
but if you ignore dyno claims,
and use MPH and mass, to align the scale:
I can only comment what I have seen,
and by using track performance as a bench mark/datum,
I have never seen any VW engine show better than about 340,
that is Super street and pro stock record MPH's.
None with 108 bores and huge valves.(the large valve/throat cross section being my sore point)
Perhaps if the 11 or 12000rpm were used to get the air speed up? who knows.(or longer strokes).
I am sure anything is possible, but yet to see any record numbers from the big bores and large valves that normally go with them.
The other problem is that because most classes are capacity limited,
the large bore means short stroke, and even with rod lengths under stock,
it just agrivates the air speed issue.
Type 4's?
I can only think of two N/A ones in the world that are around a real 300hp(calculated from MPH not imagined),
and I'l bet they are either big cc or have smaller(<54mm) valves and likely comparitively short rods.
These are only my viewpoint on what(how) i see around the traps.
I hope my comments give food for thought and generate some discussion.
Shag55
Reply #349 on:
January 01, 2013, 05:05:36 am »
I'd say you may be right. Until we see he #s equated from MPH they we all just figures from a dyno.
Pats motor I believe is in the Neighborhood of 330 at pro stock weight. Roger Crowfords pro stock motor is there also as well as his super street motor and its 82x96.5 bore
Reply #350 on:
January 01, 2013, 17:59:02 pm »
As far as i know one of the fastest super stock engines only has 90,5 bore . with 86 stroke something about 270 hp ...
So i think that big bores do not make the power. but the heads do
Shag55
Reply #351 on:
January 01, 2013, 20:50:38 pm »
That's a different scenario Udo. Valve size limited. The 90.5 bore has a better intake vale to bore ratio at 49%
MeXX
Reply #352 on:
January 01, 2013, 20:53:15 pm »
Hi
latest pix from my version of a street 4 inch mill
Bare Competition Eliminator with Beryllium seats installed
Stud holes drilled
Step for the combustion chamber and head gasket milled
Porsche nikasil barrels and billet spacers installed.
MeXX
Drag or Die
Shag55
Reply #353 on:
January 01, 2013, 21:31:47 pm »
Nice, are those CEs? What valve size and bore?
MeXX
Reply #354 on:
January 01, 2013, 21:41:39 pm »
Quote from: Shag55 on January 01, 2013, 21:31:47 pm
Dear Shag
Yes these are CE and I bought them as bare castings;
51,4mm intake valve 40mm exhaust valve
100mm bore Porsche 993 nikasil barrels.
MeXX
Last Edit: January 01, 2013, 21:43:28 pm by MeXX
Drag or Die
Shag55
Reply #355 on:
January 01, 2013, 22:09:03 pm »
Perfect! 51% of bore. If these are to be street heads then will you use an oil bar for cooling?
MeXX
Reply #356 on:
January 01, 2013, 22:12:27 pm »
Quote from: Shag55 on January 01, 2013, 22:09:03 pm
THX Shag
I run oil squirters on all engines street or race.
I run huge oil coolers to cope as much cooling as possible by oil
MeXX
Drag or Die
ibg
Reply #357 on:
January 01, 2013, 22:31:15 pm »
Dear Mex, what stroke are you using as the barrels look fairly short!
Do the spacers 'extend' the barrel to stop the piston cocking at the bottom?
MeXX
Reply #358 on:
January 01, 2013, 22:41:15 pm »
Quote from: ibg on January 01, 2013, 22:31:15 pm
Dear Ian
As Porsche uses only 76mm stroke this barrels are very short. Maximum stroke U can run is 82mm,
the spacers a necessary to get the right height with Autolinea case and 5.400 rods.
MeX
X
Drag or Die
Reply #359 on:
January 01, 2013, 22:56:39 pm »
My 104 mm JE. 440 g with CNC copied dome from my E-Plus heads.
71 mm stroke.
5.325" rods
Last Edit: January 01, 2013, 23:00:46 pm by Frallan
Some of my cars:
11
12
13
14
17
