September 23, 2026, 14:21:03 pm
| | |-+  Camshaft Registry
Pages: 1 2 [3] Print
Author Topic: Camshaft Registry  (Read 119402 times)
« Reply #60 on: May 29, 2017, 22:23:51 pm »
I wish I could come up with a cam card for the early Berg roller cams ... but I can do that on my own I suppose!
I have one catching dust on the shelf ... LOL
TxT
« Last Edit: May 30, 2017, 00:15:41 am by TexasTom » Logged
Dominick Luppino
« Reply #61 on: May 30, 2017, 16:24:28 pm »
Buy one of these, you'll know more  about what cam numbers then you would want to know...
https://www.indiamart.com/proddetail/cam-profile-machine-13164948148.html
« Reply #62 on: May 31, 2017, 02:27:45 am »
Not very hotrod-ish, sorry!  Grin
But if you have a mild nearly stock engine this is the best cam I've used. Really smooth, great economy, and broad torque band, stock or 1.4s rockers.
Schneider probably still have the cam number.
OK, back to hotrod stuff.......
 Cheesy
« Last Edit: October 13, 2017, 06:20:42 am by modnrod » Logged
« Reply #63 on: June 06, 2017, 23:56:13 pm »
Thanks but I'm good ...
I have a dial indicator and a good degree wheel.
« Reply #64 on: June 07, 2017, 18:01:06 pm »
Yep and a scratch pad to do your math... it's good to keep it simple.  Cool
Dominick Luppino
« Reply #65 on: June 07, 2017, 18:26:26 pm »
It just saves time knowing exactly what you're installing in your Engine, I've had Cams that weren't even close to the cam tag.....but hey, what do I know...
« Reply #66 on: June 08, 2017, 14:42:29 pm »
Engle W125
Still my all time favorite.  I ran my first one retarded four degrees in the '63 (1835cc).  Mated up to a close-ratio trans, it pulled hard in third and fourth...
« Reply #67 on: September 26, 2017, 21:46:02 pm »
That's why I have a degree wheel and a dial indicator!
I had a couple cams checked on one of those, but they were set up wrong and the data was useless.
I literally rechecked them in the case ...
Tools are only as good as the user!
bedjo78
« Reply #68 on: September 16, 2018, 07:52:42 am »
I am looking for FK97 cam card. pls share if you have it. thanks
Dougy Dee
« Reply #69 on: September 16, 2018, 22:19:37 pm »
Advertised Duration: 328
Cam Lift: 0.443
.050 Duration: 287
IO: 37
IC: 70
EO: 73
EC: 34
Lobe Centers: 108
Overlap: 71
Info from old Cam Card
Drag race only; 1.4:1 rockers. Wide Base Lifters
bedjo78
« Reply #70 on: September 17, 2018, 05:20:52 am »
Many thankss
« Reply #71 on: March 07, 2019, 17:14:36 pm »
W130
