July 26, 2026, 04:22:50 am
4 stud zero offset Erco's ?
Topic: 4 stud zero offset Erco's ? (Read 6902 times)
Black Sheep
less is more
November 18, 2009, 19:11:09 pm »
Has anyone tried to fit these bubble Erco's with disc brakes up front ?
Im thinking about enquiring to see if I can get a pair of these made in Porsche 130 pcd for when I go racing .
But I think I heard there may be a clearance issue with the caliper ?
Little help here please
13.03 @ 98mph
dth
Re: 4 stud zero offset Erco's ?
November 18, 2009, 21:31:53 pm »
Should be fine ,friend had a ghia with 5x130 zero off set Erco,s , he removed them ,but not because they didnt fit ,didnt like the look
dth
November 18, 2009, 21:34:10 pm »
Also ,i got them machined to 5x205 for my Oval ,but wouldnt clear the CSP brakes ,so Colin tried them on his (CB wide 5) and the fitted just fine
EL PINGO 66
November 20, 2009, 06:46:43 am »
yes man,, the erco buble w porshe pattern have problems whit calippers but i have those wheels w disk brakes of carman guia. and i put a 5/8 spacers and a long studs..
its the only solution and the other dont put zero erco put normaly...
Black Sheep
less is more
November 20, 2009, 07:59:54 am »
Thanks dude , I remember you posting these shots of the spacer and your car before now
13.03 @ 98mph
JSL
November 20, 2009, 10:44:08 am »
Nice! :-)
56 Bug Rat-look
http://www.volkszone.com/VZi/showthread.php?t=583273
54 Bug Cal-look Project
http://cal-look.no/lounge/index.php/topic,9879.0.html
Lil'turbo engine project
Defcon-3
http://www.defcon-3.co.uk
samba66
November 20, 2009, 10:56:15 am »
Yes i had to run a 10mm spacer with VW disc brakes
67worshipper
November 20, 2009, 14:32:06 pm »
Quote from: EL PINGO 66 on November 20, 2009, 06:46:43 am
i like the look of your car pingo on those rims.very sweet
vw hot rod heaven
EL PINGO 66
November 24, 2009, 01:23:01 am »
thaks for all comments..
saludos amigos
November 25, 2009, 17:45:03 pm »
I used 20 mm spacers to clear the caliper AND the balancing lead inside the wheels.
November 26, 2009, 16:47:32 pm »
Sven has a set of Porsche pattern zero offset fronts on his car. Search for "Gimini" in the In Da Werks forum.
