July 26, 2026, 04:22:57 am
| | |-+  4 stud zero offset Erco's ?
Author Topic: 4 stud zero offset Erco's ?  (Read 6904 times)
Black Sheep
less is more
« on: November 18, 2009, 19:11:09 pm »
Has anyone tried to fit these bubble Erco's with disc brakes up front ?
 Im thinking about enquiring to see if I can get a pair of these made in Porsche 130 pcd for when I go racing .
 But I think I heard there may be a clearance issue with the caliper ?
Little help here please  Kiss Wink
13.03 @ 98mph
dth
« Reply #1 on: November 18, 2009, 21:31:53 pm »
Should be fine ,friend had a ghia with 5x130 zero off set Erco,s , he removed them ,but not because they didnt fit ,didnt like the look Smiley
dth
« Reply #2 on: November 18, 2009, 21:34:10 pm »
Also ,i got them machined to 5x205 for my Oval ,but wouldnt clear the CSP brakes ,so Colin tried them on his (CB wide 5) and the fitted just fine Smiley
EL PINGO 66
« Reply #3 on: November 20, 2009, 06:46:43 am »
yes man,, the erco buble w porshe pattern have problems whit calippers but i have those wheels w disk brakes of carman guia. and i put a 5/8 spacers and a long studs..
its the only solution and the other dont put zero erco put normaly...
Black Sheep
less is more
« Reply #4 on: November 20, 2009, 07:59:54 am »
Thanks dude , I remember you posting these shots of the spacer and your car before now  Cool
13.03 @ 98mph
JSL
« Reply #5 on: November 20, 2009, 10:44:08 am »
Nice! :-)
samba66
« Reply #6 on: November 20, 2009, 10:56:15 am »
Yes i had to run a 10mm spacer with VW disc brakes
67worshipper
« Reply #7 on: November 20, 2009, 14:32:06 pm »
i like the look of your car pingo on those rims.very sweet Smiley
vw hot rod heaven
EL PINGO 66
« Reply #8 on: November 24, 2009, 01:23:01 am »
thaks for all comments..
saludos amigos
« Reply #9 on: November 25, 2009, 17:45:03 pm »
I used 20 mm spacers to clear the caliper AND the balancing lead inside the wheels.
« Reply #10 on: November 26, 2009, 16:47:32 pm »
Sven has a set of Porsche pattern zero offset fronts on his car. Search for "Gimini" in the In Da Werks forum. Wink
